Engine Specific Info and Questions => IDI Engine => Topic started by: foxracer1 on March 04, 2007, 04:23:13 pm
Title: VNT turbo
Post by: foxracer1 on March 04, 2007, 04:23:13 pm
I know there are thousands of threads about these but none of them really talk about rebuilding them. A friend of a friend, (you know how that goes) said they have a vnt manifold/turbo that he will sell for for the cost of shipping plus $50. So i ask whats wrong and... the dealer threw a new turbo at his moms car because of a fault code. He said it worked before they replaced it. It didn't fix the problem so they threw more parts at it and fixed the problem later on. He said the "wastegate is stuck" I'm pretty sure its a VNT because its off an 2001 jetta auto TDI. So i feel the vanes are coked up. He also said there is some shaft play but thats all he said.
So can these be rebuilt realtivley easy? If so when i have it apart could i have the manifold/turbine housing, vanes, turbine wheel, compressor housing, compressor wheel, ceramic coated? anything else? I would really like to prevent heat soak in to the intake tract.
Title: VNT 15
Post by: jimfoo on March 04, 2007, 05:31:16 pm
As far as I know, they can be rebuilt. I remember seeing a site where someone also had coked up vanes, and it cleaned up well.  I personally wouldn't  spend the money to ceramic coat it. VNTs are fairly free flowing. Just get a good intercooler.
Title: VNT turbo
Post by: Benjamin on March 05, 2007, 01:39:51 am
there are three important things in my opinion,
the first one is the play on the shaft like every turbo, "much or less" play is just a word...  :wink:
sometimes the vanes stop moving becouse of the dirt from the black smoke, if you clean it, its good again
the last thing is the (most of the times vacium controlled) actuator, they get stuck, but you can rebuild it as well, alltough its not worth it.
my experience in vnt turbo's, after you unbolt the 6 bolts (sometimes more), its not easy to take the turbine off.
i think you allready readed about reclocking (and maybe 4 new drills), to rotate the oil drains in the right direction.
Greetz, Benjamin
Title: VNT turbo
Post by: foxracer1 on March 05, 2007, 07:11:26 am
Thats what i thought about the play and the vanes. Are these ball bearing turbos? I really just want to have the manifold coated to prevent it from transfering heat to the intake.
Title: VNT turbo
Post by: Benjamin on March 05, 2007, 12:56:49 pm
go for a good IC instead of coating, you can go for a cheap plate also between those manifolds, but i think there's not gonna be a big difrence.
BB turbo's always have a "R" in the name, like a GT28RS...
as far as i know there are no OEM VNT turbo's with BB.
Greetz, Benjamin
Title: VNT turbo
Post by: HarryMann on March 12, 2007, 12:35:13 pm
Make a s/s sheet heat-shield for the exhaust manifold, like the JX 1.6 vanagons had (mild steel). 1 ~ 1.2mm s/s is about right to work with provided its not a very hard grade.
This will reduce most of the radiant heat, and also keep heat in the exhaust manifold where it can do most good.
Title: VNT turbo
Post by: HarryMann on March 12, 2007, 07:27:36 pm
(http://wiki.80-90.co.uk/images/JX_EX_MANI_SHLD_01.jpg)
Happy to send some templates over, but this will give you a fair idea...
I'll put some better pics up if you like. Needs a few curves in strange places but basically 3-pieces, top & bottom much the same, needing cutouts to get the manifold nuts on. I shall pop-rivet top/bot plates onto the main side plate with steel or monel pope rivets, but could be screwed I suppose.
Title: VNT turbo
Post by: jtanguay on March 12, 2007, 08:49:07 pm
hmmmm that heat shield would be great!
to prevent any heat soak into the intake manifold, why not get it ceramic coated?  best option imo, and use the exhaust mani heat shield.
The only time i think coating the exhaust manifold would be a good idea, would be with an equal length manifold like dave from PP is creating.  Otherwise you will have one cylinder that will be getting all the heat and probably cook it!
Title: VNT turbo
Post by: HarryMann on March 13, 2007, 09:38:02 am
Yup, s/s not only is highly reflective when polished, but also has a lower thermal conductance than mild-steel...
and yes, very difficult coating the inside of such a rough casting as the std. manifold I would have thought - reliably.
Title: VNT turbo
Post by: foxracer1 on March 13, 2007, 06:35:48 pm
I do have a piece of S/S so i might go that route. I just got pic of the turbo. The center section is busted. The guy tried to dismantle it and broke it some how :evil:  :x . So does any one have a VNT 15 center sec.?
Or even a VNT 17 maybe with a brokin turbine?
Ok so Photobucket is being stubborn and i can'y login so ill ave to get back to you on the pics.
Title: VNT turbo
Post by: foxracer1 on March 14, 2007, 04:26:26 pm
pic 1 (http://i75.photobucket.com/albums/i295/foxracintom/DSCF1031.jpg)
pic 2 (http://i75.photobucket.com/albums/i295/foxracintom/DSCF1028.jpg)
pic 3 (http://i75.photobucket.com/albums/i295/foxracintom/DSCF1025.jpg)
pic 4 (http://i75.photobucket.com/albums/i295/foxracintom/DSCF1026.jpg)
pic 5 (http://i75.photobucket.com/albums/i295/foxracintom/DSCF1024.jpg)
Poor VNT! :evil:
Title: VNT
Post by: jimfoo on March 14, 2007, 09:24:33 pm
Looking at pic #3 I see a GT1749, so you actually have a VNT-17, probably
on a VNT-15 center and manifold.
Title: VNT turbo
Post by: foxracer1 on March 15, 2007, 02:01:05 pm
Really? Well i see that now. It is said to be out of a 99 jetta tdi auto. When i get it i'll look closer. So this is like yours. VNT 15 turbine/VNT17 compressor?
Title: VNT turbo
Post by: jimfoo on March 15, 2007, 04:48:42 pm
Yep, like mine except mine has the k-14 manifold adapted to the 17's exhaust housing.
Title: VNT turbo
Post by: xtremitys on March 17, 2007, 03:35:55 am
i just joined up here purelly bout the VATN , VTN, VTG , etc
I just bought a good GT 25 VTN actually- i'm in Christchurch , NZ . It has the vacuum controller aswell , its complete . but thinking about selling it as i need bigger . I have a 89' SWB toyota landcruiser 4x4 and soon building a tough 4.1 ltr turbo diesel with custom internals , etc , was going to run a 2 X GT25 VTN's - but having a look around i see they are rare as hens teeth and kinda thinking i won't find another . I have seen bigger ones more suitable ( GT30 - 35 ).
Title: VNT turbo
Post by: OM617 on March 17, 2007, 05:35:29 pm
A GT37V used on the Ford Powerstroke and International DT466E's would do well for an engine that size.
Title: VNT turbo
Post by: foxracer1 on March 26, 2007, 06:23:41 pm
:evil:  :x  :evil:  :x  :evil:  :x  :evil:  :x  :evil:  :x
D#$% F$%* S%$#
I bent my turbine shaft! I got to rammy and bent the shaft. So now i need a turbine/shaft, center section and a rebuild kit.
The compressor housing does infact say GT1749V. It says 49 on the inside of comp. outlet. So this means i have a vnt17 compressor, on a factory TDI vnt15 compressor? I guess i need a 15 turbine and a 17 or 15 center section.
Title: Re: VNT turbo
Post by: fatmobile on October 26, 2009, 12:39:57 am
Sooo... does anyone know a place to get one of these rebuilt,..
 or find a new one?
Post by: foxracer1 on October 26, 2009, 04:11:19 pm
I rebuild them!
Post by: Rabbit on Roids on October 27, 2009, 08:25:54 am
where did you source your parts? i need bearings and wheels for my turbo. well, atleast bearings and seals. they are gone.
Post by: foxracer1 on October 27, 2009, 05:57:15 pm
i use G-pop shop they are real good guys. I'd recomend them to everyone.
Post by: fatmobile on October 28, 2009, 09:52:50 pm
I thought I had a spare center section to use while mine is getting rebuilt but it's different.
The other one is about 1/2" too narrow to even fit in the exhaust manifold.
(http://img443.imageshack.us/img443/7057/vnt2different.jpg)
 No holes where there are holes on the VNT-15.
 The vane operating levers are different.
 The compressor wheel is too wide for the bore.
 What kind of VNT is the one on the right?
Post by: fatmobile on October 29, 2009, 08:05:39 pm
The other center section seems to be from a 2004 TDI BEW block.
 Called the KP-39
http://forums.vwvortex.com/zeropost?cmd=tshow&id=4615281
 Edit: Anyone know how these 2 turbos compare?
Post by: OM617 on October 29, 2009, 10:01:34 pm
Looks like a KKK turbo.
Post by: Rabbit on Roids on October 30, 2009, 07:31:11 am
looks KP 39 to me.
Post by: fatmobile on October 30, 2009, 06:56:07 pm
How do they compare?
 Is one better at the low end but better up high?
 The KP-39 is a later model,..
 Improved in any way?
