General Information => General => Topic started by: SMOKEYDUB on January 18, 2007, 04:00:38 pm
Title: golf 2 td vid VERY FAST!
Post by: SMOKEYDUB on January 18, 2007, 04:00:38 pm
http://videos.streetfire.net/search/diesel/3/9e863027-f338-4ea3-8207-981300d8253d.htm
enjoy
Post by: jtanguay on January 18, 2007, 05:43:47 pm
:shock:
where can i get me one of those motors???  :twisted:
hmmm for a 2006 2.0 PD engine its... about $7000  :cry:  on ETKA
Post by: SMOKEYDUB on January 18, 2007, 06:43:28 pm
not sure which pd that was but im sure you can get one from malone or 935 racer i think? or a recked 04 and up diesel dub
Post by: jtanguay on January 19, 2007, 04:31:47 am
wrecked TDI's ... hmmmm
anyone have a good source on wrecked tdi engines here in Ontario???  i'm sure its pretty uncommon since nearly anyone driving a TDI has some brains... (they can do the math of fuel savings anyways...)
Post by: anarchyx34 on January 19, 2007, 11:07:07 am
Sick car. Why is it that whenever I see a video of a modified diesel, it's spewing thick black smoke everywhere? Isnt that poor tuning? Dosent that cause very high EGT's?
Post by: burn_your_money on January 19, 2007, 12:07:25 pm
I saw a wrecked TDI in a local yard, engine fire though so I didn't bother :(
Post by: jtanguay on January 19, 2007, 01:04:47 pm
Quote from: burn_your_money
aw thats when you talk the guy real low...  :lol:
i wouldn't mind having that motor if it was only $200... slap on a new head... get a m-tdi pump dissassemble the vnt turbo and clean it up a bit... pray that it wasn't the cause of the fire...  :lol:
Post by: burn_your_money on January 19, 2007, 03:03:45 pm
It had looked like it cooked, and that every part on it would have been total garbage, I didn't even bother asking how much he wanted for it
Post by: malone on January 19, 2007, 05:07:45 pm
The video states 1.9L PD with 225hp and 490Nm, which is attainable with a stock-internal 1.9L PD100 found in NA-sec Golfs and Jettas, etc. There's no need to import a PD130 or 16v PD from Europe unless you want more HP.
On a second thought.. inexpensive PD100s are hard to find in NA. PDs are much more abundant in Europe, so importing one may be less expensive. Under 3,000 USD or even 2,000 USD will get you a complete PD130 engine & electronics package. Price varies depending on different sources in Europe.
Post by: malone on January 19, 2007, 05:25:14 pm
Brief puffs of black smoke (as seen in that video) doesn't always indicate high EGT. It's sustained high loads where you should avoid heavy smoking without an EGT gauge. If someone has a EGT gauge and smokes a ton, then so be it. Diesel power is primarily based on fuel, so more fuel means potentially more smoke.
Some people want to squeeze out the last few HP by overfueling and some others prefer good power while appearing clean (smoke-free).
It should be made clear that it is STILL possible to exceed safe EGT limit without producing any smoke. So if you're doing more than moderate power enhancements, an EGT gauge is always a good idea.
In this video there are too many unknown variables to determine whether it's good or poor tuning. I.e. Is his turbo so large that he wants to pump a lot of fuel (i.e. smoke) at low RPM in order to get the turbo to spool up a little quicker? This would make sense on a tight autocross course. Should he have ported his head to improve low-RPM airflow to reduce the smoke?
It is possible to tune the chip to reduce off-boost smoke. We can't really judge his tuning based on this video only.. we need more information; a full mod list, take logs, analyze his chip, type of fuel he's using, etc.
For what it's worth; in most cases the excess low-RPM smoke is indeed a result of poor chip tuning. I see many VNT-15(stock) and VNT-17, VNT-20 equipped TDIs smoking a ton at low RPM (or in the entire RPM band) when they could have smoked a lot less without losing much power (if at all) after a proper chip remap.
