Engine Specific Info and Questions => IDI Engine => Topic started by: homerj1 on October 08, 2024, 10:05:03 am
Title: IP pump Id
Post by: homerj1 on October 08, 2024, 10:05:03 am
Can anyone id if this is a 1.6td pump or a AAZ pump?
Thanks
(https://media.kijiji.ca/api/v1/ca-prod-fsbo-ads/images/fe/fed591ba-09b8-4e6a-be5f-7b6623a86617?rule=kijijica-640-webp)
(https://media.kijiji.ca/api/v1/ca-prod-fsbo-ads/images/ba/baef0b2f-4ab7-467b-ba95-f4cf995d0b9d?rule=kijijica-640-webp)
Title: Re: IP pump Id
Post by: RabbitJockey on October 08, 2024, 12:13:32 pm
this looks like an aaz pump because of the shape of the "snout" or nose. a part number would be the best way to tell
Post by: homerj1 on October 08, 2024, 03:10:54 pm
There are no id #s on the pump except for
 " The numbers i can find are...
468 stamped into the housing beside the fuel inlet.
& CHJ 0631 printed on the delivery head"
The above is from the seller of the IP. Also the pump was rebuilt, not used & stored for the past 10 years, so I figure the insides might be a bit gummy?
Post by: RabbitJockey on October 09, 2024, 05:31:43 am
Its possible that it's gummy, I bought one that had sat for about 4 years and the governor weights were stuck in it. it was an easy fix. I still have this pump if you'd like to buy it. I ran it until 2017 when the engine failed, then it sat in the car with fuel in it until about 1-2 years ago, since then it's been stored in my garage, it has a vanagon-style throttle lever on it
Post by: homerj1 on October 14, 2024, 05:49:50 am
PMed you RabbitJockey
