For Sale/Looking For => Parts for Sale/Wanted => Topic started by: bigblockchev on May 08, 2007, 05:49:37 pm
Title: WTB AAZ std bore piston or two, good used ok
Post by: bigblockchev on May 08, 2007, 05:49:37 pm
I have one really bad piston and another that would be nice to replace. Has anyone done a rebore & have their old slugs sitting gathering dust i could put them to use and a few bux in you pocket. Thanks all Dan
Post by: dirtydiesel on May 12, 2007, 06:55:24 am
i have all 4 pistons. good shape bored engine O\S don't need anymore
Title: AAZ pistons
Post by: bigblockchev on May 12, 2007, 08:24:05 pm
I Pm'd you. I'm interested in the set My email is [email protected] thanks Dan Minchin
Post by: dirtydiesel on May 13, 2007, 06:20:51 am
will do Dan gimme a week ok
will email you
Title: Scary stuff oil pressure loss
Post by: bigblockchev on May 15, 2007, 07:46:15 pm
I see that you are having your own scary times with oil pressure loss. I had my oil light come on last year but I ended up getting a new oil pump. Also had a bit of a discussion with a knowledgeable fellow about replacing worn intermediate shaft bearings , a known  issue with high mileage engines which mine is. Good luck Dan
Post by: dirtydiesel on May 24, 2007, 05:38:27 pm
hey the oil pressure problem was a water pump bolt. It had backed out of the housing and jammed the inter shaft. i was very lucky.
