General Information => Troubleshooting => Topic started by: BioDieselVW on December 13, 2006, 11:37:12 am
Title: 1.6 TD Ticking Noise Please Help?
Post by: BioDieselVW on December 13, 2006, 11:37:12 am
I have a 1.6 TD in my Caddy. Ever sense I have put it in it has been making this ticking noise. My first thought was an exhaust leak but have pretty much ruled that out. Anyone have an idea what it could be. Could i have a bad lifter of two? They are hydraulic  do these go bad ?
Post by: Benjamin on December 13, 2006, 12:07:31 pm
is this with the stock camplate in the pump?
Greetz, Benjamin
Post by: burn_your_money on December 13, 2006, 01:55:37 pm
How is your timing?
Post by: Malacaco on December 13, 2006, 04:57:36 pm
my engine starts ticking too but only when i go in a tight left corner...
Post by: jtanguay on December 14, 2006, 04:41:51 am
Quote from: Malacaco
hehe probably from lack of oil pressure :)  you should install an oil pan baffle!
Post by: BioDieselVW on December 14, 2006, 04:49:22 am
so if i have a lack of oil pressure is that due to a faulty oil pump? What will a windage pan do for oil pressure.
Post by: BioDieselVW on December 14, 2006, 04:51:03 am
Timing is right on and was just done. Anyone with any ideas?
Post by: jtanguay on December 14, 2006, 01:50:50 pm
Quote from: BioDieselVW
the windage pan ensures that you have oil in the sump on hard cornering.  its also good for a couple HP up top, and is way better than the stock oil pan seal, as it comes with its own rubber seal.
hearing ticking is usually from advanced timing... or worse, lack of oil pressure.  i would get a gauge just to be sure though.
Post by: Malacaco on December 14, 2006, 04:49:47 pm
but then if the oil pressure gets lower, the pressure light should turn on...?!
Post by: jtanguay on December 14, 2006, 05:41:44 pm
in a perfect world.. yes.. i have seen way too many of these lights blink when oil pressure was fine, and not flash when there is an issue.
best way to check, is with a gauge.
Post by: Malacaco on December 15, 2006, 04:45:05 am
so where could i get an oil pan baffle for the td engine? all i can find is for the gti...
Post by: jtanguay on December 15, 2006, 05:30:15 am
it will be listed for 1.9TD's but fits the 1.6TD oil pan :)  as far as I know you don't need different bolts to hold it in, but I may be wrong...
http://parts.autopartsonlinecanada.com/parts/apocanada/wizard.jsp?year=1996&make=VW&model=JET-D-004&category=A&part=Oil+Pan+Baffle
theres a pic of what it looks like, and the price in CDN.  don't know the part # though.
Post by: AdAm84 on December 15, 2006, 11:21:19 am
Don't depend on the idiot lights. My glow plug light only works half the time but i know that they are working. I thinks its a grounding ploblem in the dash. So there cold be the same issue with the oil pressure light.
Post by: Malacaco on December 15, 2006, 11:56:00 am
Jtangauy, can't open the page, must have some problem, but thx anyway
Adam84, i honestly think that my light works perfectly well cause when i turn the ignition key, the light turns on, and 2 seconds after i turn the engine on it shuts off, wich means it works with pressure gains :). besides it's a new one that i bought recently.
But i noticed something today. the ticking noise that appears in tight left corners could mean not only low oil pressure but low oil level too... cause i was checking the level and it needed about a liter, and after that , didnt hear anymore tickings. Just a guess, i suppose.
Post by: burn_your_money on December 15, 2006, 02:48:19 pm
PP sells baffles I think, support the locals :D
I took the time to upload the picture in the link to my photobucket account for you, not sure why you couldn't open it.
(http://img.photobucket.com/albums/v603/burnyourmoney/baffle.jpg)
Apparntly they are all the same for 8Vs, so I bought one from BFI.. horrible idea. They are a great company with great products, but if you live in Canada you will get screwed over on import fees bad!
Post by: Malacaco on December 15, 2006, 07:04:15 pm
where's BFI from. Excuse my ignorance but don't know that company. And thx a lot for the image. That will help me a lot to explain in here in portuguese what i really want cause i don't know the transaltion for oil pan baffle ;)
Post by: burn_your_money on December 15, 2006, 07:11:41 pm
it's also called a windage tray. BFI is located in the states. They only ship to North America I think.
www.blackforestindustries.com
Post by: Malacaco on December 15, 2006, 07:40:09 pm
wow, this is nice
