Model Specific Questions and Info => MK2 Golf/Jetta and Audi 5k => Topic started by: Sawbones on February 17, 2024, 09:59:12 am
I have a 1986 Jetta 1.6 NA diesel. It used to be an AC car. Previous owner stripped everything and it came to me with a waterpump and alternator that didn't line up with the crank pulley. I went through a bunch of nonsense and got everything in line but I'd like to have the proper single belt setup. If I were to walk into a part store I wouldn't be able to say what belt I need for my crank/waterpump/alternator nor would I be able to say what alternator I need. Can I get the parts from a Rabbit diesel or MK2 diesel and bolt it on, off to the races? My alternator is a long shaft motorola but it used to be a Bosch and I don't mind swapping it back if needs be.
What all do I need? I think crank pulley, waterpump pulley, alternator but if there's other things, I'm kind of at a loss.
I think there is a writeup in the FAQs.
Just rotate the AC alternator down, grind a little so it will go down farther.
Use a ford double pully and the same AC belt.
Along with some creative adjuster bar stuff.
I put this non-AC, MK2 stuff on all my MK1s.
I was looking for a writeup on it. I'd think there ought to be several but maybe they're buried way back. I had to shim my waterpump pulley about 1/8" out from the engine and that put it dead nuts on. Then I used the deep alternator pulley and machined off about 1/4" of the big spacer in between the pulley and alternator. That put it very close but could use probably a 1/64" shave. I'd like to have the factory gear from a non-AC vehicle so there's no confusion when ordering parts. I'd figure it could be taken from a Rabbit diesel or any other non-ac diesel but I don't know for sure.
I always have a hard time finding the link to the write-up/DIY.
