For Sale/Looking For => Parts for Sale/Wanted => Topic started by: burn_your_money on March 13, 2007, 06:34:08 pm
Title: 91 TD part out
Post by: burn_your_money on March 13, 2007, 06:34:08 pm
Complete engine less oil filter flange, head, alternator, cluster, engine wiring and injectors.
1.6l engine
basically 300-400k kms, 300PSI in cylinder #1 and #4, didn't bother to check the others. The car ran ok considering the compression.
4S tranny, only tested in R and 1 - $100
non leaking pump (for now anyways) - $SOLD
turbo - made a whining noise at idle, for parts only - $40
Manifolds - $pending
Turbo lines - $pending
Pan - $pending
Block - $75 Haven't pulled the head so I don't know what overbore if any it's at. Will separate
Intake hoses - everything except the snorkel $40
Massive starter - $10 - wasn't cranking the fastest, very corroded terminals on battery plus I don't know how good the battery was
Interior bits  $very cheap
PS setup - $100 will separate
AC lines/condenser/rad $10 a piece, lines are $5 or free with other AC purchase
Alt bracket - AC or NON $30
Hard injector lines - $25 for the set
If you can think of anything else that is on a TD I have it so just ask
Delivery is available to the GTA+kitchener on March 24/25
Everything sold as-is
Post by: zukgod1 on March 14, 2007, 07:23:22 pm
Dang Tyler, I wish I could find cars like you do.
I think I found a turbo block today, there is a head also. Is there a way to tell a differance between the NA and turbo heads?
Getting closer to needing turbo stuff.
Post by: jtanguay on March 14, 2007, 10:05:14 pm
Quote from: "zukgod1"
what year??? i believe that all hydraulic heads are turbo.  At least the part #'s match up on ETKA...  maybe the earliest hydraulics are not...
Post by: burn_your_money on March 15, 2007, 02:10:37 am
lol most people do, I have 7 TDs right now :lol:  :shock:  :roll:
Move to Canada, it's all I can recommend.
I've heard the 'all hydros are turbo" bit as well, I'd put TD valves in it though because I'd imagine they'd be different
Post by: zukgod1 on March 15, 2007, 07:43:43 am
The only problem I have is the head I have is a hydro and the turbo block I found is not.
I belive I read somewhere you can use a solid lifter head on a hydro block by blocking the oil port, but obviously using a hydro head on a non hydro block just wont work. correct?
Title: Re: 91 TD part out
Post by: Black Smokin' Diesel on March 15, 2007, 04:10:22 pm
I'll take it if it's a K24 with a working wastegate and a good condition compressor wheel.
Post by: burn_your_money on March 16, 2007, 02:01:21 am
That combination won't work unfortunately.
Post by: zukgod1 on March 16, 2007, 10:39:06 am
Quote from: burn_your_money
Quote from: zukgod1
That's exactly what I was getting at Tyler. Non hydro head on a hydro block is fine but the otherway isnt feasable.
Post by: Slave2School on March 16, 2007, 11:03:02 am
Is it a 1.9TD?  I'm looking for a cheap cam that isn't too worn.  I'd like experiment with one in my TDI at some point since I don't think a custom one is in the books after the new pump/lifters/starter I just bled for.
Post by: burn_your_money on March 16, 2007, 12:22:04 pm
It is a 1.6. I'll hopefully be getting to my 1.9 later this month
Post by: bernefj60 on March 16, 2007, 04:17:52 pm
hit me offline for details on the lot.
Rob
Post by: zukgod1 on March 16, 2007, 07:04:45 pm
do the 1.9 manifolds fit the 1.6 heads?
Post by: burn_your_money on March 17, 2007, 09:43:03 am
Yes and no. They bolt up but the intake manifold on the 1.9s are D shaped and the 1.6s are 0 shaped. I've heard the 1.9 intake is an upgrade for the 1.6 but who knows. The exhaust manifolds are the same
Post by: burn_your_money on March 17, 2007, 10:58:40 am
I've never heard any success stories for hydro heads on solid blocks
Post by: burn_your_money on March 17, 2007, 03:39:49 pm
I  thought that there would be pressure issues for the lifters
Post by: duffer on March 17, 2007, 03:56:30 pm
That's a good point.
 There would be no oil supply to the hydraulic lifters.
  Would you have to change to solid lifters and the valves
  with the longer valve stems?
  Just curious.
Post by: zukgod1 on March 17, 2007, 08:04:58 pm
Quote from: libbybapa
If you plug the extra oil return plugged with an aluminum plug and then get the head surfaced it will work fine with a solid lifter headgasket.  Upgrade the oil pump to 36mm gears.
The solid lifter head on the hydro block is harder to manage IMO.
Andrew
Quote from: zukgod1
Quote from: zukgod1
What am I, the freakin' invisible man???   :lol:  :lol:
The hydro head on the solid lifter block will work fine as I outlined above.
Andrew
WOW!!!!
Sorry dude.
The hydro head will really work on the solid lifer block just by pluging the return in the block and using the solid lifet gasket??
Ok, I'll take a look at it tomorrow. I have a hydro head and a solid block sitting here.
Post by: duffer on March 17, 2007, 11:05:38 pm
Back to "91 TD Part Out"
  This poor guy is trying to sell his parts.
  Car parts, that is.
Post by: burn_your_money on March 18, 2007, 07:11:19 am
Side conversations don't bother me, I learnt something from it all so that's a plus. Everyone knows I'm still selling parts. Thanks for looking out though :)
Post by: burn_your_money on March 19, 2007, 07:08:06 pm
:D
Post by: GolfDraggin on March 21, 2007, 12:25:13 pm
hey, just wondering if you have the turbo inlet tube that goes between the turbo and air filter, i need one for my buds 1.9TDi, he blew the turbo (snapped the shaft) so we put a T3 in it. let me know...
henry
Post by: burn_your_money on March 21, 2007, 01:03:45 pm
I can't even count how many of those things I have. $20 shipped. I'll IM you as well
They are all for 1.6s though so I don't know if they will work
Post by: burn_your_money on March 27, 2007, 08:10:24 am
to the top. I cleaned up my garage 2 days ago, I have like 5 spare air boxes and a ridiculous amount of mk2 timing belt covers (upper, lower, backing)
Make some offers
