Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: hillfolk'r on December 28, 2006, 02:02:31 pm
Title: heres some initial gtech RR numbers on the tdi-m
Post by: hillfolk'r on December 28, 2006, 02:02:31 pm
i got a gtech RR for xmas
im still learning how to use it,but im getting there
hopefully you guys who are building tdi-m's get the same results
but 2 of my runs so far:
116hp@2700 rpms
229 ft pounds@2600
and the next
138hp@3100
231 ft pounds@3150
the tq curve is SO flat it isnt funny
im not so impressed/happy with the hp numbers
i was thinkin like 150,but my butt dyno doesnt work so good
and therabbittree was close with his verbal estimate of 220 +ft pounds
though,good job Deo!!!!!!!!
i always had a problem reading the tach,but now thats no problem with the tach on gtech
my max revs are a little lower than what i thought
i used to think it revved nice to 45-4700
but its more like 4200 max,it falls off dramatically after that
ive got the shift lights set to around 3800,and that works fairly ok so far
Post by: vwmike on December 28, 2006, 02:21:51 pm
What sort of governor are you using in your pump?
You should really get that thing on a chassis dyno. Gtechs are good for doing comparisons and whatnot but they're not nearly as accurate as a real dyno.
Post by: andy2 on December 28, 2006, 02:59:18 pm
Thats 138 WHP right?How much boost? 30psi?.It would be nice to campare that with the chassis Dyno,But it does seem like a good ballpark reading.
Post by: hillfolk'r on December 28, 2006, 03:24:23 pm
they  say its not wheel hp
its net hp
itll go like 40psi most of the time
i need a bigger turbo
Post by: andy2 on December 28, 2006, 03:37:46 pm
So net hp is from the crank?
Post by: RabbitJockey on December 28, 2006, 04:06:15 pm
it's real world hp, basically, wheel hp with  aerodynamics played in as well.  his car would probably have another 20 hp on a stationary dyno
Post by: hillfolk'r on December 28, 2006, 05:28:23 pm
yea and being i was in 4th gear the aerodynamics come into effect too
in a lower gear,it winds out too fast to get a complete  hp/tq curve
and it was raining when i did my initial testing
thats why i only did hp testing at first
Post by: RabbitJockey on December 28, 2006, 07:36:11 pm
i'll have to do a 0-60 move in my jetta in the rain, but only of the speedo, i don't want anyone to see outside, then they'll no i was actually sitting still lol
