General Information => General => Topic started by: burn_your_money on July 19, 2007, 02:24:50 pm
Title: How much PSI will a mk1 fuel filter handle?
Post by: burn_your_money on July 19, 2007, 02:24:50 pm
The title pretty much says it all. I think I need something that will handle over 100psi. Also what temp would it be good up to?
Post by: bevboyy on July 19, 2007, 02:47:57 pm
Tyler, the design of the stock filter would not hold anything over 40 psi.
You're going to have to use one off a car that has multi port FI. GM Vortex comes to mind as their fuel pressure is close to 100 psi.
Post by: burn_your_money on July 19, 2007, 02:52:04 pm
Thanks, you probably just saved the life of my engine :lol:
Actually what is the max oil pressure ever created with a not so healthy engine?
Aren't the mk1 CIS engines pushing close to 100PSI as well?
Post by: bevboyy on July 19, 2007, 03:01:35 pm
Oil pressure should be around 60 psi if memory serves me right.
The CIS pressurizes the fuel at the fuel distributor. The pump is I think 90gal/min - this again is by memory..
Post by: hillfolk'r on July 19, 2007, 08:17:02 pm
ive had my  fuel  pump regulator act up,and send 50-60 psi to the pump before without blowing out......
im using a cis pump for a lift pump with a cheezy  home depot regulator  to  bypass the extra pressure
i normally keep it at 42 psi(idling),cause under a load itll drop to mid 30s
any less,and it drops severely under a load
cool thing is i can open the pass. door and reach unde r  the car and adjust the regulator+watch my psi guage in my console
been like that for over a year
