General Information => General => Topic started by: 935racer on August 22, 2006, 10:45:59 pm
Example:
V E 4 / 9 F 2400 L 12
V: Distributor injection pump
E: Axial piston high pressure pump or R: radial piston high pressure pump
2-6: Number of high pressure outlets
8-12: Pump plunger diameter in mm.
F: Mechanical governor or E: Electric actuator mechanism or M: high pressure solenoid valve.
2400: Upper pump nominal speed (half of engine rpm)
L: Counter clockwise or R: Clockwise (view toward pump drive)
12: Type code.
This really helps to get the number Dave is talking about.
http://ecat-online.bosch.de/toc/frame1.html
Peter
Alright, I got some spare time between working, changing diapers and trying to finish off a basement remodel, to start working on my TD build. I pulled one of the IP's off, and cleaned up the id plate on the other to pull the numbers off. I cant seem to use the product decypher/ID that you posted Dave in order to figure out what I have.
Once I get the new digital camera software loaded on the computer I will add some pics.
Here's what I have:
I am not sure what year these came out of, one may be a 92.
Pump #1
NR 0 460 494 182
R 223 BT 4007
VW/Audi 068 130 130 081F
015 644 39515
Pump #2
NR 0 460 494 162
VE R 188
VW/Audi 068 130 110H
011 541 189 68
Gonna do some more searching, and more head scratching. :? I am trying to determine which is the best pump for the Giles mod.
Thanks, Jim
