Engine Specific Info and Questions => IDI Engine => Topic started by: the4ork on May 31, 2007, 04:20:26 am
Title: adding aba oil squirters to 1.6 n/a block
Post by: the4ork on May 31, 2007, 04:20:26 am
can i do this? i should be able to just tap them in right?
i got a blown aba block that i can yank the quirters out of... then just throw in some oversized TD pistons and i should be good to go  :wink:
Post by: Justin on May 31, 2007, 12:30:38 pm
should be able to, I would just take in both blocks to the machine shop so that they can get the proper location  in the block. its pretty much what VW did on all of the turbo blocks, and I could be wrong but I think that the only difference between turbo and non turbo blocks are in fact the oil squirters.
later
Justin
Post by: tylernt on May 31, 2007, 07:06:13 pm
I've heard it said many times that oil squirters can be added to a block but I don't know that anyone has come back and reported success or failure... so please, if you do this, let us know how it works.  :)
Post by: Audi80 on May 31, 2007, 11:47:32 pm
I´ve done it. We machined squirter places flat and drilled holes. Works fine. I used TD squirters.
Post by: tylernt on June 01, 2007, 06:57:02 am
Quote from: "Audi80"
8)
Post by: subsonic on June 01, 2007, 11:06:08 am
Quote from: libbybapa
IIRC the gasser squirters squirt at a different pressure than the diesel ones (premature? :lol: ).
Andrew
They have a cream for that now :lol:   :lol:  :lol:
Post by: Tony2ltr on January 05, 2009, 07:00:16 pm
I am considering doing this becuase I just put the older turbo on an NA engine, but the NA pistons don't have the notches cut out of the skirts. I was just thinking of drilling and tapping for a pipe thread/compression fitting and small tubing that I could bend to shape and then crush the end down for the desired squirt.
What do you think?
-Tony
Post by: Tony2ltr on January 06, 2009, 06:20:46 pm
no kidding?  I never looked at one closely.  I have a TD block, I will take one off and look at it tomorrow.  The only reason I didn't think they would work on a Naturally Aspirated block, is that the Turbo pistons have a notch cut out on the skirt for them.  Maybe I can just modify them and extend the little tubes and make them more of a "U" shape.
I would have nver thought they had little valves in them. Thanks!
-tony
Post by: jtanguay on January 06, 2009, 07:27:05 pm
(http://img340.imageshack.us/img340/8259/oiljetyb6.jpg)
Post by: blkboostedtruck on January 06, 2009, 07:52:48 pm
oh JT
that picture turns me on! :twisted:
L.O.L. Duane :roll:
Post by: jtanguay on January 06, 2009, 08:32:54 pm
Quote from: "blkboostedtruck"
oh JT
L.O.L. Duane :roll:
 :lol:
Post by: VW_Commuter on January 06, 2009, 08:38:19 pm
oh JT
L.O.L. Duane :roll:
ROFLMAO
Post by: Tony2ltr on January 07, 2009, 05:04:54 am
Yeah Baby! Great pic! where in the world did you find that? Why has the footnote been altered to read 1.5 bar instead of 3 bar?
-Tony
Post by: jtanguay on January 07, 2009, 09:28:13 am
Quote from: "Tony2ltr"
-Tony
i found an old turbo diesel pdf of a vag manual.  it has the reasoning of why VW/AUDI added turbochargers to their diesel engines.
no clue why they put 1.5 bar from 3 bar...
by chance, does anyone know what the idle oil pressure should be at?  i'm getting 15 psi with the bypass filter and the buzzer isn't coming on... i should be good right? (my oil squirters won't be squirting at idle  :()
Post by: Tony2ltr on January 07, 2009, 11:50:51 am
I believe the part number may be in the now out of print catalogue:
 "2009 FIND OLD JUNK AND TAKE IT APART 1.6"
LOL :lol:
-Tony
Post by: Tony2ltr on January 07, 2009, 06:01:04 pm
That is great, i'll see if the local VW dealer has them or can get them.
