General Information => General => Topic started by: dieselkidd on July 18, 2007, 07:53:21 am
Title: I want to build a tractor with my Tracker ! Need tips
Post by: dieselkidd on July 18, 2007, 07:53:21 am
It's a 92 Geo Tracker, priced out an adapter kit (Acmeadapters) and  well a 1.9TD would be nice :lol:. IT would be GREAT for the up and comming moose hunt, None like it around. Is there anything I should know before I get my hands dirty? Fabrication? mods to chassis ,do have a 2'' suspension lift ,will the oil pan fit?fuel tank and lines,tranfer pump, exhaust pipe, will stock do? ANY INFO WILL HELP!
Post by: burn_your_money on July 18, 2007, 04:34:32 pm
Moved to the general section
Post by: dieselkidd on July 18, 2007, 08:25:21 pm
tkx
Post by: burn_your_money on July 19, 2007, 04:52:27 am
Do you have some more info on what you are doing exactly and with what?
Post by: jimfoo on July 19, 2007, 05:04:50 am
Big radiator, fan that moves lots of air!
Post by: dieselkidd on July 19, 2007, 07:04:33 am
TKX Jim .vw rad or stock ? would it fit in a tracker?electric fan?oil cooler?
Post by: Darth Garry on July 19, 2007, 09:53:48 am
Are you going to put a PTO on it?  Now that would be awesome!
Garry
Post by: jimfoo on July 20, 2007, 07:13:34 am
Quote from: "dieselkidd"
Much bigger than the VW rad, oil cooler also. You will have to have an electric fan as most Diesels don't have a provision for a regular fan. A fan from a 3.8 Ford Taurus moves a ton of air and is 2 speed. BUT it uses LOTS of power on high, 30 amps running, 100 amps starting, so it needs a big fuse and big relay. A friend of mine has a LWB Suzuki with a 1.9 and VW rad and he overheats all the time it seems. I have a much bigger radiator and still get too hot, so get the largest one you can fit in. You probably weigh less then me though. My truck is 3500 lbs.
You probably need a larger exhaust, 2" minimum, but 2.5-3" would be best, allowing cooler EGT's and better flow.
