Engine Specific Info and Questions => IDI Engine => Topic started by: rallydiesel on June 15, 2007, 07:39:15 pm
Title: Simple way to remove exhaust clamps?
Post by: rallydiesel on June 15, 2007, 07:39:15 pm
I am going to be pulling our 1.6 TD's engine for the first time and want to know how you guys remove the C clamps on the down pipe? Could I just use a couple curved rods to lever them open or do I need a special tool?
Post by: Fisher on June 15, 2007, 07:43:52 pm
Getting them off is easy, you can just stick a screw driver into the hole in one end and pry them off, watch your face when you do it.  Getting them back on is the hard part.
Post by: burn_your_money on June 15, 2007, 08:31:04 pm
For removal I used to pry them off with a ratchet or screwdriver, whatever was handy.
Now I use this
(http://img.photobucket.com/albums/v603/burnyourmoney/exhaust.jpg)
worth it's weight in gold
If you need tips for installation without the tool just ask
Post by: Vincent Waldon on June 15, 2007, 08:44:10 pm
Some one has to say it:   search for "exhaust clamp" here and on www.vwdieselparts.com and you'll find pictures of various home made tools and lots of discussion.
Post by: foxracer1 on June 15, 2007, 10:54:51 pm
take an exhaust clamp and put the nuts on the u bolt. then put the saddle backwards on the ubolt stick in the c clamp and back the nuts off of the u bolt forcing the c clamp apart. a 1.75" or 2" clamp works
Post by: Darth Garry on June 16, 2007, 07:59:32 am
With a pair of these wedges, they become a former-pain-in-the-ass exhaust clamps as with the wedges, it becomes a 2 minute process.
These wedges can be made by anyone with some flat steel stock and a way to cut it and a grinder.
First the photos:
(http://www.notinteresting.com/photoalbum/050305truckdoza/P3050018.JPG)
Here are the wedges in action holding the springs open.
(http://www.notinteresting.com/photoalbum/050305truckdoza/P3050016.JPG)
Here's the part number of the big one.  I don't know if it's something you can still order, but it is a genuine VW/Audi part.  My dad got a few sets when he worked at the dealership.
So, how do you use these, you ask?
It's simple, and doesen't involve messing around with prybars, weird u bolt openers, or the weird clamp opening tool.  Here's what you need:
EYE PROTECTION!  You are forcing these springs open.  I made the mistake of dropping one once, and there is enough force to send the spring flying.  It flew at me and took a large chunk out of my eyeglasses.  I can't stress this strongly enough!
Your wedges.
A set of channel lock pliers.
2 minutes.
1)  Take the big wedge and jam it into the C clip as far as you can.
2)  Take your channel lock pliers and adjust them to get a good grip on the downpipe.
3)  Rotate the downpipe with the pliers as to force the C clip open further
4)  Jam the wedge in as far as it will go.
5)  Repeat a few times until you have the C clip open pretty far.
6)  Rotate the pipe the opposite direction.  There should be sufficient space to get the C clip off of the exhaust pipe.
Do the same for the other side, and your exhaust is off!
To put them back on, put the wedged C clip in place, and rotate the downpipe as to open up the C clip enough to get the wedge out.  Repeat.  Done.
If the exhaust clips are going to be off for a while, it is best to take the C clips out of the wedges so they don't get stretched out.
I hope this helps, and maybe will save some of you guys some time.  Maybe someone on here could even market the things.
Garry
Post by: BellCityDubber on June 16, 2007, 08:43:44 am
Quote from: "foxracer1"
this is the way I've always done it
Post by: CoolAirVw on June 16, 2007, 12:07:49 pm
Aqui esta.
(http://img57.imageshack.us/img57/3751/exhaustspringclipexhaustclampt.th.jpg) (http://img57.imageshack.us/my.php?image=exhaustspringclipexhaustclampt.jpg)
Post by: saurkraut on June 18, 2007, 02:22:32 pm
Muffler clamps are the best.  2.5"  Especiall on the TDs.  Muffler clamps fit in there better than the purpose built tools.
Post by: Black Smokin' Diesel on June 18, 2007, 06:13:28 pm
IMO using any tool and any trick in the world, it's still a PITA to do. The exhaust clam trick works good but it's a PITA to work with when removing the passenger side clamp.
