For Sale/Looking For => Parts for Sale/Wanted => Topic started by: avocado_tom on July 24, 2006, 06:09:37 am
Title: NEEDED: Vacuum check valve (?) for 1.6TD
Post by: avocado_tom on July 24, 2006, 06:09:37 am
When I was pulling the 1.6TD from an '84 Jetta, I made the mistake of attempting to pull off a hose that led from the block to the brake booster (IIRC).  Unfortunately, the plastic port coming from the engine block broke off with it inside the hose.
I assume this is a vacuum hose and that they plastic bit was a one-way, check valve?  Does this sound right?
Does anyone have one of these they're looking to part with?
Cheers,
    Avocado Tom
Post by: BlackTieTD on July 24, 2006, 07:32:45 am
sounds right to me. adding your location to your profile may help in your search for a replacement  :)
Post by: avocado_tom on July 24, 2006, 07:47:57 am
Ah.  Good point.  Thanks!   :D
Post by: BlackTieTD on July 24, 2006, 07:56:47 am
cool. there seem to be a lot of dubbers in PA...maybe due to the old westmoreland factory?
re-reading your original post i'm not sure if that part is the check valve, or if you have one in-line as i do on my 1.6TD. make sure if you're having it shipped or whatever its the right part  :mrgreen:
