Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: wjbski on November 27, 2006, 05:37:48 pm
Title: what's a good source for oversize pistons for a TDi engine?
Post by: wjbski on November 27, 2006, 05:37:48 pm
I just made a deal for a 99.5 Jetta TDi that needs internal engine work. I don't know the whole story yet, but it sounds like valves VS. pistons....
Are there any sources for O.E. oversize pistons?
Post by: RabbitGTDguy on November 27, 2006, 07:55:44 pm
Ebay has them listed every now and then... From there, I'd check with "Vanamania"...he is on ebay as well and is able to get stuff directly from germany most of the time. I think he had oversized units listed as well...  Be prepared to pay the price though. The last set of oversized ones I saw went for over 900.00 and I didn't stay to watch the end of the auction...
there may be a few vendors here that will chime in and could possibly help you out as well.
Joe
Post by: vwmike on November 27, 2006, 08:10:34 pm
Maybe try Autohausaz.com . I think they had them for around $90 a hole with rings.
Post by: RabbitGTDguy on November 28, 2006, 02:51:18 am
That sounds about right for rings, they used to have two different sets...two different qualities...one for around 70.00 a set...the other closer to 100.00 a set ... but he is looking for oversized pistons as well! If they sold them for that price, I don't see them listed, but if that is indeed true I'd be jumping all over them buying some up! Not a bad deal if it exists...
Joe
Post by: vwmike on November 28, 2006, 10:31:26 am
Autohaus doesn't seem to have them listed anymore but you can still get them here for around $100 each with rings:
http://www.busdepot.com/details.jsp?partnumber=038107065AA
http://www.busdepot.com/details.jsp?partnumber=038107065AB
http://www.busdepot.com/details.jsp?partnumber=038107081AB
http://www.busdepot.com/details.jsp?partnumber=038107081AA
Post by: RabbitGTDguy on November 28, 2006, 04:02:11 pm
Thats def. a good deal at those prices! Nice find...  Will have to remember that if the need ever arises in the future...
Joe
Post by: wjbski on November 28, 2006, 07:20:45 pm
Thanks for the link! I was supprised to see that the #1 and 2 pistons are different from the #3 and 4, and that the 3 and 4's are more expensive.
Upon talking with the shop owner where the car is at, it seems that the oil pump drive gear failed and has basically wiped out the engine. The cam journals are destroyed, so at the very least it needs a head. The shop said they also pulled a main cap and saw starvation damage to the crank as well as a rod journal. As I try to locate a used engine, the prices for motors w/ unknow mileage or maintainence history seems insane, so I'm not so sure I'm going to pursue this car anymore.
Post by: vwmike on November 28, 2006, 11:36:15 pm
You should probably be able to find a used ALH engine in the $12-1500 range. Check out car-part.com to do a search of wrecking yards. If you buy a known good engine from a lower mile car you should be pretty safe. A good wrecking yard should be able to give you mileage and/or compression test results.
Post by: vwmike on November 28, 2006, 11:53:22 pm
Maybe try here - http://forums.tdiclub.com/showthread.php?t=154825
Post by: wjbski on November 29, 2006, 03:39:07 pm
Thanks for the insite, vwmike.  If I could find a good, used engine I would persure it, but around here (Mid Atlantic region) these motors seem to go for ~$2500 without any kind of maintainence history or warranty.
I also saw that same ad on TDiclub.net  Unfortunately, when I tried to join their little club last summer, I wasn't granted the 'privelage' to post in their ads. I have no idea what it's all about. I've written several times to the administrators to no avail. It sucks, too because Harrisburg is only 1 hour to the north of my house.
Post by: therabbittree on November 29, 2006, 03:55:33 pm
that sounds weird i have been a member there for years ..no restrictions to sign up just start a new accoount?...
mummn
later
Deo
Post by: myke_w on December 13, 2006, 11:23:54 am
I can get you brand new .20 oversize ones with rings for 105 shipped each 1+2 or 3+4   or I can do a full set for 385 a set shipped..
email me at [email protected] if you want a set..
