Engine Specific Info and Questions => IDI Engine => Topic started by: the4ork on March 27, 2007, 10:40:49 pm
so im finishing up my 91 golf daily driver, high comp/ported ect aba swap on standalone....
next is to tackle my 1.6D engine that i bent a valve with (doh)
so im deciding to completely rip the engine apart and build it back together new...
few questions...
head: it will be completely torn apart /w valve job and port/polished.
should i do the work to a TD head? why?
should i spend the extra few bucks for oversized valves? exhaust will be sodium filled.
is their any additional porting i need to do? you guys have any exp. with this?
bottom end: again, fully rebuilt
i think oil squirters are worth it, i have some out of a blown aba, can i use them? how do you install them? is that a machine shop job?
also, forged pistons... i'm going to go with an oversize piston.... should i just get some forged pistons? does anyone sell them? for max performance, should i go with the n/a pistons? arent they higher in compression? and then have them coated?
ARP - im assuming they are made for the diesel as well, and im talking main and head studs, and rod bolts. should be a 20mm pin right? 21mm?
plans im also thingking about...
t3/t4 50trim .48 stg1 on log manifold
3" dp /w 3" side exit
giles pump
head rebuilt /w new valves, ported/polished
bottom end /w oversize
passenger performance cam
front mount IC
any other info you can give me would be great :)
hope this explains it:
(http://img128.imageshack.us/img128/1576/changes4jh5.jpg)
:wink:
