For Sale/Looking For => Parts for Sale/Wanted => Topic started by: TW on July 31, 2006, 06:58:23 am
Title: FS 5 Cylinder NA Diesel Parts
Post by: TW on July 31, 2006, 06:58:23 am
Block, recently bored out:  Crankshaft, rod bearings ground to 2nd undersize: 3 (possibly 4) almost new oversive pistons and rings, 5 rods, main and rod bearings (If you want the crankshaft and rods): Oil pump(used for 200,000 miles): Intake and exhaust manifolds:  K&N air filter and air box.  5 good injectors and glow plugs.  Also have cracked cylinder head.  Make me an offer on all or some of these items.  [email protected]  320-260-5298
Post by: addautomotive on July 31, 2006, 07:25:12 am
Flywheel?
Post by: TW on July 31, 2006, 09:02:17 am
I used the flywheel on the Turbo Diesel
Post by: itzdshtz on July 31, 2006, 12:26:32 pm
Hi, do you still have the cyl.head and how bad is it ? Herman
Post by: TW on July 31, 2006, 05:00:57 pm
The Cylinder head had a crack that filled the number 5 cylinder with antifreeze.  I never had it checked to see how bad it was.  Most head rebuilders say that these can be welded and be made as good as new or better.  I gave up on this engine after a 2nd head lost the inserts in the swirl chamber and damaged some pistons.
Post by: Jeremy on August 14, 2006, 03:24:19 pm
emailed you with my more specific questions and requests
Thanks Jeremy
