Engine Specific Info and Questions => IDI Engine => Topic started by: burner on February 27, 2007, 06:47:40 pm
Title: older rising rate pump on an eco diesel???
Post by: burner on February 27, 2007, 06:47:40 pm
im not sure if i should swapout the 91 eco pump for an 85 quantum td pump or just do a head swap?
Post by: RabbitJockey on February 27, 2007, 06:59:59 pm
swap the lda top over and the 9mm head over
Post by: burner on February 27, 2007, 07:16:35 pm
is it easy
Post by: burner on February 27, 2007, 07:48:44 pm
any other suggestions to make an 84 rabbit ecodiesel swap faster?
Post by: burner on February 28, 2007, 04:50:04 am
im sick of doing seaches, somebody give me a recipe for a quick eco 1.6 td please.
Post by: jtanguay on February 28, 2007, 06:00:31 am
Quote from: "burner"
what is it that you want to do exactly?? turbo your motor??  install an ecodiesel injection pump on an '85 quantum TD for some extra power??? then yes you would need to swap the LDA top over to the ecodiesel since it does not have one.
If you're trying to swap an '85 quantum injection pump to the 91 ecodiesel, then go for it...
a rebuild would do wonders for power though  :wink:
