Engine Specific Info and Questions => IDI Engine => Topic started by: nogama3 on August 08, 2007, 07:46:45 am
Title: Golf TD more power required - options?
Post by: nogama3 on August 08, 2007, 07:46:45 am
so what can i do next to get more power after this:
http://www.vwdiesel.net/phpBB/viewtopic.php?t=9939
i was thinking off maybe a front mounted intercooler, turbo or anything else you guys can advise.
Post by: zaprzal on August 08, 2007, 07:48:02 am
do you already have 1.6td boost pin? what turbo do you use?
Post by: nogama3 on August 08, 2007, 12:27:23 pm
using the original 1.9 pin and i beleive that its a kkk turbo.
Post by: bert on August 08, 2007, 12:42:31 pm
Nogama,come over to halesowen mate,i will take you for a blast in my AAZ TD mk1 golf,no intercooler,and its rapid,i just altered the aneroid pin  :wink:
Bert
Post by: nogama3 on August 08, 2007, 12:47:26 pm
Bert, I'll have to do that mate...
Post by: zaprzal on August 08, 2007, 12:51:55 pm
change boost pin for 1.6td one and check what turbo do you have kkk k03 or k14
Post by: nogama3 on August 09, 2007, 12:53:58 am
ok guys, bit of a thick question but where is this pin located and how easy is it to change it over, i take it its from a mk2 golf.
is this pin the same as mentioned by bert and zaprzal?
thanks
Post by: zaprzal on August 09, 2007, 01:01:27 am
(http://www.home.earthlink.net/~rps1976/Images/Diesel/Smog/Smog105411479.jpg)
pin is located here:
(http://img95.imageshack.us/img95/4820/pompavu2.jpg)
(http://img143.imageshack.us/img143/3429/membranaum1.jpg)
(http://img144.imageshack.us/img144/421/bolecwysunietync0.jpg)
(http://img142.imageshack.us/img142/8673/rysykt7.jpg)
(http://img207.imageshack.us/img207/2172/ldaur8.gif)
Post by: nogama3 on August 09, 2007, 03:48:40 am
very impressive pics.
next questions:
how do i go about changing this pin?
from which vehicle do i get this pin from?
is it a diy job?
Post by: zaprzal on August 09, 2007, 03:53:03 am
yes it is 100% diy ;) get one from 1.6td or machine yours.
Post by: nogama3 on August 09, 2007, 05:20:12 am
sorry to be a pain in the *ss, from which part of the engine bay do i remove this part from?
fuel pump or somewhere else?
thanks
Post by: zaprzal on August 09, 2007, 05:42:06 am
top of pump
Post by: burn_your_money on August 09, 2007, 06:09:20 am
Here you are
http://vwdiesel.net/phpBB/viewtopic.php?t=645
What is the green bar represent in this picture?
Post by: zaprzal on August 09, 2007, 06:10:55 am
Quote from: "burn_your_money"
I think it's fuel dose
Post by: con on August 09, 2007, 07:05:28 am
wow those pictures are really helpful. Ok so before you take the pin out you mark where it is so if you get lost you can return to stock?
Then is it just a case of turning the pin 180 degrees and putting it back?
Post by: gnavs on August 09, 2007, 08:49:47 am
those pics really clear things up.
and einspritz menge literally means inject mixes
lade druck = pressure loads
Post by: bert on August 09, 2007, 11:33:47 am
I will say that i got a 1.6 boost pin and it didnt fit the 1.9 pump,it was a different diameter,i had to alter the origional pin also my pump dont have a starwheel or smoke screw on the cap either look
(http://i78.photobucket.com/albums/j95/citigolf_2006/ebayjune003.jpg)
Bert
Post by: zukgod1 on August 09, 2007, 11:46:11 am
That is what I call a CLEAN engine!!!!
Kudos..!!
Post by: bert on August 09, 2007, 11:53:38 am
Thanks mate,i brought a scrap mk3 golf for the engine unseen £300 went to pick it up,opened the bonnet,its got a brand new bosch fuel pump on it,and its a nearly new genuine vw exchange engine,with the TDI crank in it  :shock:  nearly wet myself  :wink:
Bert
Post by: nogama3 on August 09, 2007, 01:53:51 pm
Quote from: zukgod1
Kudos..!!
that IS a clean engine...ENVY you big time!
Bert, i maybe free between Mon-Wed next week as the misses is going to Yorkshire for the week this weekend and I'm dropping her off so may try and pop down and see your motor.
Post by: zukgod1 on August 09, 2007, 02:25:43 pm
Have you removed the cap to see if there was/not in fact a star wheel under the diaphram?
Post by: bert on August 09, 2007, 02:44:04 pm
Yes mate,come any late afternoon,where do you live? and i have looked under my pin dan and theres no starwheel just the crappy 1.9 pin and the diaphram,and i had my shiney 1.6 pin ready buy it didnt fit the bore   :cry:
Bert
Post by: nogama3 on August 10, 2007, 03:27:41 am
I'll be coming over from Nuneaton mate. i'll get in touch with you to arrange our meet.
Sal
Post by: myke_w on August 10, 2007, 01:14:43 pm
http://youtube.com/watch?v=km171HDXOZ4&mode=related&search=
 :twisted:
Post by: nogama3 on August 12, 2007, 02:28:24 pm
never seen that video before but it has now put a big smile on my face!
