Engine Specific Info and Questions => IDI Engine => Topic started by: Cheesetoast on June 01, 2006, 11:23:43 pm
On my engine there is 2 hoses coming off the pcv vent, one from the crankcase and one that goes to the intake. I bought the aluminum pcv filter, it only has one inlet/outlet, should I unplug one of those 2 hoses or do I have the wrong item?
(http://members.shaw.ca/adowler3/tdengine.JPG)
the other option i was thinking wiht installing a T so i can plug both in. Either that or plug the one going to the intake, but don't i need that connected?
You need this one,
http://www.stancomachine.com/CCVII.htm
You have the A4 version. If you wanted to install a "T" it would need to go on the bottom, where the filter plugs into the valve cover.
:x guess i'll return it...
