Engine Specific Info and Questions => IDI Engine => Topic started by: Black Smokin' Diesel on May 03, 2007, 03:53:23 pm
So I bought a set of mercedes injectors said to be from a turbo engine (so they should be 155bar units). As it turns out, it's stamped 135bar on the injector bodies.
They have about 70k on them and look brand new. I'd like to know if I can use them on my 1.6TD. TD injectors are rated 155bar.
you could.. you might see a bit more smoke though for the extra fuel and less pressure. if the nozzles have 70k km's you might want to consider fresh nozzles...
I've run the VW NA 135 bar injectors in my 1.6TD when my source was temporarly out of new injectors.
The low end was smoother, and the top end was noticeably less.
Being its the same nozzle and pintle, just thicker shims, what I was feeling in performance terms was retarded timing.
With those Mercedes injectors, you'll be getting more fruel, and retarded timing.
Might want to get them reshimmed to 155 bar.
How much would a re-shim be?
problem is.. will the springs handle the extra pressure? smog said that n/a springs can bind...
wouldn't decreased break pressure advance the timing? since they open earlier because the pressure is reached sooner?
OR, you can set the injection timing to the n/a spec and end up with better flow and reduced pumping losses.
Andrew
Now that's the kind of option my budget can deal with. I'll get everything back together and have it timed by a shop (unless I can find someone local to me with proper equipement).
Thanks a lot guys!
One last question, how the hell do you make the pre-combustion chambers stick to the head when re-installing it? Two of them just keep sliding out :?
put some grease on them or something?
I go no meng maybe some tape
And I bought a new head because the shop told me it was toast since one of mine would fall out? :evil: Guess I have a spare head now.
maybe time for a new shop? :lol:
This is supposed to be THE head shop in Denver. Maybe he doesn't do many VW Diesels. Well, since the IDI wasn't imported here, I can bet on it.
Peen the edge in 3 places.
Not sure I understand what you mean.
Remove pre cup, take center punch and make a mark on the inside of the head where the pre cup sits, hit the side of the area where the precup is supose to sit against. Do this on at least 3 opposing angles and then the precup will need to be taped in place to get it in.
Another term would be swedging. What your doing is deforming the metal in small areas around the precup so the deformed (swedged) metal will cause friction on the sides of the precup. This is inside the head not on the out side/ cumbustion chamber area. Although that may work as well.
Does that make sense at all?
Yes is makes sense :D Thanks a lot!
sorry to use your topic but i also have a question related diesel injectors.
i heard about mercedes injectors...what are the beneits of replace by merc ones? wont the car make more smoke at low rpm?
i saw this:
Edited by moderator (reduced URL size):
EBAY LINK (http://cgi.ebay.de/Einspritzduese-VAG-VW-z-B-T3-Golf-uva-DN0SD297-f-Poel_W0QQitemZ200106901081QQihZ010QQcategoryZ61258QQrdZ1QQcmdZViewItem)
whats is that he his selling?he also have the same kits for vw 1.6 and i am in need of injectors freshen up.
should i go for it?
should i go for it?
Seems to me that they are generic nozzles, probably aftermarket ones. I'd avoid and find genuine Bosch nozzles.
Merc injectors have more flow than vw injectors. I've heard on a 60% increase but I could be wrong. If you're not modding the engine stick with VW nozzles, they are cheaper than mercedes nozzles.
i need to do something to the injectors, at cold strats the car makes a lot of noise...
also at the last visit to the pump shop to clean the injectors they told me that they were at the end of they´re life...
what do i need to rebuild them?
would this be enough?
edited by moderator: shortened URL:
EBAY LINK (http://tinyurl.com/2o3ycz)
edit:i have more fuel,reshaped lda pin,kkk24 at 2bar at 4500rpm(closed WG) and planing on doing larger exhaust and governor mod.
the kit that are in the links are the same price so should i go for any of them?
sorry for all the Q... :oops:
I do what Andrew is explaining, with the precup out I make 4 punches around the diameter of the precup chamber, than I place the precup in its chamber and do another 4 offset from the 4 holes I just made, this should tighten it up plenty :D
sorry... :oops:
what about my question?
edit:how can i make the urls smaller?
thanks to the mods,last time long urls for me 8)
what about the kit in the ebay page?
is all that is needed to freshen my gtd a bit?plug and play right?
i would appreciate the help as i am in nedd of doing this and this kit is a nice find for me(i am from portugal)
black smokin' diesel answered your question
i dont mind os using aftermarket nozzles if they last long as well.
as anyone used some?
suposing i would buy,the kit as everithing right?
