Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: superman293 on May 19, 2006, 08:55:32 pm
Title: air/fuel gauge?
Post by: superman293 on May 19, 2006, 08:55:32 pm
I was wondering if it was possible to install a air/fuel ratio gauge on a 2000TDI, i know they run to a oxgen sensor in a gasoline car but im not sure about the TDI
thanks
Post by: dubCanuck1 on May 19, 2006, 11:27:21 pm
No o2 sensor until the Pumpe Duse (MKV) TDI's. You shouldn't need an A/F sensor for your TDI. I don't even know if there's one sensitive enough to read it with how lean diesels run compared to gassers.
Post by: vwmike on May 20, 2006, 02:17:02 am
The gauge you want measures exhaust gas temperatures, also known as EGT's.
Post by: superman293 on May 21, 2006, 01:54:17 pm
what is the importance of the exhuast temperature?
thanks
Post by: Piper106 on May 28, 2006, 04:38:20 am
Exhaust gas temperature (best measured in the exhaust manifold between the cylinders and the turbocharger) is a indicator of how hard the motor is working.  Stock exhaust temperatures are not problem, but as guys turn up the fueling and other mods, exhaust gas temperature goes up with the power.   Too high on the temperature and the potential is that the top of the pistons, the exhaust valves or the turbocharger will fail from excess temperature.  As far as a 'safe' vs. 'danger' exhaust gas temperature number, there have been several threads, both here and the IDI forum in this board.
Piper106
Post by: TDForNow on May 29, 2006, 12:58:15 am
Diesel air/fuel "sensors" are purely visual...........no smoke=not enough....just a touch of smoke=now we're cookin'!..... too much smoke= :shock: oops we're chokin' the heard!!
