For Sale/Looking For => Vendors Section => Topic started by: Smog on November 30, 2006, 04:40:43 am
Title: TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready
Post by: Smog on November 30, 2006, 04:40:43 am
TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready (TD and TDI)
uprated 1.6GTD nozzles (RA/SB engines )
stock 1.9TD nozzles (AAZ engines)
0.205mm and 0.216mm nozzles for the TDI
IDI injection pump seal kit (1.6D 1.6TD and 1.9TD)
TDI injection pump seal kit (1996-2003 TDI)
IDI Pump shaft seal for pump sucking air
I can do COD for canadians (add 5$)
www.veg-injection-service.com
Post by: LeeG on November 30, 2006, 01:03:47 pm
Do you still install and shim nozzles if someone sends injector bodies?  How much for that?
How about the special socket for IP dissasembly?
Post by: Smog on December 01, 2006, 04:23:49 am
Quote from: LeeG
Sorry,
no more pop-testing on injector. You may ask your local BOSCH certified shop if they can do it for you
Post by: jtanguay on December 05, 2006, 01:34:34 pm
nooo smog you dont pop test injectors anymore? i'm guessing something bad happened?
Post by: Smog on December 06, 2006, 04:28:07 am
Quote from: jtanguay
Simply too much time consuming for a guy with 2 kids under 18 month old....
Post by: DELETED on December 06, 2006, 06:17:59 am
DELETED
Post by: Smog on December 06, 2006, 06:19:06 am
Quote from: DragonsMaw
Do you have 1.6D seal kits in stock?
Yup,  everything is in stock ready to ship
Post by: commuter boy on December 06, 2006, 04:08:11 pm
Quote from: Smog
Ah, wait a year or so, then you can get them to pump the handle for Papa.
 :D
Post by: Smog on December 07, 2006, 04:28:52 am
I may show them how to rebuilt my 1972 beetle; it will be better for customers
Post by: commuter boy on January 14, 2007, 11:01:21 am
Do you have seal kits for the 2.4 5 cyl AAB engines that were in the Canadian Transporters?
I'm curious as to how much of the 1.9 seal kits would match with them, the pumps look fairly similar on the outsides......
Post by: Smog on January 15, 2007, 04:05:11 am
Quote from: commuter boy
the injection pump is similar but the kit I sell will be missing 1 small copper seal for the fifth delivery valve on your pump.  I don't think it's a problem as they are rarely leaking but just to let you know. The rubber parts are all the same
Post by: insdtanoodles on February 15, 2007, 02:43:18 pm
Is it just as easy as to take the old nozzels from my aaz and put new ones in or do the the new ones have to be shimmed and pop tested?
Post by: Smog on February 16, 2007, 04:06:07 am
Quote from: insdtanoodles
the fabrication tolerances are tight, they can be reinstalled without pop-testing but if the car got over 250000km, it's a lot better to have the injectors reshimmed to the oem opening pressures.
they will work fine without shimming, you'll get the power, mpg and driveability gain but pop-testing them is the icing on the cake
Post by: insdtanoodles on February 16, 2007, 01:46:33 pm
I guess I should get them shimmed then, cars got 247000km on original injectors
Post by: red64chevelle on June 07, 2007, 06:11:23 am
I just payed via PayPal for the injection pump seals, and GTD nozzels.  I can't wait to finish my "GLD" project.
Post by: Smog on June 07, 2007, 06:15:10 am
Quote from: red64chevelle
I will send them today !
Post by: Turbinepowered on July 11, 2007, 09:54:26 pm
Do you also sell, or can you get, shim kits for those of us who would like to pop-test and reshim our own injectors?
Post by: Smog on July 12, 2007, 04:18:41 am
Quote from: "Turbinepowered"
I still have almost all sizes; do you need something specific or you want the whole kit ?
Post by: Turbinepowered on July 12, 2007, 12:11:46 pm
Quote from: "Smog"
Looking for the whole kit, actually; potentially more than one, given I'd be reshimming three engines' worth of injectors. A 1.5, 1.6TD, and a 2.0 TD, so all in all thirteen cylinders' worth of injectors. And I'm not sure what all is in the whole kit, so...
Post by: Smog on July 16, 2007, 12:40:48 pm
Quote from: "Smog"
If you ever know what sizes you may need, I could make a small kit for you. But I don't have a "real" kit ready to sell
Post by: Smog on July 16, 2007, 12:41:44 pm
The TDI 216mm are back in stock with a small amount of 0.260mm nozzles for the racers....
Post by: TD_Bunny on September 18, 2007, 09:00:34 pm
hey smog, what is the diff with uprated 1.6GTD nozzles and stock? Also, is it $80 shipped for one nozzle or for a set?
Post by: Smog on September 19, 2007, 05:05:03 am
Quote from: "TD_Bunny"
80$ is for a set of 4 nozzles
the GTD nozzles will flow more than stock nozzles and will certainly be better than the stock worn nozzles.
Post by: Smog on December 24, 2007, 04:57:30 pm
Quote from: "Smog"
the GTD nozzles are back in stock and I got a load of 11mm pump head kits for the TDI that may fit your IDI pumps
Post by: jtanguay on December 24, 2007, 05:14:54 pm
how much for the 11mm pump head kits?  i'm getting Giles to build my TDI pump.
Thanks
nevermind checked your site!  $150.
looks like i'll be buying this  :wink:
Post by: scopefrfd on January 10, 2008, 06:34:01 pm
Hi,
I'm interested in the 11mm pump head and gasket sets.  A couple of questions are they genuine Bosch or made in China stuff.  The reason I ask is I bought a new made in China 11mm pump head and gasket set off ebay and the pump head lasted less than six months in my M-tdi before it crapped and the injection gasket set the gasket for the top cover did not fit properly so I had to buy a genuine bosch gasket locally.   If it is made in China, is there any warranty on the items you sell?
thanks
Post by: Smog on January 11, 2008, 06:17:41 am
Quote from: "scopefrfd"
Hi,
thanks
the 11mm heads are made in china. made in the very same country as the  Bosch stuff.  By the way, myself I managed to friction-weld a VERY high dollars genuine BOSCH head in my own TDI.
as for the gasket kit, its BOSCH stuff.
Post by: secondgen on November 03, 2008, 06:32:09 pm
Still have any GTD nozzles?
Title: No Bosch parts made in China
Post by: Giles@PerformanceDiesel on November 03, 2008, 07:40:44 pm
there are no parts factorys in China guys, they make some tools
for Bosch but no parts for production and even if they did like
India or Brazil then the quality control would be much higher
if you siezed your Bosch original Head in your TDI then there
must have been something else wrong.
Giles
Post by: Smog on November 06, 2008, 09:05:17 am
Quote from: "Giles@PerformanceDiesel"
there are no parts factorys in China guys, they make no parts for production
http://www.bosch.com.cn/new/web/boschinchina/company_rbcd_en.htm
http://www.chinadaily.com.cn/bizchina/2006-05/22/content_596903.htm
http://rbcn.vicp.net/web/press/press_release_detail.jsp?newsId=27
Bosch founded its first trading office in China as early as 1909. The company operates via a holding company in Shanghai, 14 subsidiaries, six joint ventures, and six trading companies. 2005 consolidated sales in China reached 1 billion euros. Up to 2005, Bosch had invested around 620 million euros in China and between 2006 and 2008 it will invest a further 620 million euros. Over 14,000 Bosch employees are committed to bringing to the Chinese customers the latest technology as well as the most reliable services to help improve their quality of life.
Title: Chinese Parts
Post by: Giles@PerformanceDiesel on December 11, 2008, 07:47:35 pm
Hey
all i was saying was that the Diesel Pump parts produced by Bosch
all around the world China doesn't have any that i know of.
any parts we get here in Canada i have never seen any from China.
Giles
Post by: SootyMK1 on January 02, 2009, 02:40:07 pm
Can you get the throttle shaft bushings for a Bosch VE? Off of my 1.6L N/A
Thanks!
Title: Throttle shaft bushings
Post by: Giles@PerformanceDiesel on January 03, 2009, 05:54:55 am
yes no problem, just tell me the overall length pls
Giles
