Engine Specific Info and Questions => IDI Engine => Topic started by: foxracer1 on February 03, 2007, 08:35:27 am
Title: TURBOS TURBOS TURBOS??????
Post by: foxracer1 on February 03, 2007, 08:35:27 am
What are the turbos that were all offered on the VW diesels?
Alos where do they spool at?
garret/t3 - older engines? - more boost higher rpm than below?
kkk/k26 - eco? quicker spool?
kkk/k06? - aaz - really quick spool?
VNT - TDIs
And what years were they offered?
I'm confused with the TDIs and the turbo manifold combo where both are one? what years did they do that where they all VNTs? just tryin to get all the differet ones figured out.
Post by: QuickTD on February 03, 2007, 09:46:04 am
Garret T3 Used on early 1.6TD's. A little large and laggy for the stock engine but responds well to fueling mods. Trapezoidal manifold flange.
KKK-K24 - Used on later 1.6TD's, slightly slower spooling than the T3. Trapezoidal manifold flange.
KKK-K14 - Used on the US ecodiesel, the european RA/SB GTD engines (with watercooled cartridge) and used on some early 93-94 1.9TD AAZ engines. Good compromise between lag and max boost for mildly tuned cars. Trapezoidal manifold flange
Garret T2 - Used on some early passat 1.9TD AAZ cars, I have one in "stock" but have no experience actually using it. Someone else may be able to add something here. Size appears similar to the K03. Trapezoidal manifold flange.
KKK-K03-003 - Used on canadian and european 1.9TD AAZ engines. Extremely quick spooling but less than adequate flow for big power. Triangular exhaust manifold flange requires K03 manifold.
KKK-K03-006 - Used on early passat and Mk3 jetta 96-97 TDI 1Z and AHU, much the same as the 1.9TD K03, but is set up for mounting under the manifold. Uses triangular exhaust manifold flange.
Garret GT15 - Used on later (98?-99)AHU Mk3 TDI similar to K03 in terms of flow. Also clocked to mount under manifold, triangular manifold flange interchangable with K03-006
Garret VNT-15 Used on ALH 90hp TDI engines from 99-03. Integral manifold/turbine housing, turbo is located under manifold. Variable vane vacuum operated.
Spool time with any turbo is entirely dependant on the level of fueling, particularly the off boost setting on the LDA. The size of the exhaust, the injection timing and many other factors also contribute.
Post by: SMOKEYDUB on February 03, 2007, 11:29:51 am
who actually is running 28 and up? do you have any problems like andy and I ?
Post by: foxracer1 on February 03, 2007, 12:56:48 pm
Quick TD Thats great and exactly what i was asking for. But one thing my friend has a eco and the turbo is of course a kkk. The center section isn't watercooled though so which one does he have.
Now What about Gas turbos for VWs any interchangeability? Obviously they will probably be geared for some high rpm numbers.
Post by: entuzijast on February 03, 2007, 03:21:55 pm
He has k14, only RA/SB have watercooled k14....
Post by: foxracer1 on February 03, 2007, 03:40:51 pm
Ok after reading that i realized what he was saying. Thanks
Post by: foxracer1 on February 03, 2007, 03:43:23 pm
Ok now whats the max amount of boost each turbo makes efficently?
Garret T3- I have heard around 20Psi?
KKK-K24 - smokey dub is runnin 27psi!
KKK-K14 - 18psi?
Garret T2 - ?
KKK-K03-003 - ?
KKK-K03-006 - ?
Garret GT15 - ?
Garret VNT-15 -?
Post by: DVST8R on February 03, 2007, 03:55:40 pm
I am currently running 30psi unintercooled, or so on a KKK24 everyday, the motor has about 40K on it, and shows 490psi across the board, and I have never had a HG problem with it. Pump is only moded by huge cut in fuel pin, and minor revlimter mod.
My previous car, I ran 35psi+ and beat the crap out of it, it had every last concivable mod that you can do to a stock pump, I ran both the T3 and the kkk24 on it, and it had enough fuel that it spooled it close to as quick as a k14 on a stock 1.9td. It ran stock fibergasket and stock headbolts, and never had a hg problem. Yes it had serious EGT issues within a short WOT run, but was fun none the less.
Now we need to get Malone or Dave @ PP to chime in about the franken motor as IIRC even with a 1.9hg and studs that it had some pressurizing of the cooling system, but I could be wrong.
Post by: sethyboy85 on February 03, 2007, 04:53:27 pm
Garrett T3 Minor adjustment to the fuel screw
10psi by 3k 25psi by 4.5k. I need to intercool it it was boosting to 15psi  by 3k but would quickly shoot above 25psi and it's my DD so no popping HG for me just yet, fuel screw was much further in (idle 1400rpm) lol.
motor has 90k on it, a 91 eco motor that was immediatley swapped to the garrett, compression I don't know but it starts in 15F weather without a block heater or using the cold start lever and purrs just fine.
Post by: foxracer1 on February 03, 2007, 06:48:40 pm
sethyboy85 : what kinda boost does yours run at 2500-3000 my car runs around there from 65-75 mph and i'm wondering how it would perform on the highway.
Post by: sethyboy85 on February 03, 2007, 07:03:48 pm
depends on load and temp of engine but at least 5psi @ 2.5k 8psi by 2800rpm and like I said 10psi by 3k. It might be sooner as I only really watch the boost gauge over 3k to make sure I don't boost too much.
That is with almost no smoke, if I turn up the fuel I can have more
I run down the highway 70mph @ 3.1k or so and depending on grade 2psi to 5psi to maintain that speed without any large hills, the long grade I do pull at highway speed the truckers are going 5-20mph and I am boosting 8-11psi to maintain 75mph
Post by: nkb on February 04, 2007, 04:26:52 am
I have a t2 I was running 30+ psi non intercooled or egt. The turbo started showing no side to side play after 25k but has alittle in and out which probably isn't good but could have already been there from having 490k on it. I pulled it for a rebuild and bolted on my spare when the seals went, now no boost and a slow assed car
Post by: foxracer1 on February 04, 2007, 08:31:04 am
So were all the Integral manifold/turbine housings VNTs? My friend has one and says it isn't a VNT but i think it is. He said it was off a 2001-02 jetta tdi auto. He also said i could have it!
Post by: Typrus on February 04, 2007, 09:11:32 am
I know its not much of a contribution...
A lot of 1Z's came with the Garret GT15. Seems to be a nice turbo, though longevity has been questioned by many. Ours has gone near 200k and the seals seem ok. I attribute that to quality oil and my mom driving soft (stock brakes went 198k miles!)
It spools up fairly quick on the 1.9L 1Z TDI. I think I can hear it start whining about 1700RPM parked doing diagnostics, it gets really noticeable about 2k and sounds peaked out by 2200. I do not have a boost guage, and the N75 is stock (though brand new) on it. So, she's likely pushing whatever the factory set her to.
Again, it seems like a simple and reliable turbo, from my standpoint.
There is a gentleman over on the TDIClub who sells some nice Hybrid turbo's for the 1.9L's. I can't remember his sign on, but I'll try to remember to look it up.
Post by: Slave2School on February 04, 2007, 09:24:55 am
Bleachedbora sells the hybrids.  They use a vnt-17 compressor wheel.
Post by: RabbitJockey on February 04, 2007, 09:49:53 am
i think i'm having hg problems at 25psi but as long as i don't get on it it doesn't do it.
Post by: Typrus on February 04, 2007, 11:13:58 am
Yeah, thats it, BleachedBora.
I've heard good things about them. Several people recommend them as a replacement when the GT15 croaks.
Post by: GTD. on February 05, 2007, 04:53:33 am
80,000 pascals :D
 Sounds a lot till you realise its only 0.8 BAR or 11.6 PSI :lol:
Post by: 935racer on February 05, 2007, 09:45:40 am
Quote from: DVST8R
Hehehe yeah I remember your old jetta Brett, I know before that car was scrapped that I did put a 1.9hg with stock bolts in it. But it wasn't because your stock one failed, but because I pulled the head off already to check your valves because your timing belt failed when it was idling outside, remember how your belt walked right off the side of the pump sprocket? That was weird, it was cause that stupid bracket under the pump came loose. But yeah besides that the engine was stock, I was always amazed how badlyyou bet that thing, seems like I was doing more tranny swaps on that car than I remember you driving it :lol:
Yeah the franken motor I had go up to 37-40 psi, there were some coolant issues I remember, we were blowing up the coolant tanks, luckily they were pretty cheap. But he had problem with the water pump too, I think it was blowing the O ring out were the water pump goes into the block, and that was what killed that engine, water loss. Its been a while, and I didn't document enough on that engine. Oh well my tdi is almost done I am o ringing the head, and plan on running 45 psi. Guess I'll see what happens.
Post by: DVST8R on February 05, 2007, 07:28:46 pm
I had totally forgot about that stupid pump bracket... Good times. :lol:
Post by: foxracer1 on February 10, 2007, 08:18:39 am
Ok so now does anybody know the A/Rs of each turbo? What size would be good to look for if i was to buy a turbo or find one on an other car? Also i was at the junkyard this weekend and found an Audi Quattro 5000 w/turbo. The guy said he wanted $75 if i pulled it.
Post by: foxracer1 on February 10, 2007, 03:56:07 pm
Garret T3- I have heard around 23Psi?
KKK-K14 - 18psi?
KKK-K26- ?
Hybrid K24/26- ?
Garret T2 - ?
KKK-K03-003 - ?
KKK-K03-006 - ?
Garret GT15 - ?
Garret VNT-15 - 15-17psi?
Post by: Slave2School on February 11, 2007, 06:36:00 am
You need to take into account flow too, but I'm not sure how you can do that.      I'm sure with the 20 year design differences in compressor technology etc between the older and newer "size" might not mean as much.
Post by: SMOKEYDUB on February 11, 2007, 02:12:26 pm
usually you can get a k24 to boost even higher keep in mind i have a huge intercooler that cools very well and its plumbed with 2.5 inch tubing and my cylinder head and my intake manifold are extremely ported and polished to less restriction equals less boost. The definition for boost is... Boost is a result of restriction.With no restriction you will have no boost. So try and get rid of restrictions it will run a little less pressure but it will be more efficient.
