General Information => General => Topic started by: firestorm13666 on June 23, 2007, 04:05:54 pm
Title: Found a 82 diesel in a yard
Post by: firestorm13666 on June 23, 2007, 04:05:54 pm
I was geting parts for a friends car and we looked around the yard to see what all the had.I saw a few old rabbits and one was a diesel.It was 82 and the Vin starts with 1.The injection pump and injectors are long gone but the rest is there.So what would be some parts to get from it if i can?Thanks
Post by: RabbitJockey on June 23, 2007, 07:49:09 pm
the only thing i almost always swipe from cars like that is the glow plug relay since they're 50 bucks a pop.
Post by: firestorm13666 on June 23, 2007, 11:24:42 pm
The reason why i am asking is two fold.I have a 1986 MK2 Golf,and would like to get whatever useful parts i can.The other being i would love to have a MK1 with a diesel and knowing that if i do with a MK1 i can't be picket about diesel or not i would like to get the parts that make it a diesel so i could swap one in a MK1 if i do get it.Also how good are the fuel filter setup on the Mk1 compared to the MK2?Thanks
Post by: bevboyy on June 24, 2007, 07:09:13 am
Take the head off it. if the cylinder walls look ok, and the engine turns over by hand, take the engine.
Post by: burn_your_money on June 24, 2007, 08:05:34 am
Take the cluster
I think the fuel filter is just as good as the mk2 setup but I don't know for sure
Post by: RabbitJockey on June 24, 2007, 09:46:03 am
the mk1 setup is better, but only because the filters for it are like 10 dollars cheaper haha.
Post by: firestorm13666 on June 24, 2007, 11:16:31 am
So none of the wiring would be worth taking?Also it did have a non a/c braket :D .Anymore advice would be grate thanks.
Post by: bevboyy on June 24, 2007, 12:14:48 pm
depend on what you want to wire up. If you are planning to drop the diesel into a gasser shell, then as long at they are both ce1, ok, otherwise, just pull the relays...
Post by: firestorm13666 on June 24, 2007, 11:06:13 pm
Sorry if i was not clear in my last post.I ment that i would like to have MK1 and know that finding a clean one is getting harder to find and if i do find one it might not be a diesel.This is why i asked about the wiring.Also what is CE1?Thanks
Post by: ODwyerPW on July 09, 2007, 07:53:27 pm
If it has good plastic navy blue window cranks...take them.   they are tough to find.
If it has good navy blue trunk carpet..take it and sell it to me.
