Engine Specific Info and Questions => Diesel Swaps => Topic started by: fatmobile on May 19, 2025, 08:48:26 pm
Title: VNT-15 in a Rabbit
Post by: fatmobile on May 19, 2025, 08:48:26 pm
  I like the VNT-15 turbo and 1.6 diesel combination.
 It feels like plenty of power without being too much for the old 1.6.
 Since they hang so low I can use the gasser intakes with the long runners and larger plenum.
1.6 TD intakes can be hard to find. I converted several gasser to diesels so had a few extra.
 Probably can still find one cheap on the vortex.
(https://live.staticflickr.com/4843/46527921922_871ec014d0_w.jpg) (https://flic.kr/p/2dTvLbo)
 Here's how I attach the gasser intake to the TDI exhaust and plug the EGR port:
(https://live.staticflickr.com/65535/54532199320_4385af7d98_w.jpg) (https://flic.kr/p/2r5PLZ7)vntgasserintakebolt (https://flic.kr/p/2r5PLZ7) by vwfatmobile (https://www.flickr.com/photos/147103123@N05/), on Flickr
 The turbo sits farther to the passenger side so it's easier to build a downpipe that doesn't interfere with the shifter stuff.
 (https://live.staticflickr.com/65535/54532037984_91bc936a58_m.jpg) (https://flic.kr/p/2r5NX2s)
 And the exhaust doesn't need to be shaped like a ?. It's just a 90 where it comes out of the turbo.
 Much easier exhaust to make than for the stock turbo setup.
(https://live.staticflickr.com/65535/54532037419_c70dbc773c_z.jpg) (https://flic.kr/p/2r5NWRH)
 The old 1.5 diesels didn't use the toilet bowl exhaust flange.
 They had 2 support brackets attached to the block and trany, then a flex section.
 I used a set of the old brackets to make this exhaust solid so it wouldn't wrench on the turbo when I get on it.
(https://live.staticflickr.com/65535/54532053739_86640994e3_n.jpg) (https://flic.kr/p/2r5P2H6)
Closer up:
(https://live.staticflickr.com/65535/54532111083_bb1a35be32_w.jpg) (https://flic.kr/p/2r5PjKM)vntunderclose (https://flic.kr/p/2r5PjKM) by vwfatmobile (https://www.flickr.com/photos/147103123@N05/), on Flickr
 Just getting the topic started. Will need to look for old pictures..
 And I have a video showing the controller that I will link to...
If you have any questions, fire away.
Title: Re: VNT-15 in a Rabbit
Post by: drrtybyl on June 28, 2025, 10:03:37 am
I remember seeing your post detailing your setup -- the vane control is mechanical with linkages? Are you still running this setup -- do you have boost/vane presets, or do you leave it fully adjustable from the cab?
Post by: fatmobile on July 01, 2025, 10:17:52 pm
 Yes, I'm still using this,.. when I'm done doing some front end and brake work.
 It's just set for this altitude.
 If I go into the mountains I have to get under the hood and make an adjustment.
