Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: deezul ryan on December 24, 2006, 03:24:10 am
does anyone have a source for TDI HD parts? like H beam rods and thicker pistons? maybe rods for another engine (gas) that fit? i am also looking for ARP # i think 8v gas head studs and main studs will fit. Or PLEASE correct me if i am incorrect.
Heavy duty TDI parts are hard to find. The diesel, TDI's even to begin with are built with pretty robust bottom ends, crank, rods, pistons, etc. wise compared to a gas car just because of the stresses they see on a regular basis. However, I believe it is Allard in europe that sells HD TDI pistons, suposedly the VWMS spec units, rods, etc. as well as the overbore kits for TDI's too. 2.0, 2.1, etc. EXPENSIVE stuff though...
There was a guy on Ebay here a while back selling HD TDI pistons. They weren't OEM...some other piston manufacturer, but supposedly they were heavy duty... I thought someone on here was going to buy a set...but that was a while ago. Maybe they'll chime in...
As far as head studs and other hardware goes. Gas studs will not fit, all diesel, 81+ through TDI (with exception the the PD "pumpe deuse" use 12mm head studs. The gas units are smaller in diameter and different in length as well if I remember correctly. Raceware in my book is the best and they carry both the head studs for TDI's as well as main studs...but ARP may have them as well. You'll want to check if the rod bolts that ARP sells are approriate though as when I was looking around no one made a rod bolt specifically for the TDI which has a different style rod bolt than most gas engines. As far as I know, the main stud kits are the same between the gasser and diesels though. Just don't really care for the mexico made ARP stuff and will front the extra cash for Raceware or stock hardware if it comes down to it. Stud and rod kits will also require you to have your block line bored for the stud fitment as well as the big ends of the rods bored to allow the proper fitment of the rod bolts if you go that route.
Maybe thats some help...not sure... good luck...
Joe
i have seen the pistons on ebay and i like what i saw. i am building this motor to race only and i dont want to find out the hard way that the rods will fail. does anyone know the measurments of tdi rods? Thanks for the head stud info[/img]
i came across this on the net today. maybe this will help anyone else with the same problems. dont know if i can get them in the states.
http://shop.dieselschrauber.de/product_info.php/cPath/44/products_id/158?osCsid=f2491d6b0ca38b2c80e42568b36322a4
YouŽll find stud part numbers from here (http://vwdiesel.net/phpBB/viewtopic.php?t=4208)
Rod maesurements are:
pin 26mm
big end 50,6mm
lenght 144mm
