Engine Specific Info and Questions => IDI Engine => Topic started by: Op-Ivy on September 16, 2006, 01:26:21 pm
Title: Bringing the 1.6TD Idle Down?
Post by: Op-Ivy on September 16, 2006, 01:26:21 pm
I did the "smog" mod and increased my fuel a bit. My idle is now higher(I know this is normal)
What screw do I turn to bring it down? I can't figure it out :P
Thanks, Matt
Post by: Op-Ivy on September 17, 2006, 12:12:11 pm
Anyone?
Post by: andy2 on September 17, 2006, 03:30:22 pm
Smogs thread for the 1.9 is the same as the 1.6.The #7 screw is what you will use to lower your idle.Be careful as this adjustment screw is usually seized up.Spray it with penetrating oil and work it back and forth very carefully as part of it is plastic.I believe that turning clockwise lowers the idle.
http://vwdiesel.net/phpBB/viewtopic.php?t=579&start=0
Post by: BellCityDubber on September 17, 2006, 10:49:50 pm
Quote from: "andy2"
When I did my adjustments, #7 didnt do anything for my idle, but I moved #6, and it seemed to do the trick
Post by: andy2 on September 18, 2006, 09:17:24 am
If the #7 screw doesn't seem to back down the idle it may be that its sitting on the #8 screw's stop.In which case the #8 screw would need to be backed out to lower the idle.The #6 screw shouldn't need to be touched unless your really screwing around hardcore with the pump :twisted:.
Edit:My mistake turning #7 counterclockwise lowers idle.
Post by: Op-Ivy on September 18, 2006, 03:43:03 pm
Thanks for the input guys! Lowered it a bit and sounds about right now! I don't have a tach (clock) so I can't tell for sure what its at.
Post by: zagarus on September 18, 2006, 04:05:41 pm
well we should get you a tach shouldn't we.  easy hook up, i think  :P
Post by: Op-Ivy on September 19, 2006, 07:07:39 am
Haha I'm with you on that one!
