General Information => Troubleshooting => Topic started by: gamber on April 29, 2007, 09:34:59 pm
Title: Turbo seal / thrust bearing shot?
Post by: gamber on April 29, 2007, 09:34:59 pm
Recently bought a 85 Jetta TD, engine code "H" from the VIN
During my pre-purchase inspection, noticed dirty oil.  Thought, quick oil change and all is good.  Not the case.  I commute 1200 km a week and change the oil weekly.  The oil use is roughly 1 litre / 1000 km, and at these now weekly changes the oil is BLACK.  I am suspecting turbo seal and/or thrust bearing.
Exhaust is clean when warm.  Very little smoking on cold start or acceleration until engine is up to temp.
Am I on the right track?  Any other thoughts here?
Post by: jtanguay on April 29, 2007, 10:40:55 pm
have you ever driven a diesel before???  if you can keep your oil from going black after a week.. hats off to you! (the harder you push your motor, the more black smoke will pour into the oil...)  1L/1000km isn't that bad at all... you will find that the harder you drive, the more oil you burn...
i'm going to be installing a bypass filter on my jetta this summer... filters out the soot!
www.fs2500.com
Post by: Doug on April 30, 2007, 03:52:02 am
Jt's right. Your oil is supposed to be black. That is the detergent package keeping the carbon generated by blowby in suspension where it will not precipitate out to cause problems. It sounds from your description that the engine is performing alright. Leave well enough alone and drive it. Change out the oil every 3000 km or so with a quality diesel rated oil.
Post by: burn_your_money on April 30, 2007, 06:07:08 am
Alot of that oil usage is probably from leaks. I find that if I fill my engine to the top with oil the first half of it is gone within 200 kms, the last half of the dipstick will last at least another 1000 kms though.
As mentioned jet black oil is normal, as soon as I start my car after an oil change it's black
Post by: gamber on April 30, 2007, 08:17:39 pm
Thanks for the input - was paranoid!
Post by: gamber on April 30, 2007, 08:22:53 pm
amazing thing though, each time I change oil, it runs better!  any feed back here?
Suggestions for moderate mods for improved performance?
Love to update the suspension - any ideas?
Post by: burn_your_money on April 30, 2007, 08:30:27 pm
Sounds like you have alot of soot in the system, look into www.AUTO-RX.com I'm planning on buying some soon... maybe even tonight
Post by: QuickTD on April 30, 2007, 09:16:38 pm
Changing oil every 1200km is a recipe for very rapid engine wear. While regular oil changes are required, very frequent changes are not necessarily better and may in fact be harmful. Engine oil does not perform at its best until it has a few thousand km on it. Engine wear is generally highest immediately following an oil change due to factors such as detergent wash and the high total base number or alkalinity of new oil. I would suggest you leave it in at very least 5000km, better still run it for the VW recommended 10000km if your travel is mostly highway miles, your engine and your wallet will thank you.
Post by: jtanguay on April 30, 2007, 11:47:35 pm
check out www.fs2500.com video's.. you will be amazed!  i'm installing one on my  m-TDI! oil change intervals of  25'000km is possible.
the extra performance from the oil is attributed to the fact that there is next to no foreign particles flowing through the oil... remove them, and you can increase mileage, and decrease overall wear on the motor!!
my last oil change wasn't black until i put around 100km on it... good synthetic, and not flogging the engine is the key!!!
i too had to get used to oil turning black fairly quickly when i bought my first diesel... once you go black (oil) you don't go back!  :roll:  :lol:
Post by: Doug on May 01, 2007, 04:08:06 am
Repalce rings and valve guides and you will be amazed that the oil will not be as heavily laden with soot as quickly as before. In fact it seems to stay more or less clean for several hundreds of kilometres.
Post by: gamber on May 17, 2007, 10:36:36 pm
so what is the easiest way to re-ring?  read somewhere that it can be done easily, just cannot find the link again
Post by: Doug on May 18, 2007, 03:29:04 am
I am not sure that there is an easy way or a hard way. Most of the time is spent hunched over the motor assuming that you are doing it in the car. Get a book like the Bentley, read it till you are sick of reading it, then read it again. Break out the tools and start diassembly. With the head off at that mileage make sure that you replace valves and guides. Always hone cylinders with a brush hone. Install new rod bearings as they are cheap. Also replace the glow plugs as they are easily accessible. The last time I left the manifolds and turbo attached to the head so that I did not disturb the gaskets. It is quite a lift to get things back in place but if you had a friend to help it would to go easier. That was the hardest part for me as the slope of the head makes it want to slide back before you get the gasket and bolts positioned properly.
Or you could pay somebody to do it for you.....
Post by: jimfoo on May 18, 2007, 05:55:55 am
Quote from: "Doug"
That's where either using ARP or Raceware studs helps, or cut the heads off a couple of the old head bolts, cut screwdriver slots in them, and thread them in to help position the gasket and head.
Post by: burn_your_money on May 18, 2007, 05:58:22 am
Quote from: "jimfoo"
Just be carefull not to gouge/scratch the head when you are lining everything up.
Post by: Doug on May 18, 2007, 07:58:58 am
I believe that the Bentley suggests using wooden dowels inserted into the bolt holes in the block to assist in the alignment. This is the same idea as the head bolts cut off and slotted on the top. This works if the head is stripped of manifolds and turbo. I found this did not work well for me because of the height that the head had to be lifted to with a full arm extension in order to reach into the engine compartment. This would be a lot easier with a second person assisting. With a new head gasket and the surfaces clean and dry it is possible to gently move the gasket and head  around until the holes line up correctly. If I did it with success then you can too.
Post by: stewardc on May 18, 2007, 09:22:46 am
There's actually a guy here http://www.vwdieselparts.com/forum/viewtopic.php?t=4868 who claims his diesel Rabbit will keep the oil clean for over 5000km. He's running super lean and it must be a real pig to drive.
Post by: Doug on May 18, 2007, 11:02:09 am
Hey buddy, you wanna buy a bridge?
Post by: stewardc on May 18, 2007, 11:13:13 am
Quote from: Doug
My thoughts exactly, but there are a number there who claim he does it. I think it's a huge sham. :?
Post by: Doug on May 18, 2007, 03:58:07 pm
Think about the SMART car with its modern 3 cylinder diesel massaged to the max, lighter than a rabbit and it manages to yield about 75 mpg. Now why would you believe some knob writing in pigeon English but still literate enough to use a computer? What is wrong with this picture? As P.T. Barnum said "There is a sucker born every minute". It seems that as soon as someone puts something in writing the suckers are lining up to believe what ever it says no matter how impossible. That is your editorial for today!
Post by: jtanguay on May 18, 2007, 07:05:41 pm
it's not possible to run a zero soot diesel... yet anyways...
thats why i opt for a bypass filter! many people believe changing the oil at 5k intervals will save their engine... little do they know that the oil's life could be around 15'000km or more depending on driving.  the main reason oil must be changed is the soot contamination.
lol doug... i'll take a bridge!  :roll:
Post by: burn_your_money on May 18, 2007, 07:14:44 pm
I get about 66 MPG in my mk2 Jetta... Imperial of course
BTW I want a bridge too
Post by: jtanguay on May 18, 2007, 11:37:33 pm
i'm just amazed at how the smart car only gets 75 mpg...
Post by: stewardc on May 19, 2007, 03:18:10 am
Quote from: jtanguay
Especially when the guy in the "clean oil Rabbit" gets 120 mpg  :roll:
Post by: Doug on May 19, 2007, 04:28:17 am
I think that is a general average from what I have heard from the few locals. Maybe they do better like Tyler's Jetta (66mpg, that is amazing!) with a 100 mile downhill and a 50mph tailwind. Somebody was recently claiming that a trip to N. Carolina and back!! cost only $47 for fuel. I find that a strech unless they were able to buy incredibly cheap diesel somewhere. It is for sure that here at about a dollar a litre you couldn't do it. That would be 2000 kilometres/ approx. 1200 miles on 10+ gallons??? I don't think so! Probably lucked into some cheap diesel in Pennsylvania or West Virginia where taxes are less than here. No doubt they were idling the engine at just over 50 mph too.
Post by: Kudagra on May 19, 2007, 08:33:39 am
That Hagar guy needs to go back and learn grammer. It pains me to read his stuff. Too disjointed.
Post by: jtanguay on May 19, 2007, 07:51:12 pm
give me a 6 speed transmission for a 1.6TD... and we'll see how much mileage that thing gets...
120 mpg is absolutely ridiculous... i've heard of 70mpg on an N/A before... but that's it.
maybe if you carbon fiber pretty much everything... take the seats out...
then wax the car for less air friction... (no seriously... that might be worth 1mpg right there...)
