Engine Specific Info and Questions => IDI Engine => Topic started by: 85bertajetta on November 08, 2022, 06:39:43 pm
Title: 1.6td mf block injection pump
Post by: 85bertajetta on November 08, 2022, 06:39:43 pm
I'm having some issues with my injection pump. It sat with water in it and has some rust.
Is there a different pump, maybe from a newer engine that's easier to find that will work for this unit?
 I'm also having issues getting the pully off, so I might have to cut that.  Any input would be appreciated
Title: Re: 1.6td mf block injection pump
Post by: fatmobile on November 08, 2022, 07:47:10 pm
Any bosch rotary from a 1.6 VW diesel will work.
 Have you tried a gear puller on the sprocket?
Post by: oblique on November 16, 2022, 06:32:57 pm
Does this include NA pumps? Just to avoid confusion because they are easier to find at junkyards, etc
Post by: fatmobile on November 16, 2022, 09:35:07 pm
Right, you can use an NA pump.
 It will smoke more before boost kicks in.
