General Information => General => Topic started by: rallydiesel on May 16, 2007, 11:32:42 am
Title: Question on timing belt replacement
Post by: rallydiesel on May 16, 2007, 11:32:42 am
In my Bentley manual it says to loosen the camshaft sprocket and tap it free from the camshaft with a rubber mallet. Yet in the timing belt how-to on the VWdieselparts webpage it doesn't mention having to do this.
My question is, do I have to loosen the cam sprocket or can the belt be properly tensioned between the cam and the IP without this by just sliding the belt onto the sprockets?
Post by: Vincent Waldon on May 16, 2007, 11:54:02 am
One's a "just replace the timing belt" thing and one's a "actually set the timing" thing.
If your timing is perfect.... cam is exactly in the right spot at TDC etc and all you need to do is put a new belt on then you quite often will not have to loosen the camshaft sprocket... the new belt may just slide into place and not move when you tension it.
If you want to replace the belt *and* make sure you have perfect timing then you go for the full-meal-deal proceedure... Engine at TDC, lock the cam and pump, break the cam sprocket free, install the belt, tension, tighten the cam sprocket, remove the locks, set the pump timing with the dial gauge.
So, both instructions are correct, just talking about slight different things.
Post by: rallydiesel on May 16, 2007, 07:17:13 pm
Got it, thanks.
Post by: jackbombay on May 16, 2007, 08:43:57 pm
Quote from: "Vincent Waldon"
  I leave the cam shaft lock in place when I turn the pump so  the engine/cam doesn't move from TDC, fwiw.
Post by: 6011 on May 17, 2007, 12:09:08 am
Sorry to hijack but, do most people use correct VW tools for this procedure, or do you use a (3/16?) piece of flat bar for the cam shaft and a (what size?) cylindrical thing to lock the pump pulley?
Post by: jimfoo on May 17, 2007, 07:51:39 am
I used the correct tools.
Post by: burn_your_money on May 17, 2007, 03:14:20 pm
I only use the dial indicator, everything else is the "incorrect parts" It all gets the job done
Post by: Vincent Waldon on May 17, 2007, 03:47:11 pm
Quote from: jackbombay
Quote from: Vincent Waldon
Yeah, now that I think of it, me too !!
Just don't leave any of the locks in place when starting it for the first time !!
To the other poster:  I use a "real" dial gauge and adapter, milled a cam lock so that I don't need any silly feeler gauges, and turned the pump lock on a lathe... of them all the pump lock is the least critical imho.
Some people use a stick and feeler gauges instead of the dial gauge... what would McGyver do I wonder ??!!
