Engine Specific Info and Questions => IDI Engine => Topic started by: Benjamin on October 04, 2006, 05:39:42 am
ok, i was doing my (first time) governermod, so i tooked of the top of the pump.
i got the throttle thing with the 3springs:
(http://www.morninglight.nl/a3/governor2.jpg)
so, i looked better, i got the main spring, the intermediate spring, BUT not the little right spring :shock:
is that normal?
is there any need to put a 3th spring in it, (from another pump?)
wherefor is the 3the spring guys?
Greetz, Benjamin
@admin: i didnt know were to place, i even dont know this IS a problem? or not, anyway, i hope to hear where for it is, if this is a problem, feel free to replace in the right section
edit: i think this is the idle spring
Is that your spring setup that you have pictured?
Andrew
no, i found the pic on the net, i miss the right spring.
i just searched a little spring from a sparepump (dont know or the load will be the same), anyway, i hope it gonna run good :x
my pump is whole stock, after i do the governermod, do i need to screw back the feul quantity???????????????????
Greetz, Benjamin
The spring to the "right" is the idle spring. Yes it is needed.
so what happens when you take a stronger or weaker spring?
Greetz, Benjamin
okay, i did the governermod, everything is together, i used a spare spring like i said, the engine runs good as before.
its a big questionmartk for me why the engine could run fine without that "right" spring.
anyway. what happens when the "right" spring is stronger/weaker?
what happens when the left/main spring is stronger/weaker?
Oh, i did the governermod, the quantity screw a bit, the lda adjusted with the starwheel, and the lda is exentric, i got the best side now, its a big big difrence, i try to gtech one of these days when the weather is better.
Greetz, Benjamin
Greetz, Benjamin
when the right spring is stronger or weaker it will just take longer for it to correct your idle speed, when the right spring is stronger it will make you rev higher with more fuel for longer, and when its weaker you will rev lower, more or less the left spring is the rev limiter, i think anyone feel freee to correct me, i am just going by what i have read and my understanding of the workings of the injector pump
guys,
i Gteched when the engine was with stock settings, my fastest 0-100km/h was 11,5.
last night after doeing the governermod, lda, starwheel, feul quantity, a little bit wet on the street, and 2persons in the car, i did 8,7sec! :D stock T2 turbo! i'm hitting something about 1,2-1,3bar. with a lot of smoke :lol:
i'm realy glad, i think when i'm alone in the car, with good weather, i can do 8sec flat.
DIESEL4EVER :twisted:
Greetz, Benjamin
i bet youre easily doing a low 16 with that 0-60
