General Information => Troubleshooting => Topic started by: Mattg on May 31, 2007, 07:28:20 pm
When I bought is 94 golf this sensor was broken off the drivers side of the block. I have no idea what sensor it is anyone know?
if it is on the head then I beleive it is an oil pressure switch. A picture will help
How do you post a pic?[/img]
It has to be on the net already. Then click the img button, paste the link, click the img button again.
there are services like photobucket and flickr that can help. They will host your picture you give them on the net.
ok so lets try this here's a pic of the side of the engine you can see the broken senor in side of the head.
(http://s111.photobucket.com/albums/n155/matthewg_02/House/100_0625.jpg)
That's the low oil pressure sensor... the blue wire with the black boot that's dangling plugs into it.
Real cheap to replace, even if you have to buy it at a dealer, and the result of low oil pressure can be really expensive !!!
Just checked $20 at Piston Ring. Thanks
Just checked...$3.68 at Python Parts.com
(Part #P4030-33683)
Just to be super clear, there are two oil pressure sensors (that look pretty much the same)... a "high pressure" one on the oil filter flange, and a "low pressure" one on the head.
You want the "low pressure" one. And, they are slightly different depending on if yours is a turbo or not. You want the turbo one.
