For Sale/Looking For => Parts for Sale/Wanted => Topic started by: dailydubber on August 03, 2017, 07:40:55 am
I'm looking for the hose that comes from the turbo compressor outlet and into the intake manifold. I have a k24 Turbo. My zip code is 21666
Sent from my HTC6545LVW using Tapatalk
I have one from an AAZ 1.9L Turbo Diesel not sure if it's the same? The part number is 1H0 129 627 AB.
(https://uploads.tapatalk-cdn.com/20170803/414ce83c8c3b0e140abecdc4750fad84.jpg)
Sent from my SM-G925V using Tapatalk
I'm actually looking for the one
coming out of the turbo and not going in the turbo like the one on this link:
http://www.mk1autohaus.com/Lifetime-Silicone-16L-TD-19L-Aaz-Turbo-Diesel--Intake-Boost-Hose_p_6518.html
if you are not worried about it looking original you can use a 2" silicone elbow, i have in the past. black silicone looks decent too.
I've tried putting a 90 degree elbow like you mentioned but it is getting kinked. I've also adjusted the compressor housing to lessen the kink but it didn't work. So I figured the original has special curves to prevent any kinks.
mine was on an aaz which has a little bit different of an angle on the inlet hose so maybe i had better luck because of that.
