For Sale/Looking For => Parts for Sale/Wanted => Topic started by: zukgod1 on January 19, 2007, 09:40:31 am
Here it is.
Located in Salt Lake City, Ut area.
1984 Toyota reg cab 4x4
A/C, P/S, Tilt 183K miles 5spd
This was a NA truck when I got it but I was able to round up the turbo parts preaty easily so I went for it.
It has allot more power now, you can actually drive it on the freeway now :)
List of new parts below;
Timing belt
Water pump
Radiator
Injection Pump w/ Boost compensator
Advanced timing and pump turned up
Injectors have new tips, pop off set and flowed
Pusher pump
Turbo w/ OE exhaust manifold and OE intake manifold
Cold air intake
2.5" exhaust system Turbo back
All V Belts
Glow plugs
Charged A/C
Block heater (freeze plug type)
Fuel level sender (Toyota)
Carrier Bearing
Front brake Rotors
Braided brake lines
New clutch
Rear trans mount
Clutch Master cyl
4" lift
Shocks
Toyo 31" A/T's on Alum wheels
2 new batteries
EGT, Boost, Fuel pressure on A Pillar
Oil pres, Water temp, Volts in dash pod
All Auto meter Ultra lights
New windshield
Tinted all glass
APC Buckets
Pre formed carpet w/ lots of insulation
Tilt column, changed key switch so doors still match
Removed Toy fuel filter assy and installed one off a 01 Dodge better filter and easier to find.
Under bed Reverse lights
Flat bed w/ LED lights
Received hitch mounted to frame.
Valves were just adjusted also
White in color.
Paint is in fair condition, it has been repainted at some point in the past and the clear coat is peeling off. The cab has a little rust on the drivers side rear cab corner but it's not terminal and the passenger front fender has very little rust around the fender lip.
The original bed was rusted out preaty bad so I decided on the flat bed, it seems to be working out ok, get allot of comments "Cool truck" etc etc.
This truck is not a powerhouse but it will do 75 just fine.
Get's 25 mpg depending on how you drive it.
Need $4500.00 USD
Can help arrainge shipping or you can fly into Salt Lake City airport and I'll pick ya up.
Dan
801-755-2523
SOLD
