Engine Specific Info and Questions => IDI Engine => Topic started by: DVST8R on July 02, 2006, 03:05:49 pm
Title: Complete Pump Dissasembley w/Pics! (NOT DIAL UP FRIENDLY!!)
Post by: DVST8R on July 02, 2006, 03:05:49 pm
Right here on this site, but in french...
 :cry:
Maybe we could get one of our bi-lingual members to translate and put it in the FAQ.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1573
Post by: jtanguay on July 02, 2006, 06:19:57 pm
for now you can use http://babelfish.altavista.com/ and translate the actual webpage.  It's not pretty, but it helps.
the inside of the pump has quite a few pits in the metal... must be from bad diesel?
Post by: DVST8R on July 03, 2006, 10:46:53 am
Quote from: "jtanguay"
Yeah I supose it helps... but then again so does watching tv in french :P
I really don't like the bablefish translater it does a poor job at best.
Post by: jtanguay on July 03, 2006, 12:17:19 pm
Quote from: DVST8R
Quote from: jtanguay
mostly in part because it doesnt re-arrange the words.
Post by: RabbitJockey on July 03, 2006, 10:40:54 pm
i think i used googlet o translate that page, and i learned a hell of alot about how the pumps work
alot of good stuff here too
http://www.cs.rochester.edu/u/jag/vw/engine/fi/injpump.html
Post by: veeman on July 07, 2006, 01:38:26 pm
Very interesting page... tons of pics.  I always wondered what some of that stuff looked like.
I can translate that page, but I'm not sure how I'd do it without recopying the original pics and such.  Would I repost it on that thread or here in the English section?  Is there enough interest in that or do the pics do a sufficient job at explaining everything?
I notice there are a few technical terms I'd have to look up, but the rest of it doesn't look that bad...
Post by: Benjamin on July 07, 2006, 02:27:08 pm
i think its a good topic for the FAQ?
Greetz, Benjamin
Post by: DVST8R on July 07, 2006, 05:25:54 pm
Quote from: "veeman"
I think that would be great and put it in the FAQ section.  8)
Post by: veeman on July 13, 2006, 11:54:12 am
Then insert the english version of each phrase in turn.  Once it's done, I'll make this post a smiley face so that it's not all posted twide.  Cheers.
Ok... I'll do my best.  In all honesty, I've never taken a pump apart in this detail , so it might take me a bit to get some of the tech terms for the parts right, but I can always go back and edit those as you guys point them out to me.  Just let me know so this thread doesn't get 10 miles long.  I've taken a little bit of liberty and tried to clarify some points so the translation is not 100% accurate word by word.  Here goes:
Alright, Folks....  Here’s my Friday night project :  prepare a nice working Bosch pump to install on a 205 (Peugeot?).
Since the pump was in unknown condition, it was to be completely taken apart and rebuilt with new gaskets / seals and everything. As it turns out, this was a good move because the inside of it was full of crap..
So…Here’s the starting point, the pump and a packet of seals containing the throttle lever sleeve and the mainshaft seal :
(http://bricofoy.free.fr/voiture/pompe/dsc05036.jpg)
And here's the same thing an hour later..
(http://bricofoy.free.fr/voiture/pompe/dsc05301.jpg)
The Bosch pump looks "crowded" doesn't it? :D and yet, can't complain, a rotary pump is worse  :shock:
I didn't take any photos during disassembly, so we'll start from here.  If you have any questions about the disassembly, just follow this thread from the bottom up ;)
It goes without saying that once the pump is apart, all the pieces must be rigourously cleaned.  In addition, it also greatly helps reassembly to lubricate all parts that adjust, rub or slide together with penetrating oil.
We'll start by reassembling the outlet ports (pressure valves) on the hydraulic head.  Here are the different components of the outlet ports:  valve, valve spring, adjustment shim, nice new sealing washer and plunger.
(http://bricofoy.free.fr/voiture/pompe/dsc05305.jpg)
The parts reassembled :
(http://bricofoy.free.fr/voiture/pompe/dsc05306.jpg)
and the whole thing :
(http://bricofoy.free.fr/voiture/pompe/dsc05307.jpg)
With that done, let's get on with the "serious" stuff
hoooo,  it's completely empty ! You can even see my jeans at the bottom of the hole... :lol:
(http://bricofoy.free.fr/voiture/pompe/dsc05308.jpg)
We'll start by reassembling the stator on the transfer pump:
(pay close attention to correctly align the threaded holes with the holes at the bottom of the pump body marked in green)
(http://bricofoy.free.fr/voiture/pompe/dsc05310.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05311.jpg)
Next, the rotor and its vanes :
(http://bricofoy.free.fr/voiture/pompe/dsc05312.jpg)
First the rotor :
(http://bricofoy.free.fr/voiture/pompe/dsc05313.jpg)
Next the vanes go in with the help of a long needle nose pliers:
(http://bricofoy.free.fr/voiture/pompe/dsc05315.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05317.jpg)
then the rotor cover :
(http://bricofoy.free.fr/voiture/pompe/dsc05318.jpg)
Here it is in place with its screws :
(http://bricofoy.free.fr/voiture/pompe/dsc05319.jpg)
We'll now put the main shaft in place as shown below:
(http://bricofoy.free.fr/voiture/pompe/dsc05320.jpg)
Before putting it back in its place, you have to first put in the governor drive gear along with two new elastic shims/couplers:
(http://bricofoy.free.fr/voiture/pompe/dsc05321.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05322.jpg)
Next, add the washer that goes behind it:
(http://bricofoy.free.fr/voiture/pompe/dsc05323.jpg)
and finally the transfer pump drive key in the shaft:
(http://bricofoy.free.fr/voiture/pompe/dsc05324.jpg)
Then you put the whole thing in the body of the pump:
(http://bricofoy.free.fr/voiture/pompe/dsc05325.jpg)
And...here it is in its place :
(http://bricofoy.free.fr/voiture/pompe/dsc05326.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05327.jpg)
We'll now put the put the following pieces together:  the roller carrier with its actuator pin for timing advance:
(http://bricofoy.free.fr/voiture/pompe/dsc05328.jpg)
Put the actuator pin into the carrier (be sure to put the hole in the pin on the correct side!)
(http://bricofoy.free.fr/voiture/pompe/dsc05329.jpg)
Next, put the assembly in the pump :
(http://bricofoy.free.fr/voiture/pompe/dsc05330.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05331.jpg)
...and here's the actuator pin when it's in its appropriate place.
(http://bricofoy.free.fr/voiture/pompe/dsc05332.jpg)
It sticks out into the advance mechanism's bore:
(http://bricofoy.free.fr/voiture/pompe/dsc05333.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05334.jpg)
Ok, now all we have to do is assemble the roller carrier so we can put the advance piston in place like so:
(http://bricofoy.free.fr/voiture/pompe/dsc05335.jpg)
Put the assembly back together :
(http://bricofoy.free.fr/voiture/pompe/dsc05336.jpg)
The piston in place :
(http://bricofoy.free.fr/voiture/pompe/dsc05338.jpg)
Pay close attention to the piston's orientation.  The machined part of the piston that accepts the spring is installed on the side of the evacuation hole that goes to the transfer pump:
(http://bricofoy.free.fr/voiture/pompe/dsc05337.jpg)
All that's left is to drop the acutator pin in place
and secure it with its pin.
(http://bricofoy.free.fr/voiture/pompe/dsc05340.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05342.jpg)
Install the clip on the end of the pin:
(http://bricofoy.free.fr/voiture/pompe/dsc05343.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05344.jpg)
Next, we'll put on the transfer assembly cover with a new seal:
(http://bricofoy.free.fr/voiture/pompe/dsc05345.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05346.jpg)
Then, on the other side, the spring and the automatic advance mechanism (cold start advance lever / cover for us VW guys?):
(http://bricofoy.free.fr/voiture/pompe/dsc05347.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05348.jpg)
Eventually, I removed the electric adavance mechanism since the 205 doesn't have this feature.  I put a normal cover in its place.
(http://bricofoy.free.fr/voiture/pompe/dsc05415.jpg)
Next, you install the cross-shaped piece  that drives the rest of the pump:
(http://bricofoy.free.fr/voiture/pompe/dsc05349.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05350.jpg)
Then install the rollers... They are shown here on their support outside of the pump.  Pay close attention to the orientation of the washer which is curved to adapt to the outside shape of the support:
(http://bricofoy.free.fr/voiture/pompe/dsc05351.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05353.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05354.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05356.jpg)
Install the spring that goes in the center :
(http://bricofoy.free.fr/voiture/pompe/dsc05357.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05358.jpg)
Next add the camplate which goes on top:
(http://bricofoy.free.fr/voiture/pompe/dsc05359.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05360.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05361.jpg)
To align this part, the drive pin for the piston (marked in green) must be aligned with the key in the pump's shaft.
It's the cams (humps) of this plate that cause the piston's movement when the rollers pass over them.  The piston moves, compresses the fuel and injection occurs.  You can modify the advance by turning the roller carrier in relation to the timing advance piston's position underneath.
With this pump, I changed the camplate because this pump's original camplate didn't have the same profile.  The one that's in there now comes from a 205 pump.
Now let's go on to the distributor piston:
(http://bricofoy.free.fr/voiture/pompe/dsc05363.jpg)
Next we add the governor assembly:
(http://bricofoy.free.fr/voiture/pompe/dsc05364.jpg)
This piece, directly actuated by the governor, is going to more or less cover the piston's outlet hole (marked in green on the preceeding photo).
During injection, the piston is pushed in, pushed by the camplate.  Depending on the position of the governor assembly, the hole becomes more or less blocked by the piston's movement after its stroke.  This is how the amount of fuel to be injected is regulated. (when the hole is "free" the pressure is relieved through there and injection stops).
The piston is called the "distributor" because it is driven in rotation and directs the fuel towards each outlet port (pressure valve toward the injector)  through each of the different holes on it.
Next, we put the distributor piston back into the hydraulic head:
(http://bricofoy.free.fr/voiture/pompe/dsc05365.jpg)
..and the return springs:
(http://bricofoy.free.fr/voiture/pompe/dsc05366.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05367.jpg)
The spacer shim at the end of the piston:
(http://bricofoy.free.fr/voiture/pompe/dsc05368.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05369.jpg)
..and it all goes into place in the pump :
(http://bricofoy.free.fr/voiture/pompe/dsc05370.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05371.jpg)
We'll now reattach the governor levers and the return springs on them:
(http://bricofoy.free.fr/voiture/pompe/dsc05373.jpg)
The most complicated part of this operation is the correct positioning of the springs:
l
(http://bricofoy.free.fr/voiture/pompe/dsc05375.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05376.jpg)
Detail of the how the special triangular head bolts (for which I made a special socket by grinding an old 13mm socket) will fit into the lever assembly:
(http://bricofoy.free.fr/voiture/pompe/dsc05377.jpg)
Installation of the bolts with new aluminum gasket:
(http://bricofoy.free.fr/voiture/pompe/dsc05379.jpg)
The only thing remaining on this step is to put the lever assembly in from the top:
...And no...that doesn't work.  We're screwed.  Impossible to do it this way.  We'll have to disassemble the head and then put the levers in place before all of the rest. :mad:
By the way, on the distributor piston, you'll see the outlet orifice (marked in green), the orifice leading to the injectors (red) and the 4 grooves that fill the chamber at the end (green).   The piston is hollow to allow flow through to all of that.
(http://bricofoy.free.fr/voiture/pompe/dsc05381.jpg)
The head assembled with all its return springs:
(http://bricofoy.free.fr/voiture/pompe/dsc05383.jpg)
The only thing left here is to put everything back into place then disassemble it one or two more times after the springs fall out in the process...and here you go:
(http://bricofoy.free.fr/voiture/pompe/dsc05384.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05385.jpg)
Let's go on now to the reassembly of the centrifugal governor.  Here are all the pieces:
(http://bricofoy.free.fr/voiture/pompe/dsc05387.jpg)
First you put together the counterweights:
(http://bricofoy.free.fr/voiture/pompe/dsc05388.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05389.jpg)
Then you put them back into the body of the governor:
(http://bricofoy.free.fr/voiture/pompe/dsc05390.jpg)
Next, you replace the governor lever seen below.  (notice the calibrated hole that's part of the system that alters the initial fuel injection in function of the load):
(http://bricofoy.free.fr/voiture/pompe/dsc05391.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05392.jpg)
After this, you put in the governor shaft in the body of the pump:
(http://bricofoy.free.fr/voiture/pompe/dsc05393.jpg)
These are the washers that go behind the governor's rotor:
(http://bricofoy.free.fr/voiture/pompe/dsc05394.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05395.jpg)
the governor itself :
(http://bricofoy.free.fr/voiture/pompe/dsc05396.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05397.jpg)
Then install the shaft and tighten it with the help of a hex key and a normal box wrench to hold the shaft in position so it doesn't move while the lock nut is tightened.
The position of this shaft is important because it regulates the system of initial injection by vacuum (?).  It's wise therefore, to mark the position of this shaft during pump disassembly.
(http://bricofoy.free.fr/voiture/pompe/dsc05398.jpg)
There you go... Now the pump body is complete.  The only things missing are the pump cover and the transfer pressure regulation valve that I could have put on right after this, but didn't...
We'll start by removing the old lever guide sleeve:
(http://bricofoy.free.fr/voiture/pompe/dsc05399.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05400.jpg)
Then we put the new sleeve in its place:
(http://bricofoy.free.fr/voiture/pompe/dsc05401.jpg)
Gently push the sleeve home by using a bolt and some large washers:
(http://bricofoy.free.fr/voiture/pompe/dsc05402.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05403.jpg)
Next, put in the governor shaft and return spring "capsule":
(http://bricofoy.free.fr/voiture/pompe/dsc05404.jpg)
Detail shot of the attachment of the governor spring assembly on the governor lever:  the flat (green) fits into the slot/grove in the lever (red) then gets pulled into place from behind:
(http://bricofoy.free.fr/voiture/pompe/dsc05405.jpg)
And there you go... just have to replace the cover (with a new seal) and screw it into place.
Next, you put the throttle lever back in its place thanks to the markings on the shaft and on the lever (we would have obviously have taken care to mark it's exact position during disassembly):
(http://bricofoy.free.fr/voiture/pompe/dsc05406.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05407.jpg)
Now, put the transfer pressure regulation valve back on (with new o-ring seals, of course):
(http://bricofoy.free.fr/voiture/pompe/dsc05408.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05409.jpg)
Next, add the electric fuel cutoff solenoid :
(http://bricofoy.free.fr/voiture/pompe/dsc05410.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05411.jpg)
And finally, install the seal on the mainshaft (you can do this by using a large socket and the pump's shaft pulley nut to press it into place on the shaft...sorry, no photo,).
(http://bricofoy.free.fr/voiture/pompe/dsc05412.jpg)
(http://bricofoy.free.fr/voiture/pompe/dsc05414.jpg)
And there you go, all done. Nothing left to do but to install it onto the 205! :)
(http://bricofoy.free.fr/voiture/pompe/dsc05418.jpg)[/quote]
Whew...
Post by: DVST8R on July 13, 2006, 03:23:20 pm
Way to go Veeman!! That just made my day!
Post by: 935racer on July 13, 2006, 04:36:15 pm
I can go through and give all the bosch technical names if anyone is interested. Also we need to put a disclaimer on this, there are few crucial parts of DISSASEMBLY not noted here that are integral to putting the pump together without the proper tools/equipment. IF you just take it apart and try to put it back together based on these pictures you are gonna be in for a dissapoinment. Also note that this is a ghetto rebuild, many of these parts should not be reused, but can be. Its a lot like tearing apart an engine and just re ringing it and maybe putting new bearings in. I can try to throw some tips out as I put the names in, but to do this right I would need to take pictures of the dissasembly process, which is almost as important as reassembly. I've got 4 pumps that I have completely dissambled and rebuilt that are running and driving perfectly, but the 2 pumps before those 4 good ones... well, lets just say I learned the hard way :o
Post by: scopefrfd on July 13, 2006, 08:42:17 pm
I think this is probably one of the best posts I ever seen on any forum.....it would be fantastic if we could also see the dissassembly too.  Hopefully that can be included in time.   Incredible job by veeman..for taking the time to translate.
Post by: scopefrfd on July 13, 2006, 08:57:40 pm
not to get off topic...but has anyone tried to lighten the governor flyweights in an effort to increase fueling at high rpm rather than shimming the governor spring?  The governor flyweights, can different weights be purchased?   I'm trying to figure out the best way to increase my fueling at high rpm....my current 11mm pump is cutting back way to much fuel after 3-4k....feels like my M-tdi is hitting a wall.
Post by: 935racer on July 13, 2006, 11:00:37 pm
DONT lighten the governor flyweights, in fact they are pretty much always replaced with new items in a pump rebuild. Lightening them will not give you more fuel in higher rpm. Delete the governor intermediate spring to gain some additional fueling, to make your fueling useful after 5000rpm you will need to increase DYNAMIC timing, to help reduce INJECTION and IGNITION lag.
Maybe I'll get malone to come out to the shop and he can take some pictures of proper pump dissasembly.
Post by: LeeG on July 14, 2006, 01:50:26 am
veeman, You da man!!!
935racer, move veeman's post to FAQ for posterity1?
Post by: Benjamin on July 14, 2006, 04:09:46 am
Is there a FAQ or example to do this DYNAMIC timing modification myself?
i think i didnt read about it before.
How much rpm can a VE pump rev? i think the camplate-springs will start flying when doing those high revs
Place Veeman's work in the FAQ, maybe its an idea someone can host those pics?
Greetz, Benjamin
EDIT:
i found some info's on the Search about this DYNAMIC TIMING, maybe there should be a FAQ about it to. i just getting this understanded, but i cant imagine how you can get this calculated, any tips or FAQ
Post by: scopefrfd on July 14, 2006, 03:56:03 pm
I have a tdi timing cover which is much deeper than the stock unit on my 11mm M-pump.  If I install the cover would that increase my dynamic timing?
Post by: DVST8R on July 14, 2006, 09:33:55 pm
Probably not as it would just change the preload of the spring, all of the deeper factory covers that I have seen, still stop the piston at the same place the just change the spring preload depth. In order to advace your dynamic timing you would have to mahcine out the cover to a diameter of 25mm iirc, to whatever depth you require to get the advance you are looking for. Or shave the piston.
This really is better left to a pro pump builder with a "pump dyno" that can view the rate of advance as well as the total amount of advance, but if you want to risk your pump I say go for it and make sure to report to us the results 8)
Post by: Benjamin on July 15, 2006, 09:29:56 am
(http://scirocco.cs.uoguelph.ca/gtd/bosch-ve/figure-31.gif)
is it the number 5 we need to make shorter????
How to measure we dont get TO early??
(http://img283.imageshack.us/img283/9725/pict0056mg7.jpg) (http://imageshack.us)
why is this thing for? there is also a electrical contact, what can it it do??
Greetz, Benjamin
Post by: Hey on July 16, 2006, 08:53:17 am
The bottom picture is of an electric cold start timing advance mechanism.
Sorry, but it is not!  Want your are taking about is on the other side.
It is a selenoïd that takes the fuel pressure from the top of the pump and report it in the timing piston chamber to counterbalance pressure and avoid timing advance. It only works when there is pressure inside the pump.
-If 0 volt is applied, the pressure is passing inside the piston chamber and there will be no timing advance
-If 12 volts is applied, the pressure is NOT passing (you always want 12volts there)
Post by: Benjamin on July 16, 2006, 02:17:00 pm
Do you mean this, or where for is this?
in the upper left corner you can see a mechanisme, i thought this is for the timing advance when the engine is cold, so it should better run, its fully adjustable. when i pull on it i dont hear any difrance in rpm, i hear maybe a other sound, but maybe its in my had
where for is this solenoid? i hope i understand right, but i dont see the usefulness when you always put the 12v on it.
Greetz, Benjamin
Post by: Hey on July 17, 2006, 06:02:12 am
On the first picture, I wouldn't say it's a device to advance cold timing (not sure because never had such a pump in my hand)
The other picture... I have a few pumps like that and already studied it. On the bottom of the pump (second picture) you see a selenoïd  with a hose on going on the top of the pump.
If you take that selenoid off the pump and blow air inside this hose, the air will pass free and exit by the selenoïd.
However, if you put 12volt on the selenoïd, the air is NOT gonna pass free.
Then with 12volts applied... the pressure on the top of the pump cannot goes by the selenoïd and counter balance the pressure on the timing advance chamber.
Post by: veeman on July 18, 2006, 09:05:35 am
So... can anyone PM me with the "proper" names of some of the items I translated?   I'm pretty sure that I got a few of them wrong.   Once I have the corrections, I'll just edit my original post and then it'll be correct from here on out...
Post by: DA-BRT on January 05, 2007, 05:06:28 am
I learned rebuilding pumps at school (Autotechnical University) But one thing I havn't been able to find te last years is IP torq values.
Can anybody post the torqing values? Or have I missed them on the forum?
Post by: Tintin on January 05, 2007, 06:03:26 am
(http://img503.imageshack.us/img503/4448/serrageimagexa9.jpg)
(http://img443.imageshack.us/img443/9124/torque1me2.jpg)
(http://img443.imageshack.us/img443/7862/torque2lr6.jpg)
(http://img169.imageshack.us/img169/1158/torque3xt7.jpg)
(http://img58.imageshack.us/img58/5172/torque4js2.jpg)
(http://img58.imageshack.us/img58/3509/torque5iq5.jpg)
Post by: DA-BRT on January 05, 2007, 04:02:25 pm
Thanks Tintin for the values. I've been searching for these for a very long time.
Post by: rallydiesel on August 09, 2007, 02:46:59 pm
Quote from: "935racer"
Can you just briefly mention the parts that need to be marked during disassembly that need to be marked?
Post by: Vincent Waldon on August 09, 2007, 03:26:44 pm
I'll start the list:
- take pictures of the damn throttle springs
- mark the position of the throttle shaft on the throttle arm
- measure the protrusion of the governor shaft (the one with the reverse threads)
- measure the protrusion (or count the turns) on the main fuel screw
- note the alignment of the main cam plate... specifically the pin that drives the distributor shaft... and put it back the way you found it... can easily get it 180 degrees off... use the keyway on the main shaft as a reference
Been a while so that's all I can remember of the top of my head... others will chime in I'm sure.
Post by: myke_w on August 24, 2007, 07:08:14 am
Beautiful write up,
I see no mention of the main bushing in in the pump housing. how does one go about replacing that. I have about 5 pumps on my shelf with bushings worn so badly that fuel leaks past even a new seal.
