General Information => Troubleshooting => Topic started by: firestorm13666 on April 21, 2006, 05:31:19 pm
Title: Bad news yet angin
Post by: firestorm13666 on April 21, 2006, 05:31:19 pm
Well i think my headgasket it shot.I have fuel or coolent bubbling out between number 2 and 3 between the head and block.So i think the head gasket is shot.I plan to search more later on about to do it.Right now i am just looking for the best parts to use to get the job done and what all i will need to do it and the price.Thanks for any help
Post by: 935racer on April 22, 2006, 09:18:28 am
You want to upgrade to a 1.9td metal headgasket and you gotta buy soem new stretch bolts. While you are there doa  full coolant flush, oil and filter change, tbelt and tensioner, replace your valve cover gasket with a rubber one, and put a windage pan in place of your crappy oil pan gasket, or at least upgrade toa  rubber one. Also if you need glowplugs its super quick while the head is off as is removing the injectors if they need to be rebuilt. Replace the 2 rubber o rings for the 2 coolant flanges on the head as well. Soem of thats overkill but thats what I like to get done while I am in there.
Post by: firestorm13666 on April 22, 2006, 09:34:50 am
Well i have to drive the car because i have been waiting people to send me parts so i can.I have already chaged all 4 glows,oil and filter,i have a timing belt siting in my room.I need to get a timing belt tensioner,as for the oid pan gasket i have been told that the 2L ABA uses a type of windage tray.As for the injectors that will have to wait till i get more money.As for the head gasket where should i get it form?Also how much of a price differnts is their between head bolts and studs?Kinda sucks that the oil is new but it might have some coolnet in it.Thanks for anyhelp.
Post by: 935racer on April 22, 2006, 09:37:23 am
Yeah you gotta drain the oil and coolant, its mandatory, studs are nice but about 10 times the cost. You can get everything you need from www.passengerperformance.com
Post by: chrissev on April 22, 2006, 03:40:58 pm
Quote from: 935racer
you don't have to drain the oil to do a headgasket,  but if it has coolant in it you'd better change it.
Post by: firestorm13666 on April 22, 2006, 05:23:01 pm
I will drain it just to be safe.As for passengerperformance are they not in Canada?I would like find some place here in the US to get parts form.No offcen to passengerperformance i just have been hearing bad things about trying to get things form Canada becaues of costums.As for the head gasket it''s self what year and model do i need to order it for?Am i going to need any tools other then the normales ones to get the job done?Should i get a head gasket set and yes i know it does not come with the head gasket,or should i just leve the intake and exhaust manifolds on it?Would it be a good idea to use that copper spray on gasket sealer?Thanks for any and all help.
Post by: firestorm13666 on April 24, 2006, 12:10:11 pm
What coolent should i use?Would GM Dex-Cool be ok?Thanks
Post by: firestorm13666 on April 24, 2006, 04:33:11 pm
Does anyone know?
Post by: Kudagra on April 24, 2006, 04:47:20 pm
Id use water 1st...then I believe VW recomends a good Ethelene glycol. Dex Cool is Propoline glycol. If you mix them you get silicon dropout and it looks like someone put jelly in your system.
Post by: fspGTD on April 24, 2006, 07:31:26 pm
Moved to troubleshooting.  Not power enhancement related.
Post by: mtnsammy on April 25, 2006, 07:20:18 am
Here is a link to where I have found almost any part needed. THe mail order is quick and customer service is great. THe only downside is the parts lookup isn't great. I have had to manipulate the car info to get the right part. If you know what you are looking for it is still easy. I have not tried calling in for assistance yet. One time I called for a missed shipment and I got the new parts 2 days later. Good people.
http://www.autohausaz.com/search/make.aspx?sid=rejbybyjhmoylyavz3jl1g45
