For Sale/Looking For => Parts for Sale/Wanted => Topic started by: myke_w on December 14, 2006, 09:50:29 am
Title: FA: 1.6 TD Pistons in .20 and .40 Kolbenschmidt $310 shipped
Post by: myke_w on December 14, 2006, 09:50:29 am
1.6 TD piston sets in .20 and .40 oversizes for $310 shipped.. Best deal around... cheapest you will ever find them.  :D
SEE LINK
Relisted... again
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMESE%3AIT&viewitem=&item=140081395736&rd=1,1
(http://i24.ebayimg.com/07/i/000/80/42/8d75_12.JPG)
Post by: jtanguay on December 14, 2006, 12:24:24 pm
that really is a good deal... i wish i knew which oversize i needed :)
Post by: myke_w on December 14, 2006, 12:47:39 pm
Is your engine apart?
If you can see the piston tops you can pretty much tell what you'll need.. .20 over can clean up just about any normal wear, if you've got mechanical failure damage evident on the walls, you may want to go for the .40 over... either way, let me know..
Post by: foxracer1 on December 14, 2006, 01:49:48 pm
how many sets do you have?
Post by: myke_w on December 14, 2006, 01:52:03 pm
How many do you need? :)
Post by: 935racer on December 14, 2006, 01:53:21 pm
Great deal!
Post by: foxracer1 on December 14, 2006, 01:57:22 pm
Good thats what i needed to hear. Probably one set not sure which size yet. i think its .020 already and still has crosshatch.
Post by: myke_w on December 14, 2006, 02:00:56 pm
If you can see the piston tops, you should be able to read the number. It should be somthing like 76.49 if it's stock. If it's oversize it will be more like 76.99
Post by: Kudagra on December 14, 2006, 04:23:03 pm
<--- No money
Post by: myke_w on December 14, 2006, 05:38:59 pm
<--- No money
They'd make a good christmas gift!! :)
Post by: myke_w on December 16, 2006, 10:16:54 am
relisted..
Post by: Kudagra on December 16, 2006, 08:57:59 pm
I really dont think the wife would understand and I think sleeping in the back seat of the Jetta would be mighty cold at the moment.
Post by: myke_w on December 16, 2006, 09:07:04 pm
Quote from: Kudagra
I meant they'd make a good gift for you! Put them on your wish list man!
BTW, buy 2 sets, get 20 bucks off set #2. In other words, 2 sets for 600 shipped - deal is only good for GTD folks...  :D
Post by: nkb on December 21, 2006, 03:35:31 am
do you only have 1.6 pistons?
Post by: myke_w on December 21, 2006, 05:31:35 am
Quote from: nkb
No, I have 1.9 TDI pistons in another auction..  I can probably get others.. just ask..
[email protected]
Post by: mst on December 28, 2006, 07:25:24 am
Sorry to bother you since I probably will not be buying from you. I live in France, so the transport price will be expensive have seen on German eBay pistons for engine code
CS and JX (campmobile/bus), the price is right, 185 euro with sales tax, but my engine is a
SB; I do not know if they will fit, can you help me. I have written to the guy selling and he does not know!!
Post by: myke_w on December 28, 2006, 08:10:47 am
Is it a 1.6 or a 1.9? Is it turbo or NA?
Post by: mst on December 28, 2006, 08:47:47 am
The SB is a 1.6 turbo from a Passat from about 1989 (it is also used in the Golf Mk2.What I am afraid of is that the JX 1.6 TD do not use the oil jets, but if all vw 1.6 TD use oil jets then there should be no problem, but I cannot find engine code JX in Bentley nor in my other books
Post by: myke_w on December 28, 2006, 09:18:49 am
any 1.6 TD VW piston will fit, just be sure it has the oil squirter cutouts..
Post by: mst on December 28, 2006, 10:30:06 am
I have found a picture of the pistons here:
http://cgi.ebay.de/Kolben-VW-Transporter-T3-1-6-TD-JX_W0QQitemZ8066314848QQihZ019QQcategoryZ61301QQrdZ1QQcmdZViewItem
I think that they have the cutouts,am I right? :?
Post by: myke_w on December 28, 2006, 11:58:41 am
they look like the right ones to me..
Post by: mst on December 28, 2006, 01:17:10 pm
Perfect,thanks for the help,happy new year :D
Post by: moTthediesel on December 30, 2006, 06:57:59 pm
Myke:
Got the kolbens in mail today, they look great :!:  :!:
Block off to M.S. next week to be dipped and punched out.
Hope to be making noise and smoke by spring --
moT
Post by: myke_w on December 30, 2006, 08:16:37 pm
Excellent,
tip for you..
Tell the shop to leave the bores a bit on the loose side of the factory spec in the manual.. The motor will rev easier and won't feel tight..
Post by: Fisher on January 01, 2007, 02:04:12 am
What do you consider "a bit on the loose side" of the spec in the Manual?
Just wondering.
Post by: myke_w on January 01, 2007, 10:30:30 am
(http://www.vwdieselparts.com/mspecks.jpg)
Section C # 4
Tight would be .02mm -- loose would be .05 .. If they'll cooperate, have them get closer to .05
Post by: itzdshtz on January 01, 2007, 11:08:59 am
Hi Myke, is it possible to supply 1 piston only in 77.01 mm?
I have a block that has one piston damaged, the rest is like new, only 5000 miles on a rebuild.
Post by: myke_w on January 01, 2007, 11:55:54 am
I can do one..  No problem..  paypal 82.50 to [email protected] and I'll get it on the way..
Post by: itzdshtz on January 01, 2007, 12:36:29 pm
Money send. Thanks, I will be back for more.
                                                  Herman
Post by: Fisher on January 01, 2007, 01:02:11 pm
I know what the VW Spec is, I have the manual.  There seems to be many conflicting opinions about this spec from different Shops.  There are as many different opinions as there are different shops.
I'm  just looking for information based on actual fact and experience.
Thanks for responding with your information.
Post by: myke_w on January 03, 2007, 08:53:11 pm
My experience is that if you go on the tight side, the engine will never rev well, it will feel tight. If you ahve them leave it on the loose side, it will rev freely, won't feel "not broken in" or like a cold motor all the time..
You really need to send the pistons to the shop, if they are good at what they do, chances are, they will get it right. This is not exact science... It's preference more than anything.
Post by: Fisher on January 04, 2007, 09:04:40 am
OK, thank you.  Block is at a good shop, they'll get it right.  I'll be in touch.
Title: Pistons
Post by: Doug on January 07, 2007, 06:32:00 pm
Mike, I have my 1.6 TD open now for valves and rings. It really needs to be bored but I need the car soon. I ran a ball hone through it tonight to prepare for new rings. The pistons are 76.48 mm. They have been in carb cleaner for three days and have cleaned up real nice. The old rings were basically oil crudded into the lands. There is about .005 inch wear on the bore which I realise is out of spec but this will get through the winter while I work on my Landcruiser. What oversize would you go with? Most shops always seem to want to take a fresh cut at things which usually means two oversizes. How do I order with Paypal? Haven't done it recently.
Doug
Post by: myke_w on February 05, 2007, 06:28:02 pm
more pistons available..
