Engine Specific Info and Questions => IDI Engine => Topic started by: vwpieces on May 13, 2026, 02:18:05 am
I have been running 1.6L TD's in a MK1 for 20+ years and know those pretty well. Also have Spare Parts.
A few months ago a 1Y short block came my way. Nice condition too. I want to use "what I have" if at all possible.
How much Taller is the 1Y compared to the 1.6TD? and am I correct in thinking the height difference is all above the IP mounting bracket holes on block?
Only 1.6 hydraulic head in the hoard is not great to say the least. It is flat but the usual cracks between seats. And there are hairline cracks in the prechambers. And the cam has pits starting on 4 lobes. Exhaust valves are Real Hard to find in USA, But I dug deep and found Int and Exh valves. Did New guides and cut the seats, I already had a new set of the INA 034****** lifters... just need a cam. Finding an 068109101L cam in USA, good used or New has eluded me. I have taken some basic measurements, comparing an 068109101W solid to the L and other than slight ramp difference, W is very slightly flatter as it approaches the lobe tip. I ALSO see PartsPlaceInc selling One cam for solid and Hydraulic heads... The cheepAss in me wants to just put the W in the Hyd Head.
As for a cam, I did see Cascade German has a cam they say will work on a 1.6L It is the 028109101F, 028109101C, 028109101G, Stock Eurospec camshaft for all VW TD AAZ and TDI 1Z/AHU engine codes.
Note: On AAZ's you will need 1Z/AHU valves and spring.
Fits the following:
1996-1998 Jetta, Passat, Golf TDI
1993-1996 Jetta, Passat, Golf TD (AAZ)
Also fits 1.6L TD - read on TDIclub and VWdieselparts on how these work in 1.6L engines! You would want to get our hydraulic lifters to go with it too!
As quoted from the ebay listing.
So is this a drop in cam for the 1.6 hydraulic head? I searched all those part numbers on this site and nothing 1.6 head related.
Or should I just give up on a Cam for the 1.6 and buy a complete Chinese AAZ Head off eBay for $260 to $320
Other parts I have and would want to use if possible
1.6TD pump with LDA
Have a spare set of 1.6 TD 155bar injectors I have new nozzles in and pop tested.
I think the 1.6 TD injector hard lines are a possibility? or AAZ?
Conti timing belt 028109119P
068 head bolts and timing belt tensioner I already have and I think are correct to use.
Piston protrusion is 0.9144mm and I believe that is 2 Notch, 028103383BKJ, ELRING 914856
Using the 068 cam gear, pump gear OK? Crank timing gear is the one from the 1Y.
Pretty sure None of my timing belt covers will work and I have some MK1&2 types on hand.
I should be covered for clutch/flywheel in 200 or 210 if I want to go there.
Misc gaskets and seals I should have, but oil filter housing to block I might not have, with the offset top hole.
I know a couple guys from vortex will recognize me.
Thank you in advance.
Yeah, I know ya, we go back a ways. I'll try to help.
So the 1Y is the NA (non-turbo) version of the AAZ right?
Both are IDI?
I'm not sure how much taller the 1.9 is.
I've heard it's the block that is taller so you might be right about everything above the injection pump mounting bracket being taller.
So I don't think the injector lines from the 1.6 will work. Lots of bending and they don't bend easy or like it.
Someone on here recently bought a set of 1.9 injector lines that they were real happy with.
But I can't think who or which post.
I'm going in the opposite direction.
A friend had his AAZ throw a rod though the block on his MK2 jetta and I'm putting one of my old 1.6TD engines in it's place.
I can't image the head surviving that and still being in good shape.
I was thinking a mechanical head will fit on a hydraulic block.
But not if you are putting it on a 1.9.
The head gasket holes for a mechanical head are too small for the pistons.
So Cascade German says their cam will work on anything 1.9 including AHU TDI engines?
That kind of makes sense since they are all 1.9 engines.
I have heard the cams on the hydraulic heads were made of a metal that was too soft or not tempered right and it is common to find the lobes worn.
I'm not sure how the timing curve for the 1.6 pump will work with the 1.9.
You could probably swap the timing piston springs and washers from one pump to the other and get close to the same timing curve.
Oh that's right your engine didn't come with the pump.
If it gets clacky at higher RPMs you could put another washer in or find the proper spring size somehow.
Slight cracks in the prechambers can be scary they don't worry me as much as cracks in the head around the prechambers.
The 1.6 hydraulic head has way smaller prechambers so the compression will be high with a 1.6 in a 1.9.
Several people have swapped 1.9 heads onto the old 1.6 blocks and the compression was so low it wouldn't start on a cold day.
I pulled a 1.9 prechamber once and it was at least twice the size/volume. Maybe triple. I could fit my finger in it quite a ways
So I'm not sure just a cam is the solution. Not sure what that high of compression would do to a 1.9D.
The expensive way to go:
https://tornau-motoren.de/en/e/EF/cylinder-heads/cylinder-head-complete?make=VW&model=GOLF%20III%20(1H1)&motorType=1.9%20D&carId=1866&powerKw=47&ccmTech=1896&yearOfConstrFrom=199111&yearOfConstrTo=199708
Didn't know AMC is still making heads.
I think the 1.6 cam sprocket and injectors will work.
Did the crank sprocket on the 1Y have the flat spot type keyway or the old 8mm wedge like the AAZ?
That was a trouble spot for the AAZ.
Pretty easy to upgrade to the flat spot and later TDI sprocket. I had a special tool made to broach it while the crank is still in place.
It will be interesting to see how the timing belt covers work out.
I can check with the guy and see how much of the AAZ parts he wants to sell or trade for 1.6 parts.
I'm a little short on 1.6 timing covers and am curious if the lower one is the same as the AAZ.
Looks like the 1.9 lines came from brickworks:
https://vwdiesel.net/forum/index.php/topic,47169.0.html
Not trying to knock the OP's topic astray, but fatmobile... your statement, "Pretty easy to upgrade to the flat spot and later TDI sprocket." has even broader interest for any who do not wish to re-experience the 'mangled keyway' saga on another engine... EVER! So, 1) What is the correct part # for the "later TDI sprocket"? 2) Will it fit an IDI 1.6n.a. / 1.6td crank? and 3) Can most automotive machine shops accurately broach/machine a 1.6L crank to fit such a sprocket?
I believe it had a D on the end of the part number. I remember because it is D-shaped.
But that might have gotten superceded with an E sprocket.
It's the sprocket for the AHU engine and does fit the 1.6.
I'm not sure how many shops can put the proper flat spot on the end of the crank, if the crank is off the engine.
I had a shop try and made it too sloppy for my liking.
So I had a fixture made that would hold the broach steady and cuts it to the perfect depth.
you actually kinda have to tap the sprocket on.
It works with the engine still in the car.
Just lent it to my friend in MPLS he used it unsupervised and it worked great for him.
I've thought about renting it out, but I'd need at least a $500 deposit (I'm not sure I could get another perfect one made for that much) and $50 for the rental.
(https://live.staticflickr.com/65535/49804233126_e83352001d_b.jpg) (https://flic.kr/p/2iT2HmA)
(https://live.staticflickr.com/65535/49803678343_c2aae27021.jpg) (https://flic.kr/p/2iSYSrn)crankkeywaycutter_2 (https://flic.kr/p/2iSYSrn) by vwfatmobile (https://www.flickr.com/photos/147103123@N05/), on Flickr
Thanks for the info, fatmobile. Would that be #06A 105 209 D (or, now... "E")? May have found a pic of a sprocket with that stamping. Crank is not in the engine yet, so will buy a pulley & see what some local machine shop friends think about their own accuracy on this. The broaching location on the crank seems non-specific, other than avoiding the oem keyway slot... right? Will be glad to work around the earlier keyway design that has cost a couple of engines.
Right, you can put it anywhere around the nose of the crank.
Usually the crank sprocket bump will be at 7:30 when the engine is at TDC. That will change.
I once got a free MK2 Jetta because of the crank issue.
I'm not much help with the part number.
Oh wait,.. the crank sprocket # on the AHU project is 028 105 263 D.
hey Nick hows it going? We spoke last year at volksfest and then you sold me the bracket for a mk1 1.6td air box.
the height difference is above the pump bracket, im not sure exactly what it is but its the same difference as a 1.8 jh vs an aba engine, and also the same deck height as a tdi.
you can run the 1.6 injectors, pump bracket, and pump. 1.6td or aaz lines could work but they will both need to be bent because the 1.6 lines are too short and the aaz lines are too tall because they had the taller 2 stage injectors, unless you can find the uncommon early aaz lines for single stage injectors but keep in mind some pumps had longer delivery valves.
i have some aaz stuff left over from my last engine, like an upper timing belt cover thats already trimmed for a mk1
Have not received any notifications. Changed to my gmail and did not receive notification of last reply.
Also needed to get image hosting figured out again. ;D
Can anyone confirm that this is a piston from a 1Y engine? I have spent a lot of time searching and get no other similar pistons. I can not see how this dish can allow a diesel to run.
(https://imgur.com/fU78OWIl.png)
They are VW DE but no identifing marks that suggest a part number. 24mm pins and 79.5mm "ish" diameter.
They Are factory notched for the oil squirters too.
These also match up with diesel protrusion, should be 2 notch gasket. IIRC it was 0.9144mm... from memory, Old memory.
Pistons are like new, rings barely worn. I see no skirt wear.
This short block has very little miles but there is evidence these pistons indeed were run on diesel.
(https://i.imgur.com/hEWRS9Cl.png)
(https://i.imgur.com/uBIaC0Sl.png)
AAAND Monster Image FAIL
Sorry... Fixed it.
(https://imgur.com/R9BGhMOl.png)
Learning all over again.
Craig, message sent but messing with the pic in here. Resizing tricks....
Things have been moving along but hitting walls.
Latest and #1 wall, is the pistons in previous reply.
Also moved past the 1.6: hyd head and Splurged for a Chinese head off ebay. Actually made an "offer" late night and damn it... it was accepted. $255 shipped on an Complete 1.9L AAZ chinese head.
I did have to spend 2 hours deburring all the flashing machining smear. Complete disassembly, quick lap on a few valves for sanity and they actually looked good. Guide fit and all.
Just cant leave things alone and Had to clean up the ports and bowls. Damn tiny exhaust ports compared to the 1.6L heads, yet bigger intake valves. Cam made me cringe with the very sharp edges on lobes. I did file them to prevent chipping but opted to buy a New cam I linked in first post, from Cascade German. Very nice! Also had a New set of INA 034 lifters in the hoard and used those to complete the head.
First pics of the Chinesium, honestly I wasn't disappointed.
(https://i.imgur.com/x9VerJ6l.png)
(https://i.imgur.com/dcGjot0l.png)
(https://i.imgur.com/OrE6eRbl.png)
BURRZZ everywhere
(https://i.imgur.com/6g2riQ8l.png)
(https://i.imgur.com/zoEzZr8l.png)
(https://i.imgur.com/GJePlGBl.png)
(https://i.imgur.com/KXwB9zyl.png)
This was a joke sent to a couple friends.
A Day at the HyKolity Masheen Schop. Flo Bhench testin.
Cant say it is accurate but it did show the ported intake about one red floater thing higher than stock bowl.
(https://i.imgur.com/81a4jyPl.png)
Some bowl work.
(https://i.imgur.com/dxjmWsAl.png)
(https://i.imgur.com/8Zyjj1ll.png)
Cam arrived today and installed.
(https://i.imgur.com/4fR3vQDl.png)
(https://i.imgur.com/LeOPDUdl.png)
Pics of the rod from the 1Y block and weird piston. Cause I know you want to see Rod pics. ???
It looks like it should be rifle drilled but it's not. Rod caps have 028J on them.
Bushings and bearings look new.
Ordered a set of 45mm rod bolts from AutohausAZ for 3bux ea.
028105425N or ends in C, same, same
Anyone know the rod bolt torque spec off hand?
(https://i.imgur.com/73gkWCRl.png)
(https://i.imgur.com/gleA8YFl.png)
(https://i.imgur.com/b66atoml.png)
Not going to bother taking crank out.
I took off oil pump and saw this.
(https://i.imgur.com/D4BAIYZl.png)
It did turn over by hand and didn't feel anything before removing pump. Put it back to see, and here are pics.
(https://i.imgur.com/2Uge6uDl.png)
this is an 049 pump that was in there
(https://i.imgur.com/P9bvNkrl.png)
I have a good VW 026 pump and it clears rod bump. Bigger gears too.
(https://i.imgur.com/KSjwzkCl.png)
clears
(https://i.imgur.com/hzSrUu4l.png)
(https://i.imgur.com/ZQBJzmyl.png)
I think I figured out the pistons.
They certainly are the ones that came in this engine.
Someone Cut the dish into them. Why? My only conclusion is they were going to run crazy boost.
If you stare at the pic, and imagine the 2 circle pattern on top of all IDI pistons. The 2 outer notches and the top part are all that is left.
(https://i.imgur.com/L5pF2hnl.png)
I Need 1Y pistons. :'(
Standard bore, 79.5mm
That seems like a great price on a new head and it sounds like the quality isn't too bad.
Maybe they were going to run a 1.6 head on this block so they machined the pistons,
to lower the compression because of the smaller prechambers.
I'm going to dig through my hoard and see what I have for timing belt covers for the MK2 I'm working on.
Sounds like you have someone local with a 1.9 upper cover, your lower cover might be the same as a 1.9.
I'll check if I have a MK2, 1.6 lower timing belt cover to compare it to.
That would leave you just needing the 1.9 tin cover.
You going to put a turbo on it?
Absolutely.
I was prepping TD exh manifold and a 171 TD down pipe last night.
Mocking up parts to block to get an idea of whats Not going to work
No harmonic balance damper pulley. I have a V belt damper from 1.6 TD but pass. The 1.6 I'm running now I did not use one either.
VW logo INA T-belt tensioner pulley found in the hoard. Think the WP pulley is NOS too, 068***K I believe is the number on it.
(https://i.imgur.com/NkBi79hl.png)
No non AC alternator bracket to mock alternator but have crank and WP pulley alignment sorted. Hard to get the cast iron ones anymore. May need to just use the one on car currently that I fitted a 90A alternator on.
Think the 30mm WP is Graf, says Hecho in Germany on it... seriously, it does. Metal rubber later gasket to housing and stainless bolts.
(https://i.imgur.com/tRVpOyQl.png)
Dug up a really nice set of 1.6 TD injector lines. And as predicted, they don't fit. But if one needs to mod earlier lines, these would be it because they have places where some length could be made. More squiggly's or service loop length than NA 1.6 lines.
(https://i.imgur.com/SF9r5dFl.png)
(https://i.imgur.com/QJbau8Yl.png)
Ordered a few N90577101 crank bolts (47mm), 12 point with the Nub on end. About $3ea from AutohausAZ, Only to realize they used the older 1.6 TD crank bolt previously and it is 56mm long. Head is hammered from impacting, on/off a few times in it's life. But I think I am going to use the Earlier bolt again, saw a new one on ebay for $15. The couple I have in the stash are just as hammered as this one. This one also took the Big Boy M18 Milwaukee to get it off.
Even with the early HD bolt and being stoopid tight, I can still see signs of movement. Also looks like the mating surface on crank gear is Not flat. MIM or metal injection molding flaws, mold flaws, just wear? I dunno.
(https://i.imgur.com/ZdpoZMGl.png)
Found this 068105263C crank gear in the hoard. It is identical in every measure to the 028105263 I took off. Got it... Use It.
(https://i.imgur.com/PzD5wXul.png)
Did some deep digging and I came up with a new set of pistons, here in USA! Correct 24mm pins. NPR Europe brand. I have used the brand before and Shouldn't be made in China. Beat PPI price by around $100 to my doorstep.
I think you should use the later TDI crank sprocket.
With the flat spot.
Those crank sprockets were a known failure point for the AAZ and 1.6D.
You'd have to make a flat spot on the crank but I can send you my special tool for doing that.
The AHU came with a serpentine belt setup. I'm not sure how it works with a non-AC setup.
Otherwise I would use the MK2 alternator setup because the alternator is a 90 amp one.
The weekend is over so I'm going to start pulling the 1.9 apart and swapping it over to the 1.6.
I'll start a thread on the topic take some videos and pictures.
Also need to get the rest of the garden in.
I'm going to keep the notched crank timing pulley as is. Not going to have any substantial weight on crank snout and also only going to have one V-belt to drive. I DO have a New 6 point longer 10.9 grade bolt ordered.
Crank bolt differences
(https://i.imgur.com/bogbE3ul.png)
A Few parts cleaned up.
(https://i.imgur.com/nptpgeKl.png)
(https://i.imgur.com/NhOtnYMl.png)
(https://i.imgur.com/Z1T1ZnXl.png)
Couple sets of AAZ injector hard lines in the parts score. One set really rusty and did some chemistry test on them first.
(https://i.imgur.com/1Czrmszl.png)
UGLY
(https://i.imgur.com/DIvmR5Sl.png)
Did use the ultrasonic cleaner
(https://i.imgur.com/hF7sprkl.png)
Heated and did make some black phosphate on surface. But no rust anymore.
(https://i.imgur.com/NR6UA4Rl.png)
This is the nicer set I am going to use. After about 15min in ultrasonic solution.
(https://i.imgur.com/2SK4Shgl.png)
I went a bit further to blacken or cold blue this set. Also dug up an IP with longer delivery valves and these lines fit perfect.
(https://i.imgur.com/spBINuPl.png)
More Mock-Up and seeing what fits. 028 IM pulley and 068 IP pulley work.
(https://i.imgur.com/xm8vpO2l.png)
(https://i.imgur.com/y8gDxHDl.png)
But now to take it all apart and try to get timing covers to fit. I have a funny feeling I will need to use the AAZ IP bracket and Cut off the MK1 IP/engine mount. Todays adventure.
New pistons Will be here tomorrow.
Tried searching...
But I did notice the longer delivery valves I stole off an ECO IP have some really small holes. Anyone know if this is ultimately gong to be a restriction point?
Eco DV
(https://i.imgur.com/vOr2Mwol.png)
And the one off the 1.6TD IP
(https://i.imgur.com/RzKpb7ul.png)
Any hole that size will have two effects. Less delivery at the same pressure or equal delivery at a higher pressure. Given the IP has plenty of push that really can't be increased by much, I would say you are going to get less fuel to the injectors compared to the stock 1.6 ones.
Is that the only injection pump bracket you are using?
I think there is supposed to be one bolted to the front of the block too.
I'm not sure the bolt pattern on the front of the block allows the 1.6 bracket.
I believe if that bracket isn't on the front of the block, the belt will probably track off the sprocket.
The difference between the AAZ and AHU pump brackets is
the one on the AHU has a place to bolt the extra idler pulley that goes between the cam and injection pump sprockets.
I took some video of the different setups but haven't edited it yet.
Should have taken pictures.
I have a 1.6, a broken AAZ, an AHU (that's going in a certain grey GTI, yes I still have it) and an ALH block all in the same area.
I might as well do a video on the differences and similarities.
Yes there is another bracket, hiding behind the IP. It does the rear supporting of the IP. And Yes it fits my 1Y block. However that all quickly got scrapped when I decided to try to install the timing cover inner metal.
Last Mockup with inner timing cover revealed I can not use the MK1 1.6 Diesel IP/engine mounting brackets. Now going with a gasser passenger side engine mount and a small diameter hole, cast iron AAZ IP mount. Smaller hole is same as the 1.6 injection pumps. I also flattened the front end of the gasser side engine mount in the press. I was looking for an alternator bracket to hack off the side that goes under the gasser engine mount but didn't find one in the hoard. Considered washers but then just flattened it in the shop press. But I did score a Non-AC Diesel alternator bracket I did Not know I had. I have one on the 1.6TD in the Jabbit but remember needing to source it on that build. Those AIN'T easy to find anymore.
Quickie mock-up, only pic I took with inner timing cover fit and the AAZ small hole IP mount that fits the 1.6L IP.
(https://i.imgur.com/trAzK1Vl.png)
Blasted and most painted, another mount pressed in that gasser bracket too
Mount press tool and air over hyrdaulic press... like cheating. VW tool number US745
(https://i.imgur.com/cVQGD2Vl.png)
(https://i.imgur.com/GPd4hu4l.png)
(https://i.imgur.com/KJ9UkfWl.png)
Flattened gasser mount
(https://i.imgur.com/bMRAiiRl.png)
All blasted and now painted, just need to paint the opposite side of the inner timing cover yet.
(https://i.imgur.com/lLteXAgl.png)
And I was real happy to find this mount in the hoard. Didn't know I had it.
(https://i.imgur.com/NjIHflGl.png)
New pistons should be here Today! 3:30AM, off to get "some" Sleep.
Those non-AC alternator brackets are hard to find, glad you found one.
I have one with a place a for power steering on the bottom, even more rare.
I'll probably never put power steering in a Rabbit but I can, ha.
I'm going to try to use the AAZ alternator bracket so it has a serpentine belt setup,.. but it will only have 3 holes mounting it because the top right threaded hole is missing on the 1.6 block.
I just cut the MK1 injection pump bracket short to make the MK1 motor mount:
(https://live.staticflickr.com/65535/55308347215_b0ff5ab2cb_b.jpg) (https://flic.kr/p/2sgpJHn)
The AHU alternator bracket has an ear to bolt the extra idler to:
(https://live.staticflickr.com/65535/55307039062_d24040f4ed_b.jpg) (https://flic.kr/p/2sgi2R1)AHUinjectionpumpbracket (https://flic.kr/p/2sgi2R1) by vwfatmobile (https://www.flickr.com/photos/147103123@N05/), on Flickr
Good to hear the 1.6 pump will fit that mounting bracket.
Moving along... Last couple days work.
New pistons installed. New rod bolts etc.
Head is on and torqued. One notch MLS head gasket...
(https://i.imgur.com/HGFmHeMl.png)
Intake installed, upper elbow in an NOS 068 from the hoard, rubber hose too.
Exhaust manifold on and torqued.
Didn't fully torque that turbo down, yet. Also need to dig out the correct support bracket for the 171 down pipe.
(https://i.imgur.com/FhuKbjol.png)
(https://i.imgur.com/GPgID1nl.png)
(https://i.imgur.com/jL0b8P0l.png)
Moved on to fitting some 1.6TD oil return lines to the NOS oil pan. There were 2 pans, different angle on the fitting on pan and each used a different oil return tube.
Uncrimped the SS braided hose from the required return line to fit this pan. Taller block so it needs lengthening. New hose should be here tomorrow. 3 Otiker clamps at each end will be adequate.
Had to align the tubes.
(https://i.imgur.com/1rW9RR6l.png)
(https://i.imgur.com/x0XmaXol.png)
Decided to use a -4 AN line for the oil feed to turbo. Line and all Stainless steel fittings arrived today. Still waiting for the SS banjo to -4 for top of oil filter housing, Stainless bajjo bolt too. Fitting for top of turbo to AN is steel. SS for that was elusive in my search. Well, did find one in Taiwan for a few bux but wasn't going to pay $20 shipping plus fees.
(https://i.imgur.com/nx4jzJFl.png)
Did all the coolant hoses I can. Local parts store had all the hoses and even an NOS water pipe In Stock. ::) ;D
OK, Parts store is in the second floor of MY shop.
Coolant necks and temp senders too.
(https://i.imgur.com/1vWaFpxl.png)
(https://i.imgur.com/dSLhqcSl.png)
And a Few more little things.
Injector line clamps, injector return hoses and NOS German Hella oil presure sender.
(https://i.imgur.com/zBAK8S6l.png)
(https://i.imgur.com/WOAQIbzl.png)
Looks like you remembered to put the T-bolt in the waterpump before putting the alternator bracket on.
Ha. Hate it when I forget that after all these times.
Moving right along quickly.
It looks great.
Took me hours to find the little standoff for the MK2 upper timing belt cover.
But I got a chance to organize fasteners, inventory the hoard and did actually find one.
Is you lower timing belt cover from an AAZ or AHU?
I'm thinking AHU.
i sold him some of these bits, the lower cover is off of the ahu that's currently in my car. I think the aaz and ahu lower covers are the same or close enough, i used the aaz one on my ahu because it was already trimmed for running a v belt. 1.6 lower cover is different, the split where it meets the upper cover is more of a straight line where the aaz/ahu has kind of a z pattern
It looks great.
I'm thinking AHU.
Of course I remembered the "T" bolt.
After the alternator mount was on.
But you missed the upsidedown motor mount.
This thing has been apart and back together so may times now. Just wait till the next time it's apart to address that too. And that, and that ..
Only remember ya saying TDI, don't know engine code. Had to open center hole for the cast 068 pulley. Might need to remove the metal ring to clear the V belt too. Need to dig out an alternator. 90A on Jabbit, same bracket, and had to custom make an adjustment arm. Going same route here.
And had to post this one.
(https://i.imgur.com/zjEU5wPl.png)
(https://i.imgur.com/Vun2YaAl.png)
I have both covers (and a few 1.6 lower covers) here and I like the AHU one better.
It looks stronger around the pully. Sounds like that makes it hard to use with the V-belt crank pully.
Makes sense, it's opened up a lot on the AAZ lower cover.
Glad he has someone local helping him with parts.
These 1.9s are rare and can be hard to find parts for in the US, especially plastic parts.
Oh that motor mount is upside down, dang it.
I fill the gaps in mine with urethane. Almost impossible to find the V-shaped heavy duty motor mount.
Parts geek said they had them for $35, then sent me the weak one they had for $10.
Refused to make it right so last time I bought from them.
The head on the broken AAZ I'm playing with has a KS head on it.
I really hope it survived,.. but a thrown rod can cause a lot of damage.
Managed to get the engine mount out with minimal paint damage. Hacked up a rusty mk1 diesel mount and sliced to be the receiver. Also used a chopped old mount to press with.
(https://i.imgur.com/DJyjoJGl.png)
New main bolts arrived today. Had the old ones torqued to 48ft/lbs just temporarily.
Bolts in, NOS VW 026 oil pump, windage tray and NOS TD oil pan all buttoned up. No pics before pan went on.
(https://i.imgur.com/oiAk45Rl.png)
Running out of SHtuff to do :o
Today was more fixing things already done... Mount re-do and then found out the oil filter no fitty. Hits that curly hose from the water pipe.
MK2 pipe needed some re-bending, hose from WP to pipe shortened. Febi part, don't remember needing that on the Jabbit.
But it fits now.
(https://i.imgur.com/AzqAfLTl.png)
Turbo clamped down, and the mk1 special support bracket to the cast iron DP installed.
(https://i.imgur.com/wuKZkw5l.png)
Waiting on hose for drain pipe and oil feed fitting to AN for feed. 2 more glow plugs and the buss bar to install.
Oh, yeah, that bushing barely hanging on the alternator mount reminds me.... Alternator!
(https://i.imgur.com/nPY27hXl.png)
(https://i.imgur.com/oDWpQHrl.png)
(https://i.imgur.com/DdEjiR0l.png)
Need to clean/straighten the tin between engine and bell housing. Sort and dig up some flywheels, clutch parts etc.
And clean up the damn mess in the big shop from digging up parts. Take back and put away all the SHTuff I brought into basement and didn't use. That'll be a Few days work. Maybe the fittings will be here by then.
Anyone ever see one of the On a Bentley.
Not in the Bentley. ;D
(https://i.imgur.com/IX8d62Xl.png)
(https://i.imgur.com/G7zkc2Rl.png)
Cool tool!!
Dang, chop,chopchop.
To press in MK1 motor mounts; I use flat plates with a hole to clearance the bushing center bump.
I have one of those belt tension checking tools.
Don't really use it anymore.
I adjust the belt so it doesn't vibrate a bunch between the crank and tensioner when running.
Using the MK2 metal waterpipe? How's that going to work with the starter/ front motor mount?
Craig, forgot to ask earlier. What Polyurethane do you use to fill the side engine mount?
It works, 6 years maybe? on the Jabbit.
I may have used the same on the 83 TD jetta too, that would have been 20 years.
need a reducer hose at the end to heater, think it's the 16V scirocco part. 533121623
I just cobble what I have and cut what fits for that one. Hose hoard is extensive. Big box of smaller ones up stairs.
V-belt collection is the other side of the stairs, wraps corner and 3X if counted by piece.
Local parts store usually has what I need in stock.
But that is where figuring out what I did or used 3, 5, 10 years later gets hard when you just use what you got and it fits. I would need to go back on vortex to see what serpentine pulleys I used on the 16V in the 2dr Jetta. Jabbit is right outside in this case...
Jabbit pipe and mount
(https://i.imgur.com/SVrzNpjl.png)
Get hosed... Here ::)
(https://i.imgur.com/V1z9CjQl.png)
(https://i.imgur.com/9SS0zyNl.png)
The Jabbit... not a typo. Guess I should have posted this earlier, for those not familiar.
Jetta hatchback. ;D
Quick story, I got a free rabbit. It needed fenders. Welp, I had Jetta fenders and was parting the rusty 83 TD Jetta I winter drove for 20yrs. Those fenders were junk but the front core support was salvageable.
(https://i.imgur.com/5HSTOLSl.png)
(https://i.imgur.com/MUNmFzYl.png)
I see, the motor mount makes it past the coolant pipe.
I always thought there would be a problem with the MK2 pipe and MK1 starter/mount.
There might be a different pipe/mount combo I was thinking of.
Great selection of hoses.
I have a bucket of them and a few hanging but not all the options like you have there.
That front end looks fantastic on a Rabbit.
