For Sale/Looking For => Parts for Sale/Wanted => Topic started by: mpg on July 09, 2007, 07:35:02 pm
I've got 3 good working, non-leaking td injector pumps $150 each
1 n/a injector pump in questionable condition $60
2 good working k24's $200 each
2 good working t3's $200 each
1 k26 with a little shaft play from sitting around w/o oil for a while $150
audi 5cyl turbo manifold to fit k26 $100
2 audi external wastegates $100 each
1 vnt turbo off a '05 tdi pd, not sure on model, kkk... 1800kms $500!
2 turbos off saab 900's, garrett.. one needs a rebuild $100 & $200
3 complete 1.6td's, 2 work great, one needs a headgasket $500-$800
1 1.6d 210,000kms works A1 $400
Trannys, trannys, trannys. mk1&2, gas, diesel, diesel auto, 4spd, etc.
I have about 8 mk1's and 2's getting parted out right now, plus a couple storage containers full off goodies. If there's anything you need, I just might have it.
I'm definately willing to ship, but complete engines will be a bit of a bugger..
Sounds like you have more parts then I do :shock:
Any K14s in there?
how many km's on the diesel auto box? i might know someone who may be interested...
he's considering using the auto box from a gasser :shock: definitely need that E when you're sitting at the lights :lol:
How many miles on those 1.6 TDs? Any green interior parts?
Any shaft play on the working T3's? And are these off of a mk1 1.6?
I’m looking for an injection pump 068-130-110 H do you have that one?
Any K14s in there?
Sorry.. no k14's.. I'm looking for one, myself :(
The diesel auto tranny has 26x xxx on it.. It works good, does'nt bang when coming out of E like some do.I've heard the ratios are a little wacky on a gas engine, though.
One has 42x xxx Kms, and the one that needs a headgasket has 27x xxxkms. I had to use a longblock for a straight diesel rabbit I just picked up. I tried to go without a turbo engine, but I just can't handle it..
And green interior? Ihave to admit, I almost forgot that existed... been a looong time since I saw that.. Sorry I can't help you out
Very minimal shaft play. They are off mk2 jetta's.
Any "beater" TD pumps you'd be willing to let go for cheap?
I'll sell one that leaks around the sprocket seal for $90.. that's the only turbo pump I have that's faulty..
I need one of those td pumps. Will you take paypal? How much to send to northern california (95742).
Those engines wouldnt be bad to get to the states. Hop on the CAT! ZOOOOM!
IM me and I'll drop by and pick up a spare turbo.
Do you have any K24 oil return lines?
Do you have injector lines for 86 TD?
