Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: Cynical 1 on May 15, 2006, 04:28:03 pm
Title: Question - what pumps are you guys running on mechanical TDI
Post by: Cynical 1 on May 15, 2006, 04:28:03 pm
I've searched, read the FAQ's, and followed quite a few posts. but haven't found many things in common, or many descriptions...
What injection pumps are you running on your mechanical TDI conversions?
I've seen a cummins, 1.9TD, 1.6TD, hybrid this and that, but no real "this is what it is and what it is from" listings...
I'm wanting to do a M-TDI, and I'm trying to source a pump. I would like to know what works.
I would like the:
Bosch part number
Manufacturer part number (if known)
application (what it originally came from)
Hybrid- what part of what onto what to make it work.
Thank you.
Perhaps this should be a FAQ topic???
Post by: Cynical 1 on May 22, 2006, 01:26:37 pm
Ok.
So, nobody wants to help out, or prevent this question from being asked again by other newbies???
Post by: vwmike on May 22, 2006, 01:35:17 pm
There are various ways to get this done but probably one of the simplest would be to use a 1.9TD (AAZ) pump as a base as the input shaft and offset should be correct (as far as I know). Install the TDI camplate and pump head (manuals were 10mm, automatics were 11mm) onto the AAZ pump, slap a 1.6TD LDA pin and lid on top and modify the governor to meet your needs.
Post by: macsdub on May 25, 2006, 09:30:38 am
sorry man,im in germany,its hillfolkr here,,,
 im using an 84 1.6td pump,with a 12mm head from a cummins(mid 80s) pump,i can run low 14's with a stock governor
Post by: therabbittree on May 26, 2006, 05:49:10 am
yo blake let me know if you grab one of those 1.4's or 1.2's... i am looking for the 150hp 5cyl tid fro aeurovan with teh 6spd trans and wiring cluster etc..let me knwo I emailed the guy you are dealing with..later have frun take soem brochures back..hehe
deo
Post by: Tintin on May 26, 2006, 05:43:30 pm
Hy, A question for fine tuning about a mechanical pump for the TDI, the advance timing, Which spring and timing piston are best to have a linear curve of timing?
Post by: macsdub on May 27, 2006, 04:25:17 am
we are back dude,we didnt get one yet,but its still in the works...........ill be 'round today,rabbittree
