General Information => Troubleshooting => Topic started by: 1slowvw on October 18, 2006, 02:30:42 pm
Title: Front end noise after panic stop
Post by: 1slowvw on October 18, 2006, 02:30:42 pm
Well guys the title pretty much somes it up. Went to drive a friend home tonight(and it was raining quite hard) and ended up making a panic stop to avoid running a stop sign. ended up locking up the front passenger side tire before comming to a stop. When I took off again there was a loud clunking comming from the front passenger side almost like a CV joint or something. so i took off slowly and started limping it back to residence. So after a hard right turn the noise disapears and everything seems to work fine other then the fact the car pulls to the right under braking a little bit. Anyway im hopping somone can give me an idea about what might have caused this noise because I'm kind of confused. Oh yeah the car is a 95 Golf AZZ and i just instaled a Supersport cup kit(if that could be a cause).
                                                              1slowvw
Title: OK
Post by: Darkness_is_spreading on October 18, 2006, 03:33:23 pm
Well  you gave some good details,  does the car pull at all when normally driving.  When you locked up the front tire,  maybe you damaged the Caliper,  and when you break, it drags more on that side because it may be damaged some how.
But I would check everything and report back anything weird....
Post by: 1slowvw on October 18, 2006, 04:42:37 pm
I'm hoping to be able to check it out tomorrow. Its raining tonight and im living at university so i dont have access to a garage. If anyone else has any ideas i would love to hear them.
Post by: burn_your_money on October 18, 2006, 05:24:30 pm
does it pull either way during normal driving?
Post by: 1slowvw on October 18, 2006, 05:52:11 pm
No it doesent pull if im just rolling, but if i give it gas or break it does, it feels like i have a really bad ball joint and its going in and out of alignment. if that makes any sense at all.
1slowVW
Title: clunking
Post by: Doug on October 18, 2006, 06:34:13 pm
Sounds like a lower ball joint is done.
Post by: 1slowvw on October 18, 2006, 06:41:14 pm
That is what it feels like but it doesent explain the loud clunking noise when I took off.
1slowvw
Post by: burn_your_money on October 18, 2006, 06:56:27 pm
Jack the wheel up and give it a wiggle. The loud clunking may have been your suspension settling, and was possibly unrelated
Title: clunking
Post by: Doug on October 19, 2006, 05:36:38 am
Check the strut top mount bearing too.
Post by: saurkraut on October 19, 2006, 08:51:19 am
I wonder if you lost the inboard control arm bushings or sheared the bolt and the arm is moving enough to put the sway bar into the axel.  Don't drive it until you can see whats broken and fix it.  If you can feel a toe change while driving, something is really wrong.
Post by: 1slowvw on October 19, 2006, 09:00:53 am
Having a new ball joint put in today. And having it looked over by a mechanic(I hate letting somone else work on my car) so well see how much this will cost me. Il let you guys know as soon as i find out what was causing the noise.
Just wanted to let you guys know that it was the brake disk that broke. broke clean in two must have hit a puddle when i was breaking and well you guys know the rest. Anyway thanks for all the help.
                                                          1SlowVW
