General Information => General => Topic started by: zaprzal on May 02, 2007, 06:11:49 am
Title: hybrid turbo?
Post by: zaprzal on May 02, 2007, 06:11:49 am
I want to build hybrid turbo. Bigger impeller (k26) put into smaller, machined housing (k24). Is it good or bad idea? How does it work if I compare hybrid vs stock turbo?
Post by: RabbitJockey on May 02, 2007, 06:39:54 am
it can be done it's an upgrade... this turbo won't fit on like the stock one, you'll need a spacer for it to fit.   i think when it was discussed before, that it was decided that an aftermarket turbo is a better route, but the k24/k26 hybrid is the cheaper route
Post by: zaprzal on May 02, 2007, 08:09:32 am
what spacer and why?
another question is if this hybrid will be more efficient than stock turbo if I stick with stock small, machined housing?
Post by: RabbitJockey on May 02, 2007, 09:29:46 am
the compressor housing is bigger and won't fit, the spacer would go between the turbo and the manifold, from what i know.  do a search this has been covered before
Post by: zaprzal on May 02, 2007, 09:54:18 am
I want to use stock k24 compressor housing only machined to fit on bigger impeller. What do you think about it?
Post by: jtanguay on May 02, 2007, 10:57:12 am
if you can do it... go for it!  sounds to me like quite a bit of machining though...  make sure you can get it nice and smooth in case the compressor wheel rubs a little bit... but ideally you don't want it to rub at all!
Post by: zaprzal on May 10, 2007, 07:57:13 am
one more question, should I put bigger cold side and stick with stock k24 hotside, or should I also put bigger k26 hotside?
Post by: Audi80 on May 10, 2007, 11:27:02 am
How big is that K26?
Post by: zaprzal on May 10, 2007, 01:27:50 pm
hard to tell. It's from iveco truck 2,8td, probably bigger than mercedes one but who knows
Post by: zaprzal on May 10, 2007, 11:34:45 pm
I'm afraid if stock k24 hotside would make too much exhaust gas pressure  :?
Post by: zaprzal on June 03, 2007, 10:20:32 am
anybody will help? is it better to stick with stock k24 hotside or put something bigger?
Title: .....
Post by: Darkness_is_spreading on June 04, 2007, 04:40:48 pm
No machining required,  you need a complete K26 and K24 turbo.    Take off the compressor side of the K24  down to oil cooler,  then replace with K26 components from that point on: ( flange, compressorwheel,  and K24 nut and K26 housing)
