General Information => Troubleshooting => Topic started by: BellCityDubber on May 05, 2006, 12:15:55 pm
Title: Slipping? oil?
Post by: BellCityDubber on May 05, 2006, 12:15:55 pm
today I had some free time so I thought I'd do a little bit of work on the jetta...
after my repairs, on my way back from my test run I had an unpleasent experience. I think my clutch is slipping! I've never experienced clutch slipping before, but when I'm driving along I'll notice the power's gone but the engine revs and then *BANG* it's back on again.
I also think that it may be in conjunction with a slight noise I've been keeping my ear on.  in low gears at about 2000 rpms I get a light rattle/tapping noise.
Would it be time to change the pressureplate/clutch?
aside from that I thought I'd check my fluid levels and such and come to find out that I have a black coating of what LOOKS like oil in my coolant resivoir... I've seen bad headgaskets and it's not like I have milky oil or brown coolant it's just a coating of black on top.   I dont burn white smoke or anything (trust me, all my smoke is BLACK ;) )
anyone have any ideas to point me in the right direction, I'd really appricate the help
thanks
phil
Post by: BlackTieTD on May 05, 2006, 12:22:12 pm
:( sounds like head gasket on the way out and slippy clutch as you diagnosed...
Post by: BellCityDubber on May 05, 2006, 12:29:46 pm
:roll: great....
I don't THINK it would be the HG coz I've seen them on their way out, and this one should have been on it's way out.... months ago... (the coolant resivoir has been black since I've got it from my grandparents.
as for my slipping clutch... I think I'm screwed there huh...
Post by: BlackTieTD on May 05, 2006, 12:38:42 pm
if its not the HG, then somehow oil has made it into your coolant. depending on where the HG fails, you will see different warning signs...
has it been black with oil since you got it? did it blow a HG in the past and those oil swirls are just residual? did you use an old oil jug to mix/fill the coolant perhaps?
Post by: BellCityDubber on May 05, 2006, 01:19:34 pm
perhaps I'll do a cooling system flush and see what I end up with.
my headgaset on my 8v wasnt this peculiar, it went, blew white smoke. and that was that... this is a little strange. just a black film of oil or perhaps soot on top of the coolant... no milky oil... and no white smoke...
I didn't do any cooling system work on this car since I've got it.. so I dont know if they used oil jugs....
I'll keep bombing around in it.. and if it blows up... it blows up in my face I guess eh?
but I think the cooling system is due for a flush... just to see what happens..
as for the clutch.... I'll keep my ear/eye on it.
*update*
I went on a drive over to a friends house (20 minutes away)
and I've found out some more symptoms of my problem...
one of them is that it may happen in all gears (as it happened in 2nd and 3rd earlier today, and it happened in 5th on the way here)....
and the second thing is that I don't think that the clutch is "slipping" as much as the engine seems to stop responding to the pedal...
when it stops responding it wont accelerate as if the clutch were slipping, and when it happened last I put my foot to the floor and it didnt accelerate...
Sooo...
would this be MORE and OTHER symptoms of a headgasket....
Post by: hillfolk'r on May 05, 2006, 09:01:00 pm
Quote from: BellCityDubber
:roll: great....
diesels will usually be blackinthe res.when head gasket goes like that,dumping oil in the cooland,yea you get some cheeze,but it turns black
Post by: LeeG on May 05, 2006, 09:06:32 pm
my 1.6 TD has been leaving a regular film like soot in the top of the coolant bottle for 200,000 km.  HG also periodically leaks a dribble of coolant over vacuum pump area then seals up again.
I figure it can't be anything good, but it hasnt stopped me from flogging the poor thing for the last 2 years.
Post by: BellCityDubber on May 05, 2006, 11:22:28 pm
Quote from: LeeG
yea, I have the same thing... but will a bad headgasket generate hesitation and loss of power/acceleration for a few seconds?
I thought it was my clutch but it doesnt ACCELERATE when I mash it to the floor when it does it....
I also thought of something else, I'll fix it tomorrow and see if it does it again...
I may be a victim of my own carelessness and stupidity.... I'll keep people posted....
Post by: BellCityDubber on May 06, 2006, 11:05:37 am
I think I am a victim of my own stupidity and carelessness...
when I making my first attempt at raising the fuel, I pulled the connector out of the housing for what looks like to be the fuel cut off solanoid... so I put it thru the hole and wound it around.... not the best fix... I know... but I think that perhaps could have been my issue.. I've fixed it properly now and I went back to trying to get the idle to go back DOWN
so I raised the fuel and started messing with the 10mm nuts and the slotted screws on the back of the IP (engine side)... which affects my cold start pull handle.... (as the FAQ says something about cars with AC which mine is)
or do I have to move the risidual fuel screw where the butterly rests against... to move the idle stop further in?
I think I fixed one problem, but am still lost on how to get more fuel.....
Post by: BellCityDubber on May 26, 2006, 10:48:43 am
Quote from: hillfolk'r
well... this week I decided I'd clean out my resivoir, and aparently there's still a bit of oil going in to the coolant bottle.. :(
I think I do have a headgasket problem.....
Post by: BellCityDubber on May 26, 2006, 01:02:58 pm
Quote from: libbybapa
Check your oil cooler first.  They also fail and let oil and water mix.
Andrew
yea, I've heard about that.... that's a good idea...
if it's bad I dont think I'll be going for a replacement, as much as I'd like to keep things oem on the car.... it'll probally get removed....
it's similar to removal on the gas cars, eh?
I'll be researching for a thread...
thanks for the tip
Post by: 745 turbogreasel on May 26, 2006, 11:54:55 pm
Andrew
Gee I must have got lucky, mine only let the oil out on the ground .
Post by: macsdub on May 27, 2006, 04:44:32 am
i know all about how a slipping clutch feels,,the revs rise a little faster than the road speed...its a wierd feeling,and sometimes barely noticible by watching tach,and speedo,its more of a "feel" thing,and you may notice it easier in the higher gears
i ran a centerforce in my idi,it was nice,but the same clutch in my tdi cant hold the power,itll slip in 5th,until i "warm it up" by letting it slip once or twice in 5th,then its "ok"..
but i gotta get a 4 puck....... :?
Post by: BellCityDubber on May 27, 2006, 12:14:09 pm
Quote from: macsdub
Well, I dont know if I posted above, but it wasnt my clutch, it was my fuel cut-off wire at the pump was disconnecting durring driving.. so that was fixed.
has anyone else ever had their oil cooler mix the oil and the coolant like the symptoms I'm having?
Post by: fspGTD on June 29, 2006, 12:03:15 am
Moved to troubleshooting.  IDI engine is for power enhancement related discussion only.
Post by: shwartzbewithyou on June 29, 2006, 10:15:49 am
I've had oil in my coolant for a while now although I'm not entirely sure it oil.  what happened was my cooling system never truely worked up to par until one day i blew a hose.  I pulled out the entire hose and replaced it, as soon as i did this I got full flow through the system but along with it came what I believe was a clog in the system from that hose deteriorating over time from the inside out.  So all kinds of residue, buildup and even really tiny bits of rubber flowed through the system.  This makes it look like oil but it's not 100% oil.
Just keep driving it until either it get's worse or you do a comp check.  You may be chasing the wrong problem.
