General Information => Troubleshooting => Topic started by: 91turboeco on May 04, 2006, 03:53:36 pm
Title: trying to change the timing belt. TRYING
Post by: 91turboeco on May 04, 2006, 03:53:36 pm
doing the rings and bearings in my 91 TD. waiting for part so started the timing belt. everything off except the big bolt in the center of the crank pully.
how do you get it off?
Post by: MacGyver on May 04, 2006, 04:54:55 pm
Best way to get it off is with an impact gun. One with decent torque.
To get the new one (they're one use stretch bolts) back on to spec later, you'll need Popeye & a couple cans of spinach.
Post by: QuickTD on May 04, 2006, 07:55:30 pm
No need to remove the big bolt for a timing belt change, just take out the 4 allen head bolts and the V belt pulleys should come off.
Post by: 91turboeco on May 05, 2006, 03:05:01 pm
took the 4 bolts out still cant get it
crank spins freely. no pistions in block
would it be reverse thred?
Post by: andy2 on May 05, 2006, 03:20:48 pm
After removing the 4 small bolts you will need to hit the pully with a big rubber mallet or a hammer and a peice of wood.Just keep working your way around the pully and it will loosen up.some come easy and others need alot of beating.Some penetrating oil will help too. You wont need to remove the big crank bolt!
Post by: 91turboeco on May 06, 2006, 09:51:47 am
guess mine going the hard way!
Post by: hillfolk'r on May 07, 2006, 12:13:08 pm
spray a little liquid love like wd,tap w/a hammer carefully,even use a propane torch to heat it up some,watch for a flameup,if you used wd first though
Post by: 91turboeco on May 07, 2006, 03:50:45 pm
took a few good hit but it finally poped off
