Engine Specific Info and Questions => IDI Engine => Topic started by: 93Ford on September 19, 2023, 06:58:38 am
I need the torque specs for the intermediate shaft pulley, injection pump mounting bolts, injection pump pulley nut, and the timing belt tensioner nut. Also should i use any loctite on any of the bolts/nuts. 1985 vw jetta 1.6 na diesel
33ftlbs for the I-shaft, tensioner and cam bolt.
I use blue locktite on the I-shaft seal carrier bolts and I-shaft bolt.
I just snug the injection pump mounting bolts/nut.
The Bentley is worth having.
IF you have VW keys you should have a Bentley Manual.
