Engine Specific Info and Questions => IDI Engine => Topic started by: b1rdjx88 on March 31, 2007, 09:19:48 pm
Title: Should I pull the head?
Post by: b1rdjx88 on March 31, 2007, 09:19:48 pm
I have just taken the crankshaft out of my 1.9 and it will be machined for the TDI gear this week.
    While pulling the engine I accidentally bumped the number 4 piston (I think) against the valves a couple times.  This happened when I was unbolting the inner CV joints.  I had already taken the timing belt and crank gear off before pulling the engine and I thought the transmission was in neutral when I started wrenching the CV joint bolts...  I Know I know - definitely won't be making that mistake again!
 There was no sharp impact.  I think at most 20ft-lbs would have been applied to the CV bolt while the piston and valve were in contact.
     So should I pull the head to check for a bent valve?  My plan had been to just close up the bottom end with new bearings.  The engine ran quite well just before I tore into it.
Post by: burn_your_money on March 31, 2007, 09:39:44 pm
HG jobs aren't too bad with the engine installed. I'd try it as is and then if the compression is low or it idles really rough I'd pull the head
Post by: rwest1 on April 01, 2007, 07:15:49 am
I strongly doubt that level of valve to head contact would cause a problem. I would finish the lower end rebuild, then hand crank the engine through, checking valve operation/clearance. Unless I found a problem I would close it up and move on. I’ve seen the old 1.5’s that were just starting to chew up the keyway run along making a big doink sound every once in a while (piston hitting valve). If you caught it fast enough you could save the head/valves. Regards
Post by: Wingaman on April 01, 2007, 09:50:17 am
Don't worry about that.
Post by: idgtd on April 01, 2007, 02:02:09 pm
A friend of mine with a VW diesel/samurai conversion had his T-belt jump timing while the engine was idling in his yard. We pulled the head, and no damage was found. The belt had a 14in section with no teeth on it.
Post by: Wingaman on April 01, 2007, 02:59:34 pm
One of mine mecano forgot the lockpin on the pump on a Eurovan 2.4 Diesel (T4) and the cam timing belt slip (not the pump timing belt) when cranking and no damage was found.
We pulled the head for nothing  :roll:
Post by: tylernt on April 01, 2007, 06:18:30 pm
I don't think you could damage the valves with the pistons using hand power if you tried.
Post by: b1rdjx88 on April 02, 2007, 05:44:50 pm
Is that a challenge?!
   Thanks for the reassuring replies.  I will button it up this next weekend and see how it goes.
    Any tips for holding the water pump pulley in place while bolting it back on the pump?  I got it off no problem using two wrenches to loosen two bolts and then wedging a long bar between the two loose bolts and the floor to get the last one, but I don't know if this will work in reverse.
    Also can I get away with using RTV sealant on the old oil pan gasket/baffle or do I need to buy a new ($)  one?
Thanks,
Alan
Post by: burn_your_money on April 02, 2007, 08:56:10 pm
Use one of those BOA straps to hold the pulley, shouldn't have any problems.
The baffles are rubber are they not? That would mean they are reusable
