Engine Specific Info and Questions => IDI Engine => Topic started by: ssray on May 25, 2006, 05:54:02 am
Title: i`m not greedy i just need a little more..........boost
Post by: ssray on May 25, 2006, 05:54:02 am
Having just done the max fuel screw thing and liking it i`d like moore boost please but i dont know what turbo i have my engine is a 1993 seat 1.9td aaz, there is no threaded bit to the wastegate so that discounts that and the link in the more power for your 1.9 is dead.
cheers  Ray :lol:
Post by: ssray on May 27, 2006, 11:43:45 am
anyone??
Post by: Benjamin on May 27, 2006, 12:43:58 pm
Install a bleed valve.
I THINK you got a K14 ore a T2.
correct me if i'm wrong pls
Greetz, Benjamin
Post by: ssray on May 27, 2006, 12:51:07 pm
Cheers Benjamin, i have plans for one of those http://transportation.hackaday.com/entry/1234000267047266/
will do.
Ray :oops:
Post by: Benjamin on May 27, 2006, 02:09:19 pm
were are you from???
you can buy it for about 25-50€.
try ebay.
Greetz, Benjamin
EDIT:
http://cgi.benl.ebay.be/JRD-Boost-Controller-XR6-Starlet-diesel-turbo_W0QQitemZ4643659845QQcategoryZ43808QQrdZ1QQcmdZViewItem
QUICKER ACTING BALL & SPRING MECHANISM FOR FASTER TURBO SPOOL!!!!!!!!!!! WAIT TILL YOU FIT ONE
my brother got a uno turbo gasser, he installed a kind of bleed valve on it, and his turbopressure exaly realy spool up much quicker, any idea how this works??
Greetz, Benjamin
Post by: 745 turbogreasel on May 28, 2006, 01:01:25 am
I did a ball and spring controler.
Now I hit 11 PSI aby 2400 RPM instead of 3200.
from 2800 up, I am 14.7, where I used to max at 11.
My 'saffety falve' still works, I just threaded the screw in so It doesn't open till 15.  I am not gonna turn it up any more untill Ihave my IC installed.
the car is even more enjoyable to drive without the 'hole' after each upshift.
I had to seriously port the valve to get it to work with the 2 hose WG actuator I have.  Initialy it would take off like a rocket, then pop the safety valve around 4000 RPM, even with the valve set to open at 7 PSI.
Post by: ssray on May 30, 2006, 05:03:30 pm
Benjamin
i`m in the uk just north of london, i could e-bay it ......but is that not less fun??
cheers Ray
