Engine Specific Info and Questions => IDI Engine => Topic started by: jasonsansfleece on March 17, 2007, 07:25:21 pm
I want to build a pump for an eco motor project.
I have the original pump and a 88 jetta n/a pump with an ADA (read LDA) and a load dependent start of delivery device (LFB)
The ADA could be fitted to either pump.
I have a basic understanding of how the LFB works from the Bosch book but not the finer points.
Would the LFB be desirable in a pump that was set up to push fuel with ones foot down?
Which pump shall I reseal and modify?
I was hoping for 15lbs boost from a intercooled KKK14,
Guy
So, no feed back on the LFB pump :?:
Hallo, I would advice a pump of a Bus (code JX), because there´s no need to modify the LDA. Or try to use a JX LDA at your pump.
Jan
