Engine Specific Info and Questions => IDI Engine => Topic started by: Turbinepowered on July 08, 2007, 03:12:57 pm
Title: Cam regrind... for efficiency?
Post by: Turbinepowered on July 08, 2007, 03:12:57 pm
Okay, so, I'm toying with the idea of having a cam made up to make a Miller cycle 1.6TD. Basically, making the cam such that the effective compression ratio of the engine is down there in the 18.5:1 or so range, but leaving the head, head gasket, and swirl chamber volume all stock.
I figure this way I can run the higher boost pressures without blowing out the headgasket, but at the same time I get the full 22.5:1 expansion ratio, which should increase thermal efficiency.
Crazy, cool, stupid? Whatcha guys think?
Post by: burn_your_money on July 08, 2007, 08:22:21 pm
What's a Miller cycle?
Post by: Turbinepowered on July 08, 2007, 08:50:33 pm
Miller cycle is a modification from the Atkinson cycle, which was developed as a four stroke cycle that had a low compression ratio but a high expansion ratio.
Atkinson cycle accomplishes this by holding the intake valve open during the first part of the compression stroke to effectively reduce swept volume, reducing compression. Miller cycle does the same thing, but uses either a super or turbocharger to make up for the lost air(and fuel) volume. A tall expansion ratio allows for better utilization of the heat-expansion of the spent air-fuel mixture, and a low comression ratio gives lower peak pressures and less chance of detonation in a spark ignition engine (Lower peak pressures for us).
Doing something like this should lower EGTs and increase the thermal and fuel efficiency of the engine, with a small hit to low-end power before the turbo spools up. Coupled with a VNT controlled properly, you probably wouldn't even notice that bit of low end lag. I think.
Post by: lyeinyoureye on July 08, 2007, 09:39:44 pm
I bet you'd see a near TDI BSFC map with a cam like that and a properly setup variable vane turbo. The only problem I can think of would be harder starting in the cold. Would the valve staying open that long imply more risk in terms of interference?
Post by: rabbid79 on July 08, 2007, 09:45:48 pm
Very cool.  Didn't Mitsubishi use it in one of their cars in the mid 90's?
Post by: lyeinyoureye on July 08, 2007, 09:52:14 pm
Yep, and they're bringing it back (http://www.autoblog.com/2007/05/31/mazda-develops-new-na-1-3l-miller-cycle-engine-for-mazda2-demio/) now.
Post by: Turbinepowered on July 08, 2007, 11:34:45 pm
Quote from: "lyeinyoureye"
I don't think it'll cause interference; wouldn't it just be staying open an extra couple of degrees crankshaft?
Anywho, I was planning on combating the cold starting issue by adding an intake preheater screen, like come on come Cummins direct injection industrial and heavy duty engines. Basically it would preheat the air, then the air would further be helped by the glow plugs. Might need to cycle them a couple times, but it should fire up.
Post by: Turbinepowered on July 08, 2007, 11:51:56 pm
Perhaps to add a bit more clarity, this engine would be effectively a dual cycle Atkinson/Miller engine. At low RPMs and before the turbo spools, the engine would be running on the Atkinson cycle. Once the turbo begins to produce boost, the effect is the same as a Miller cycle engine, minus the power-robbing belt-driven supercharger.
Might also make for an excellent candidate for a dual turbo system, pairing an ultra-small turbocharger (K03 or smaller, I'm thinking) with something more in the K24 range, or maybe something like a VNT-XX on the big end. Because of the decrease in effective swept volume on the intake while running without boost, the turbocharger I expect will be harder to spool up. Running duals would allow me to size a super-small version and add in a larger turbo to give it's grunt later on.
Post by: ezekiel on July 09, 2007, 12:37:57 am
interesting...
Post by: burn_your_money on July 09, 2007, 08:11:03 am
Thanks for the explaination.
If you have a healthy engine I don't think you'll have a problem with cold starts 90% of the time.
I think you should go for it, I'd be interested in one if it works although maybe less duration since I'd be running a K14
Post by: Turbinepowered on July 09, 2007, 09:45:23 am
Seems the consensus is to try it, so now I just need to see who I can get to grind up this lovely little gem, and for how much.
I guess it's time to contact some of our excellent vendors, particularly the ones that advertise custom performance cams.
I'm planning on putting this into a fully rebuilt engine, honed with probably some total seal rings, fresh valves, new nozzles in the injectors, and obviously things like a new headgasket and headbolts. Might go with studs, not sure yet.
Post by: burn_your_money on July 09, 2007, 09:51:04 am
Right on. Please keep us posted
Post by: Darth Garry on July 09, 2007, 10:28:33 am
Sounds like a neat project to me.
My only question would be why not try putting it into a currently running engine first?  If you have a motor that you know is going to run a certain way, you will be albe to change the cam and measure the difference.
If you put it in a freshly rebuilt engine, it may be more difficult to gauge the difference that this cam will make.
I'm real interested to hear how it turns out though, either way.
Garry
Post by: Turbinepowered on July 09, 2007, 10:46:32 am
Quote from: "Darth Garry"
Oh I'm keeping the stock TD cam as well, for comparison; the engine needs a rebuild, both because it was in a front end collision and because it had some blowby issues on a couple cylinders. Might as well do the whole thing while it's not in a car, you know?
I figure I'll get the Miller/Atkinson cam ground from a fresh blank, so I can swap back and forth between stock and modified. Probably going to go looking for a dyno in my area, to get it down on paper.
Post by: ezekiel on July 09, 2007, 12:06:33 pm
odd that the Mazda2 "Miller-Cycle" engine has no supercharger, making it an Atkinson-Cycle engine, but they're still calling it a Miller-Cycle.
and that the Ford/Mazda and Toyota Hybrids use an Atkinson-Cycle gas engine in their hybrid drivetrains.
knowing that, kinda makes you think the hybrids should be getting even better mileage than they do.
Post by: Turbinepowered on July 09, 2007, 02:26:40 pm
Quote from: "ezekiel"
Yeah, I'm not really sure how they're accomplishing that without a supercharger, since Miller Cycle specifically requires forced induction compensation for the decreased effective swept volume. Maybe they're doing something with resonance in the intake? I don't know much about stuff like that.
Post by: ezekiel on July 09, 2007, 02:49:46 pm
have you thought about, or tried to calculate, the amount of force the engine would have pushing back in that 15-20% of leaving the intake valve open?
like, to figure out what kind of boost pressure you'd need to keep the air in there?
would help with calculating, cause I'm sure I remember VNT turbos making about half a psi at idle,
Post by: jtanguay on July 09, 2007, 05:03:52 pm
wow 54 mpg with a 1.3L engine...  :roll:  why not just get a 1.0L geo and enjoy 70 mpg???  :lol: or splurge and go with a nice 1.9TDI and enjoy 50 some odd mpg with the ability to pass other vehicles...
i think a VNT turbo would be a must for this type of mod on a diesel.
Post by: xud9te on July 10, 2007, 08:24:32 am
Great idea, but what I have never had cleared up to me is what is the difference between a miller (or atkinson) cycle engine and one with a lairy intake cam?
I mean the miller cycle engines use a cam of around, or over 275 degrees, but there are plenty of NA race engines using a longer duration...
Of course the exhaust is open as well for longer giving a through flow as opposed to reverse, but where is the actual borderline? Is it just numbers or is there a mechanical (or thermodynamic) difference that I am missing?
In my mind would you not need to first calculate the pressure of the manifold exactly for the supercharging effect of leaving the intake open to make sure you have enough boost pressure to combat?
Also I have never heard of the miller cycle being applied to diesels ever, I assume for the reason already mentioned regarding drop in compression which would seriously hinder starting despite what kind of ane way system is used...
Post by: Turbinepowered on July 10, 2007, 10:18:41 am
Quote from: "xud9te"
Don't know if I'm familiar with the lairy intake cam terminology; clarify please?
I believe the difference is that Miller/Atkinson doesn't do anything for the exhaust valve timing or duration; they are purely intake-valve oriented changes, with a typical exhaust duration and timing. And a naturally aspirated engine would be Atkinson; Miller requires some kind of forced induction (Unless you're Mazda, apparently, with a forced induction-less Miller... somehow...).
I'm a little slow today perhaps, but what do you mean by the "supercharging effect of leaving the intake valve open," precisely? I am under the impression that the purpose of leaving the valve open is to reduce the effective volume of the air charge within the cylinder, thereby lowering the compression ratio while keeping a taller expansion ratio. And that any forced induction is simply there to restore the lost power of the smaller charge-air volume by increasing its pressure and density.
I'm also not sure what you mean by combatting boost pressure; do you mean calculating your manifold pressure so you know how much boost pressure you need to compensate for the loss of volume?
I think really that the advances in direct injection technology have helped any problems that would arise from the lower compression in starting. Intake air heaters, pilot injections, and better placement of in-cylinder glowplugs could all be applied to in indirect injection engine, or a direct injection engine with a high compression ratio.
I think that Miller, and even Atkinson, can be applied to a diesel by bringing its compression/expansion ratio back up into the twenties, but using the Miller or Atkinson cam to drop the compression back down into the 18.x range while leaving the expansion ratio the full 20.x or whatever it is designed to be.
Post by: xud9te on July 10, 2007, 10:53:58 am
Sorry, by 'lairy' i mean long duration (not high lift), i.e. miller cycle engines have an intake cam of larger than 275 degrees duration.
Yes, i think i answered my own question in that the miller cycle engine relies on only intake cam changes in duration.
Mazdas miller cylce always uses a supercharger, in fact i know of only one production car engine, as fitted to the mazda xedos, that uses this cycle and is definately supercharged (although at a guess check out the mazda 626 supercharged diesel in case it uses the miller cycle of a form).
I understand the miller cycle in a different way perhaps: the forced air from the late intake cylinder provides a pressurised charge to the plenum for the next cylinder to open, helping the worst part of cylinder filling, and the supercharger offsets this in order that no air flow passes a certain point in the intake tract.
Of course this offest of positive manifold pressure must be constant, hence why all miller cycles use a supercharger that provides constant boost (not an exhaust driven one).  Other wise you would have very little effective compression ratio at low turbocharger speeds (and no power).
Maybe the main reason this technology has not been applied to diesels yet (or has it?) is that mechanical supercharging and diesel torque production are just two ways of skinning a cat??
Post by: Turbinepowered on July 10, 2007, 03:25:27 pm
Apparently the new Mazda engine, linked to earlier, doesn have a supercharger. According to the article, at least.
I'll be perfectly honest with you, I have never heard it explained that way. And at least to my way of thinking, if that were the case then an Atkinson cycle engine with no such forced induction would barely run.
I also haven't heard that all Miller cams have to run 275 crank degrees of duration. I'm assuming you're referring to crank degrees, because 275 cam degrees would nearly two complete rotations of the crank... I would imagine that the extra duration would depend on how much air you wanted to force back out. Close it a little late for a little air out, a lot late for a lot.
A quick peruse around the web... and most of the Miller cycle engines I could find were running about 240-250 degrees of intake duration.
Miller Cycle isn't mean to produce more torque, it's meant to reduce fuel economy. Not really sure what you mean by comparing mechanical supercharging and a diesel's torque advantage from longer strokes and constant pressure combustion.
Post by: lyeinyoureye on July 11, 2007, 12:38:37 am
After posting something similar on another board, the exhaust valve timing was brought to my attention. I'm not sure what you consider to be an acceptable level of peak power, or if the cam's profile would even benefit, but insuring the exhaust valves don't open too soon may allow the engine to extract more from the power stroke at lower loads/speeds. Even though the IDI diesel is fairly efficient at anything above about half load, it's efficiency below that really bites.
In terms of startups, I'm not sure if a grid heater would help all that much, since they tend to be used in applications with lower CR that don't need glow plugs persay. I mean, it'd help, but imo a block heater would also be a good addition.
Post by: Turbinepowered on July 11, 2007, 10:44:06 am
My goal for this is only a mere hundred horsepower, though I'd live just fine with ninety or so. I could probably even live with seventy five, but isn't that below stock TD power anyway?
Only application I'm familiar with grid heaters in is on the Cummins bus engines, and I think they run at 18:1 and ditched the glow plugs in favor of a four-valve head and centralized common rail injection. I figure it can't hurt, especially if I put it in a special "cold start" bypass air intake.
Post by: jtanguay on July 11, 2007, 12:21:49 pm
would be nice if you could get a propane heater and send the fumes downstream to heat things up.  electric heat is okay, but propane would give you the BTU's to start relatively quickly.  now making it safe is a whole different story!
Post by: Turbinepowered on July 11, 2007, 05:31:47 pm
Quote from: "jtanguay"
Indeed, and plus that would just add a fuel to worry about topping off.
I've toyed with having an insulated coolant reservoir like the Prius does, but I don't think I want that added complexity either. So block heater, intake grid/intercooler bypass, and really, really good compression will be my starting aids, I think.
